Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
I have a Bosch she44c dishwasher that I used just this morning. This afternoon I went to turn it on and a fuse in the panel box tripped. Is there something in the dishwasher that could go bad that quickly or is it most likely something else? Every time I reset the fuse and turned on the dishwasher, it tripped again. Leaving the dishwasher off, it doesn't trip.
    Novelist:
  • 154 Answers
In some cases, the heat element lining wears out and the element shorts out to the chasis of the dishwahser, thus tripping your fuse.
In other cases, the dishwaser leaks water, and shorts out an electrical component.
It is best to get a repairer to check this out for you.
Regards
Ash
Posted on Nov 15, 2009
Bosch dishwasher SHE44C does not heat water or dry dishes
have an electrician check the heater element
Oct 25, 2017 | Bosch Dishwashers
I think I need to check the water pump/motor on my Bosch SHU43C dishwasher. It seems the water enters at the start of the wash cycle but then there is silence through the remainder of the cycles. Water...
Read this page, it may be helpful to you
http://www.repairclinic.com/0088_9_1.asp
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Aug 03, 2008 | Bosch Dishwashers
Bosch SRS53C02GB/27 tripped circuit fuse, Changed plug fuse still no sign of life
Has the circuit breaker / fuse in the meter box tripped or blown as well? If the machine tripped or blew a fuse, it is common for the heater element to be the cause or you have a water leak internally and its shorted something.
Mar 01, 2015 | Bosch Dishwashers
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
Replaced the control board in Bosch Dish Washer SHE44C and the cycle times are reversed???
I think this board requires coding to your particular model?? your dishwasher has four selection button and a delay start, whereas the module has five selections and delay as it is used in several different modesl. The coding info should have been in the box with the part and may need to be carried out directly on the module with the fascia panel removed. If you post the part number of the module I will see if I can get you the coding information..
Mar 01, 2013 | Bosch Dishwashers
How do you take the control panel out of a Bosch dishwasher model# she44c. I have read other consumers and I have the problem that the solder joint may have come loose. The dishwasher stays on one after...
Hello Steve,
Welcome to FixYa.
If you email me at macmarkus@live.ca my windows live account I will send you an official B/S/H/ ( Bosch ) service manual that should explain fully & completely how to not only take it appart, but how to repair it as well.
Let me know if you want to receive this info or not either here or via email.
To provide the info it must be through email as the adobe files are too large to post here.
I`ll watch for your reply.
Regards,
macmarkus :)
Sep 18, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch 24 in. SHE44C05UC pops breaker
We just had a potentially dangerous problem with the same model. Only we found the wiring beneath the front door were fried. How do yours look?
Dec 31, 2009 | Bosch 24 in. SHE44C05UC Stainless Steel...
Our Bosch dishwasher will not turn on. It appears to have stopped in mid-cycle - there is water below the dish rack. The circuit breaker on the main electric panel was not tripped. Thanks, Paul
check the dishwasher electrical box connection. remove kickplate. box is on r/h side. remove cover. you will probably find the wires and marettes burnt. simply repair the wires. this happens from time to time if the connection is not the best. hope that helped
Aug 18, 2009 | Bosch SHV68 Built-in Dishwasher
Bosch exxcel
The likely cause of this is a failed heater element which would cause the fuse to blow. You will need to get the heater element checked out and replaced if necessary. A visual inspection of the element may reveal the problem jf not an electrical test will be necessary. Be sure to switch off the power before touching the heater element.
Oct 20, 2008 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Bosch 5315 dishwasher
A fuse may have blown or a circuit breaker tripped. Replace fuse or reset circuit breaker at your fuse box/breaker box windman
Jan 30, 2006 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
620 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
