Question about LG Vu CU920 Cellular Phone
I have 3 icons that came up at random over the 6 weeks I have had my phone....voicemail, task menu, and sound. I don't want any of them showing...what do I do?
How to turn off ringer at particular extension?
Do Not Disturb (DND)
When DND is enabled, the telephone will not ring when someone calls, but the line
indicator still flashes. In Personal Call Manager, the
You Have a New Call dialog box
still appears and the icon for the call appears in the Calls box.
You can turn the Do Not Disturb (DND) feature on or off from the
Calls menu or the Personal Call Manager icon in the task tray.
Turning DND on or off
To turn DND on or off:
1. Click the Personal Call Manager task tray icon or the
Calls menu.
2. Click the DND menu item.
When DND is on:
• the Personal Call Manager task tray icon changes to
• the symbol check
appears beside the DND menu item on the Calls menu and the
Personal Call Manager task tray menu
• DND appears in Status bar
Oct 23, 2013 | NorStar Meridian M7310 Phone
How do I set voicemail ringtone for Samsumg Galaxy S3
Click on phone icon, click menu > call settings > scroll down to voicemail settings select ringtone select the ringtone you want click OK
Nov 01, 2012 | Samsung Cell Phones
What my voicemail 4 digit passcodefor 2402620085
Your voicemail password is a 4 digit number that you enter when you want to listen to your voicemail messages from any other phone other than your mobile phone - this is called remote access. This voicemail password gives you the protection to know that only you can listen to your voicemails.
It is vital that your password is set to a random 4 digit password. To change your password, all you need to do is:
  1. Dial 173 from your mobile
  2. You will then be asked to pick a 4 digit number, and then press the # button
  3. If you are happy press press 2
Your password is all set up and you will be prompted to enter it whenever you want to listen to your voicemails through remote access.You will only need to use this password when accessing your voicemails from another phone. You will not need to use this password when accessing your voicemail from your own mobile phone - you simply dial 171 as normal
You can reset your voicemail pass code by dialing 611 or 1 800 331 0500
From the main menu, press3 (To get help with voicemail)
Press 2 to reset your voicemail pass word
Enter Billing Zip code
Customer will receive a text message to their wireless phone with their new voicemail password.
OR
You can log into your "My Account" from the www.cingular.com
From the My Phone page, click Reset Voice Mail Password.
Choose a wireless number from the dropdown menu and select Submit.
A text message is sent to the wireless phone with the new password.
Feb 24, 2012 | Cell Phones
I want to change to Thai language in nokia n95
Don't worry I know the best solution for your problem.I'm not going to get into detail about this.
Follow this step:
1. menu icon
2. tools icon
3.settings icon
4.phone icon
5.general
6.phone language
(choose your desire language)
If don't have English option try to ask the Nokia Care to install English version for your phone.
Hope this is in line with your problem.
(It work for most Nokia n series phone)
Best Regards
Ajay
Aug 30, 2011 | Nokia N95 Cellular Phone
I can't get rid of my voicemail icon on my Motorola Cliq. I don't have a voicemail.
Do backup your data and do a factory reset going to settings . That should fix it .
Aug 05, 2011 | Motorola Mobility CLIQ Cell Phone
I recently got a Samsung galaxy 551. I received a voicemail today and I do not know how to listen to it. Please help.
To access your Voicemail please follow these directions. This will get you to your message and provide you easy access to it in the future.
Instructions
  • Start at your home screen, tap the square with four little squares inside,
  • Scroll left or right through the appliactions and find one that says "Voicemail" (it should look like a green talk/speech bubble with a phone in it).
  • Press and hold the icon for Voicemail, drag the icon to the location you want. You can move an application icon to another main menu screen. You can also move most-used applications next to Home. And then press save!*
  • Tap the Voicemail icon and your message will be on the top screen.
Now you should be able to check your Voicemail at any time and know how to place an icon for convenience.
Hope this helped!
*Information found at:
Manual
Samsung website for visuals and specifications
Jun 17, 2011 | Samsung Cell Phones
How do I erase the voicemail icon on my SCH-0310
Access your voicemail probably you have a pending voice mail
View Voicemail Messages in the Inbox Folder 1. From the home screen, press the left soft key Menu. Press Messaging. 2. Press Voicemail. or... 3. Press and hold the Voicemail key located on the right side of the phone, to dial voicemail and retrieve your message(s).
You can download the manual here: http://downloadcenter.samsung.com/content/UM/201009/20100916023024187/u310-eum_F11_patent_fix.pdf
Mar 26, 2011 | Samsung SCH-U310 Knack Cell Phone
LG Vu voicemail icon will not leave screen
call your phone from another phone and leave yourself a new message, then go in and delete that message, it worked for me
Jul 24, 2009 | LG Vu CU920 Cellular Phone
Icons won't go away!! on my chocolate
I had this problem with my phone - ring it from another phone and leave yourself a message, then listen to the message and delete it and that clears it. It worked for me.
Nov 01, 2007 | LG KG800 Cellular Phone
Voicemail icon won't go away
hai... go to settings/intial setup/master reset/it ask security code type 000000 , it will get cleared
May 06, 2007 | Motorola Mobility RAZR V3
LG Vu CU920 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
