Question about U-Line Icemaker
I have a model wcm45a. Its amkes ice in the tray
I have a model wcm45a. Its makes ice in the tray but will not dump the ice.It appears to be a timing problem as the previous onwer had taken it a part and not assembled it back together. could you help me with information how to alighn and time properly.Thanks in advance John @ skwsteam@hotmail.com
  • 3,051 Answers
Hello there:
here i Doesn't Release the Ice Cubes:
  1. Some older design ice makers used flat clear PLASTIC ice cube tray that twisted to release cubes. If this is your design, the trays often can buildup with minerals from the water supply and eventually become sticky and fail to drop the cubes. To test you can remove the ice cubes stuck in the tray, then try spraying the tray with PAM or grease it with margarine and let it run a cycle, allow a few hours. If the new batch of cubes released from the tray, replace the tray.
  2. If they didn't then your problem is with the ice maker module, it may not be advancing.
  3. Other design ice makers use a small heating element to slightly preheat the ice cubes prior to sweeping them into the ice bin. These heating elements rarely fail; more often it is the thermostat or control module.I have a model wcm45a. Its amkes ice in the tray - meter.gif
  4. The ice maker mold thermostat could not switch the heater on, make sure that it's cycling properly.
s a general description on how this works and what to check when it does not work ok
Posted on Nov 16, 2009
Ice maker makes ice but does not dump
The mechanism (motor) in the tray housing is bad. Trying to manually turn the tray to dump the ice can actually do the harm to the motor. Not advised. You'll need to buy a new Tray Assembly.
Jan 07, 2015 | Samsung RS2534 Side by Side Refrigerator
My ice maker quit, was replaced with a new one, it filled and dumped one time, filled again, didn't dump, was thawed out then didn't fill at all. Water still dispenses from the door just fine.
If the unit is new return it for another one - if there is water in the tray and it is not dumping, either the unit is not working properly or the internal freezer temperature is not going down low enough for the unit to work. Has to go down to at least 10 degrees for the tray thermostat to start the ice dump/making cycle.
Nov 28, 2013 | Whirlpool Refrigerators
Ice maker not dumping ice.
sounds like the icemaker timing or motor is bad. those parts are not replaceable on this model, you would need a new icemaker assembly
May 02, 2012 | Samsung Refrigerators
Ice dispenser does not work unit makes ice and water works fine
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Its not producing ice anymore.
Sep 12, 2009 | LG LFX25960ST Stainless Steel French Door...
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice cubes form a mass that do not dispense
Sep 11, 2009 | Kenmore Refrigerators
Model 22 Icemaker is not making ice
The following assumes that the ice trays are properly filling with water. If not, check the water control valve.
Sep 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not dumping as frequently and cubes freezing one large chunk
The first thing I would check is the cleanliness of the condenser coil under the fridge. Make sure the fan under there is running, and that the coil is clear of dust. The ice maker requires 15 degrees for a period of time before it will make ice and dump. If the temp in the freezer is colder than this, then it is likely the ice maker needs replaced. They can be replaced fairly easily with just a couple tools. (1/4" nut driver and a flat screw driver). There is a plug where it plugs into the freezer side wall, and a bent tube that supplies water to the tray. If not sure what to do, have a service tech look at it.
May 27, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
U-Line Icemaker Logo
173 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
