Question about Soyo SY-K7VME Motherboard
Pulled out power and reset wires. Power button not working. is th
Pulled power wires were can i find diagram?
    Guru:
  • 1,738 Answers
Do a online search for your motherboard company. and type diagram.
Posted on Nov 15, 2009
Need circuit diagram of power supply panasonic th-42px80b
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Power supply section schematics to many popular brand TVs are given.
Aug 05, 2014 | Televison & Video
Rodeo wiring diagram
The wire to the horn button is a live wire and it is shorted out when you press the button. This activates the relay and blows the horn. relays normally work by power coming to a terminal through the coil and out the other terminal to earth . This connects the coil and so the contacts are pulled together to allow power from the battery though to what ever is the relay for .. So what you need is power to a coil terminal on the relay and the horn wire connected to the other terminal. This will complete the circuit when you press the horn and the relay will close and the horn will blow.. To get this it may be necessary to piggy back off the power wire ( battery terminal on relay ) to a coil terminal .
Mar 31, 2014 | 2005 Holden Rodeo
I have a TH-42px600u & there is no power going to it, the power cord is working, but the Tv is getting now power. Is there a fuse I should replace or a reset button? Help PLXX!
Of Course there is a fuse at its main power regulator board. but, you must have sound knowledge in electronics, to replace it, especially to Plasma displays. If you wish to get more details, check the site linked here. If you have confidence, follow. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 14, 2013 | Panasonic TH-42PX600U 42 in. Plasma HDTV
Emachine w3107 wiring diagram
Good luck on finding a wiring diagram. Usually those plugs represent the Power Button, the Hard Drive and the other sometimes represents a reset button. If you remove the cover and sit the computer on it's side, take a flashlight so you can see inside at the motherboard. If you look from where the wires come from on the front they usually stick into little prongs on the side of the motherboard. The motherboard will have little written identifiers such as hdd for the hard drive light, pwr for power or power reset, fan for fan, etc.
Also sometimes if you look on the little piece at the end of the red, white and black wires where it plugs into the motherboard prongs, sometimes it will have writing on it as to which one it is.
Mar 24, 2012 | Computers & Internet
I have disconnected all th ewire from my motherboard and i have installed all wire but unable to connect pw button,reset button,HDD led wire and anothed LED wire please tell me how can i install them in...
Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.5 Connect the power cable to the back of your computer, and turn the computer on.
  • Oct 14, 2011 | ASUS P5PE-VM Motherboard
    You need to press the reset butten every 10 hours
    If you have to keep resetting it the thermostat maybe going bad. They are not to costly maybe around $15 dollars.
    Inspect the element's wiring and make sure that it look's intact and no burnt look to it. They can short out and trip the reset button also.
    Turn power off and disconnect the thermostat one wire at a time and reconnect to new one. You could draw yourself a diagram of th ewiring pattern to make sure you wire it back up correctly.
    May 15, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
    Have 88 f 150, turn the key and the pump in the gas tank has no noise. there are some pulled wires by the transfer case, broke by frame, that don't color code to anything. need a color code diagram of wire...
    the nain fuel pump power on mos fords was PINK or RED. But 1st check would be the anti-rollover switch (Usually up near the kickpanel). If that has tripped, pressing the reset button will restore power to the pump.
    Sep 11, 2009 | 1988 Ford F 150
    Panasonic TH-50PX60U no buttons working
    The software in the cpu of this set is damaged you must reload it to fix the problem..
    Dec 12, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
    Sub won't power up
    DVD reset procedure for TH-A10
    1. Make sure there is no Disc in the tray.
    2. Disconnect the power cord.
    3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
    4. Front display will show "TEST0".
    5. Then the display will change to : "TEST1 JC2".
    6. Press "Enter" button on the remote, display will show "EEPROM"
    7. Press "Power" to shut unit off.
    8. Reset is finished
    Nov 16, 2008 | JVC TH-A10 System
    Won't Turn On
    Try reseting the system. Instructions below.
    Jun 01, 2008 | JVC TH-A10 System
    Soyo SY-K7VME Motherboard Logo
    261 people viewed this question
    Top Soyo Computers & Internet Experts
    Roy May
    Matson Kurian
    Matson Kurian
    Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
