Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Kitchenaid whisper quiet plus will not start, the start and resume button keeps on blinking, any thoughts
  • 188 Answers
SOURCE: blinking clean light
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 03, 2009
SOURCE: how to unlock the child lock
Most of the dishwasher in this series have an energy saver dry button. Hold this button in for four seconds and it should unlock the child safety lock. Does not work, try again for 30 seconds. Does not work. We have problem. If your model does not have an energy safer button, then type in the model number and you should be able to find the manual online and open the same to find out how to unlock the child safety lock. If all fails then you need an Electronic control board assembly, about $86 for your model, plus shipping from repair clinic.com. If you are at all handy, this is easy repair. Make sure you turn off the breaker or remove the fuse before you attempt any repairs.
Posted on Feb 20, 2010
SOURCE: Child lock blinking on a Kitchenaid ultima diswasher.
Try holding the E.S. button down for 30 seconds. Does not work, you need an Electronic control assembly which can be ordered online from Repair clinic .com for $146 for your model plus shipping. This is apparently a common problem with Kitchenaid dishwashers. Just repaired one the other day. Tried everything, but as soon as the new Electronic control assembly was installed, everything was Okay. This is an easy repair for anyone who is handy at all. Please shut off power to the dishwasher by switching the breaker off or removing the fuse.
  • 3230 Answers
SOURCE: Child lock to turn off
Well you can please follow the below steps -
1. Locate the "Energy Saver/Dry" button on the dishwasher. The location of this button will be different depending upon the specific model number of the dishwasher, but should be easy to spot. If you have trouble finding it, you can check the diagram in the manual of your dishwasher for the exact location for your specific model.
2. Press and hold down this "Energy Saver/Dry" button for at least four seconds. Make sure that you do not release the button until at least 4 seconds have passed, otherwise the lock will not become disabled.
3. Check to make sure that the child lock indicator light has turned off. If this light is no longer on, this means you were successful at turning off the child lock. If the light is still on, repeat the process, but try to press and hold the "Energy Saver/Dry" button for a few seconds longer. If it still doesn't work, there may be a more complicated issue with your dishwasher. Consult your manual, or call to the manufacturer or repair man to determine if there is another problem with your dishwasher.
Good Luck!!
Thanks
Posted on Mar 02, 2010
SOURCE: Kitchenaid Whisper Quiet + dishwasher making loud humming noise
Same here. What gives?
Posted on Apr 30, 2010
Whisper quiet plus kitchen aid manual
Hello, As You Wish -
It looks like you can obtain the owner's manual for your Kitchen Aid dishwasher through the Kitchen Aid web site. It will probably be a download option for a PDF version of the manual. This is the link: https://www.kitchenaid.com/customer-service/manuals/ . You will need to enter the model number of the dishwasher.
Note: When I obtain a downloaded PDF user manual (for anything), I create a file in my Documents folder, giving the file the name of the product, so I can find it easily. Example: Kitchen Aid Diswasher. Unless the manual is hundreds of pages long, I also print it out and keep it in a paper file folder with other appliance and equipment user manuals.
Best wishes.
Dec 18, 2017 | Dishwashers
KitchenAid Whisper Quiet Plus dishwasher Location of serial number
Usually, the sticker is located on the inside edge of the door on either the left or right side--you have to open the door to see it.
Aug 19, 2015 | KitchenAid Dishwashers
Kitchenaid whisper quiet plus dishwasher
It is likely the thermal fuse is cut off and will need to be reset or replaced depending on the model number of your dishwasher. Please provide actual model number in the comments.
Apr 25, 2014 | KitchenAid Dishwashers
I have a kitchenaide Superba Monterey 21, whisper quiet dishwasher that will not drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Apr 05, 2011 | KitchenAid Dishwashers
I have a Kitchenaide Whisper Quiet Ultima dishwasher. It will come on, but no water comes in. Is there a reset button or something that may be clogged?
Are you able to provide the model no. of your dishwasher please.
NO water coming in could be either due to water inlet solenoid not working, the controller not working or the flood switch being triggered.
Need the actual model no. to confirm likely situation.
Sep 20, 2010 | KitchenAid Dishwashers
I have a KitchenAid Whisper Quiet Dishwasher. Has been working fine. Circuit breaker seem to be working but control board is now not lighting up and buttons do not respond. Seems like no power to...
I may have leaked water into the mother board ciruitry. This can happen when there is a tiny leak or when steam gets in. Check with kitchenaid, that is a good product and kitchen aid will stand by thier equipment.
Aug 07, 2010 | KitchenAid Dishwashers
Feb 04, 2010 | KitchenAid KUDR25 Dishwasher
Broken part, need model number
I found a website called Partselect.com and they have very good pictures of exactly the part I need. I ordered it from there.
Jan 01, 2010 | KitchenAid KUDP01DLBL Split-Control...
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Jul 14, 2009 | KitchenAid Dishwashers
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
354 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
