Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Won't spin and drain - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • 1 more comment
  • claudiajperr Nov 16, 2009
    Already did - it was fine.
  • debuys1 May 11, 2010
    How do you get to the switch and change it out or bypass it?
  • matlock_mich May 11, 2010
    Check you lid switch.
    Novelist:
  • 120 Answers
Check the switch for the lid. the machine will not spin or drain if it thinks the lid is open. use a screwdriver or ink pen to push on the little lever. the lid has a small stick of some sort sticking out. the lever is in the hole that the stick normally goes into. the lever should click each time. if not, replace it. good luck
Posted on Nov 15, 2009
  • Scott Calfee Nov 16, 2009
    if your machine is washing the clothes just fine, then the problem is not the motor or the belt (if you have 1). the most likely suspect is that switch or something around it. 1 of the wires leading to it may be pulled off or broken. or the contacts inside the switch may be bad.
    i suggest pulling out that switch and jumping over it with a piece of wire. you could also just tie the ends of the connections together.
    if that doesn't fix it, then the problem must be within the timer mechanism. the switch is cheaper and easier to diagnose and fix. good luck
It was the lid switch. The two halves came apart which allowed the button not to engage when the door was closed. The plastic retaining pins that held it together broke. I just removed it and used a wire tie or zip strip to hold it together. Worked like a charm.
Posted on Dec 10, 2009
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Won,t spin
A LD (Long Drain) error code means that (more or less), the drain pump is failing.
May 11, 2012 | Bosch Washing Machines
Washer doesn't spin out sometimes
you say it drain, but sometimes it won't spin,this could be your filter if it is blocked these new machines can sence it and won't let the machine spin easyest thing check your filter,you never know might be that simple
May 07, 2012 | Washing Machines
Washing machine won't rinse and the water won't drain out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 04, 2011 | Washing Machines
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Wm2455hw will not spin
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Please reply with additional details for further assistance.
Shane
Apr 22, 2011 | Washing Machines
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
417 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
