Question about Sport & Outdoor - Others
I need a manual for a Microplus 600 Galaxy Cabin Cruiser please .
Bayliner boat cabin cruiser 1986 26 ft with gm motor and volvo penta carburator Need owners manual
What engine? 4cyl, 6 cyl, 8 cyl? 2.1 2.3 2.5 3.0 3.8 4.3 5.0 5.7 7.4liter?
Jul 31, 2017 | Volvo Boating
Where is the cabin filter on a 2004 PT Cruiser?
Hi there, yes they do have a cabin filter, it located under the bonnet on the passenger side. You will need to remove the cowling on the left side, then just loosen the 3 boots holding the washer tank but don't remove them, you can then pull it forward a it and expose the housing for the filter, push the clips out of the housing and pull it strate up, then remove the old filter and replace it with the new 1. Note on the bottom of the housing you pulled up has 2 tabs on it, make sure they are located and just reverse your process and put it back together, hope this helps
Feb 18, 2015 | 2004 Chrysler PT Cruiser
How to pair the samsung galaxy s4 to the jabra cruiser
  • Touch Apps
  • 2.Scroll to and touch Settings
  • 3.Ensure Bluetooth is turned on
  • 4.Touch Bluetooth
  • 5.Slide the Power switch to turn the JABRA CRUISER on
  • 6.Press and hold the Multifunction button until you have a rapid flashing blue LED
  • 7.Touch the JABRA CRUISER in the list of devices
  • 8.The JABRA CRUISER is now paired
  • 9.The JABRA CRUISER and Galaxy S4 are now ready to be used
  • 10.Press the FM button in order to start streaming audio via the FM transmitter. The FM LED will turn red
Oct 01, 2014 | Jabra Cruiser InCar Speakerphone Black
Pt cruiser no air blowing
Blower motor, and maybe ur filters under the black price that's under ur w. Shield wipers. Clogged heater core. Just suggestions
Jul 08, 2012 | 2001 Chrysler PT Cruiser
How to install cabin filter in a 2004 pt cruiser
http://www.mooresmopars.com/GT-Cruiser/Cabin-Air-Filter/ From what I read the cars here came with out filter housing. Look at yours and see if you need the housing and the filter or just the filter. On the net it says some tractor Briggs and Stratton filters fit and half the cost
Nov 29, 2011 | Chrysler Cars & Trucks
Where is cabin air filter in 2007 land cruiser?
Land Cruiser 2007 air filter is not located behind the glove box. I removed the glove box and didn't see anything behind it. Does anyone who posts the answer here really changed the cabin air filter for the 2007 land cruiser?
Nov 07, 2010 | 2007 Toyota Land Cruiser
Where is the cabin filter on a 2004 pt cruiser
it is in the pass side cowl grille. You have to remove the cowl that covers the wiper linkage, and it on the pass side.
Jul 09, 2009 | 2004 Chrysler PT Cruiser
Sport & Outdoor - Others Logo
151 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
