Question about Maytag MSD2756GES Side by Side Refrigerator
Freezer isn't working and refrigerator isn/t cooling. What is the problem? We can hear the fan running however.
  • matlock_mich May 11, 2010
    Is the back of the freezer all frosted up?
  • 161 Answers
My refridgerator is a Maytag side by side did the same thing checked the freezer compartment fan was working removed cover to look at the cooling coil, the coils were frozen solid ended up defrosting freezer compartment every other day. replaced the adaptive control board located in the refrigerator side top, haven't had another problem since.
Posted on Nov 15, 2009
GE fridge not cooling. freezer working ok. compressor fan not working
This is an odd thing to hear. Normally when the condensor fan (}compressor fan) Isn't running the freezer is the one who's temperature rises and the fridge stays about the same. I would strongly suggest looking at the main control board, just for the simple fact that 9 out of 10 times thats the root of the problem
Jun 06, 2012 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Whirlpool Wrn38rwg6 Freezer isn't freezing and I
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 16, 2011 | Whirlpool Refrigerators
I have a kenmore refrigerator side by side. my problem is that my freezer is not freezing the top where the ice is. everything was melting and defrosting inside the freezer except the lower part. i need to...
If lower section of the freezer is working but upper not the most likely problem is going be the fan in the freezer isn't running. Do you hear that fan running? if fan is not running it also wont circulate air into the fresh food(ref) compartment. If it isn't running you can possibly jump start it by removing back and flinging the fan blade with your finger to get it going till you can get replacement
Good luck,i hope this helps
Gene
Aug 01, 2011 | Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
Kenmore Elite 596.75523400, the refridgerator is working but the freezer isn't. The freezer defrosted but the freezer fan is working. Thanks
heatman101
May 07, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
My kenmore refrigerator model # 363.9771611 runs but is not cooling and the freezer is not freezing
Fan Problems
One of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food.
You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Other Causes
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Have a good day! : )
May 04, 2011 | Kenmore Refrigerators
The bottom freezer of my Kenmore Refrigerator works fine but the top refrigerator compartment no longer cools? Thanks
All the cooling happens in the freezer.The refer section relys on a fan to blow cool air into it.When you open the freezer you should hear a fan running.If you hear the fan running, close the freezer door and open the refer door. Look for the vent/area where the air comes in.Put your hand in front of it.If little or no air is coming out it could be a sign of an icing/defrost problem restricting the air to the refer section.
It will take a tech with the right tools to find the exact problem.
If the fan is not running you will have to unplug the unit and remove the back of the freezer section from the inside and make sure ice is not keeping it from turning.If it is free of ice then replace the fan motor.
Mar 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Side by side, refrigerator works, but freezer does not The freezer just started thawing everything. We can still hear something running in the refrigerator.
This is unusual. The more common set of circumstances is that the freezer works but the refrigerator doesn't. The cold air in a side-by-side is produced on the freezer side and is than transferred throughout the freezer and to the refrigerator by a fan in the freezer.
You say you hear something running in the refrigerator. This could be the freezer fan. It is located behind an access panel in the freezer. This fan should run.
You should also hear the compressor (underneath the refrigerator) running. If this doesn't run, you will not get cooling. Also, there should be a compressor fan (underneath the refrigerator close to the compressor) running. This fan removes heat from the refrigerant coils and transfers the heat to the outside. If this fan doesn't run, proper cooling cannot be obtained.
Check these things out.
Oct 20, 2009 | Refrigerators
Maytag MSD2756GES Side by Side Refrigerator Logo
502 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
