Question about Consew 199R-1A Sewing Machine
I need to re-time my 199R, the needle is hitting the sewing hook. i just can't get it right
    President:
  • 2,702 Answers
You need to adjust it for the free play as well,,,its a twiddle a bit at a time???
Posted on Nov 15, 2009
Needle hitting bobbin case
Try a brand new needle. Make sure it is the right needle for the machine and that it is installed correctly.
If the needle continues to hit the bobbin case, then there is a needle/hook timing issue. Take it for service.
May 16, 2016 | Sewing Machines
Tip
How to check if your sewing machine is in time.
Raise the presser foot, remove the bobbin case, remove the needle plate. Make certain your correct needle is installed right, with no thread in the needle, rotate the hand wheel until you see the needle at the very bottom of its travel. The hook should be just at the edge of the needle or a fraction from it. As the hook and the needle pass the needle has to start its travel up in order to create a hoop of thread for the hook to catch. If there is not enough travel for a sufficiant hoop to be made the machine may sew but would skip stitches or may not sew at all. If it hits it to late this can cause the hook to split the thread.
on May 23, 2010 | Baby Lock Imagine
How to correct timming on Bernina 930
Rare timing problems with the 930. I created this technical document for Bernina dealers in 1986. Hope this helps.
Also to check for the timing of loop lift, please see the enclosed photos. Note that the needle position is in the right hand position with the hook advancing so that the tip of the hook point is exactly flush with the right side of the needle. (Photos are showing the hook point for training purposes only). These observations and adjustments are always checked with the hand-wheel turned in the DOM (direction of motion). If loop lift timing is off as per the Tech sheet enclosed, the tool for correction is still available. http://www.sewtechnical.com/
Aug 26, 2015 | Bernina Sewing Machines
Adjust the timing on a singer confidence quilter 7469q
Hook/needle timing needs a hands on guidance to get it fix, 2 options either you can watch in utube 'singer sewing machine hook timing' or 'google' for singer 7469q service manual for your referral.
Nov 10, 2013 | Singer Confidence 7469 Mechanical Sewing...
How do I get Singer zigzag 457 to stop hitting the needle on the bobbin housing?
the sewing machine is out of time & needs to be retimed at a
sewing machine repair shop.
here's a link for a free manual
http://www.singerco.com/uploads/download/5d6ce627c00cb91c477d4703f1b704aab08a72c8.pdf
Sep 11, 2012 | Singer Sewing Machines
Thread breaking at needle
you need to adjust the tension on the bobbin
Apr 25, 2012 | Consew 199R-1A Sewing Machine
HI problem with Consew 199R-1A. Machine locked up. I just started sewing and it locked up. Needle is fine, fly wheel won't turn more then 1/4 back and forth
Good day!
that problem is usually happen when your machine have clog or no lubrication please try to use oil to lubricate your machine at all moving parts inside.
Thank you and good luck.
Jun 10, 2011 | Consew 199R-1A Sewing Machine
How to time the hook and needle?
Email me with your make again and I will attach timing instructions drivewithken@blueyonder.co.uk
Apr 08, 2010 | Consew 199R-2A Sewing Machine
Timing the needle
That isn't the timing. If the hook is hitting the needle the hook is too far left - or close to the needle. It's adjustable by loosening the set screw at the base of the hook and by gently tapping the hook away from the needle. You want the hook to be close enough to the needle to pick up the thread loop that's formed just as the needle bar is rising.
Aug 29, 2009 | Sewing Machines
Consew 199R-1A Sewing Machine Logo
151 people viewed this question
Top Consew Sewing Machines Experts
Michael Galve
Michael Galve
Oloyede Monsuru
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
