Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Lamp replacement i was wondering if i can just replace the bulb,rather than replacing the whole light housing.if i can what is the process on doing so and what would the part number be for the new bulb.thanks
  • jonnyk Mar 03, 2008
    thanks
    Novelist:
    Scholar:
  • 96 Answers
Well I don't know if I should be answer this question, it's going to cost you,
Oh heck there you go , of course you can, it is so easy, even my two year old can do it.
Here something you should know first, don't tough the bulb, do you know what I'm saying don't touch it,
Make shure that both fan's or working, this is one issue that if the fan is burt out, the bulb won't last, the second problem when bulb burn's out is bad ballace, because of bad cap and diode inside, but don't worry about that,
Here is the info on other adjustment you can do but don't read to mutch, you'll get lost thttp://service.panasonic.ca/pdp/ServiceManuals/pt50-60dl54-sm.pdf
Mmmmm did I mention your welcome
What about Bob
Posted on Mar 01, 2008
How to replace a front head lamp
just the bulb
or the whole deal, the whole assembly,
the bulb is covered in all cars. in the glove box opr guide.
all.
the fsm covers both in the FSM ZJ
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
posted over 100 times.
Apr 08, 2015 | 1997 Jeep Grand Cherokee
How do i replace head lamp on kizashi?
the bulb or the the whole housing/????????
read the manual at
$4
https://suzukipitstopplus.com/Products/10243-2011-kizashi-service-manual.aspx
the glove box.
open the door
extract the oper guide
turn to head light page, bingo?
Sep 02, 2014 | 2011 Suzuki Kizashi
Wondering how to change the third brake light (one located in back window) on a 2006 hyundai sonata
High Mounted Stop Lamp Removal & Installation To Remove:
  1. Disconnect battery negative cable.
  2. Disconnect high mounted stop lamp electrical connector from inside trunk.
  3. Remove package tray.
  4. Replace bulb from package tray.
To Install:
  1. Install package tray.
  2. Connect high mounted stop lamp electrical connector from inside trunk.
  3. Connect battery negative cable.
Oct 12, 2010 | 2006 Hyundai Sonata
Replace 3rd eye brake light bulb is out. do i have to replace the whole housing? or just the bulb?
If they are led lights the whole housing needs replaced.If it is not led lights then just the replacing the bulbs are fine.
Jul 20, 2010 | 2002 Chevrolet TrailBlazer
Replacing Headlight lamps
you are just replacing bulbs not the whole lamp i presume. The bulbs are held in by a ring that turns about a quarter turn counter clockwise to release. Then the bulb will pull out of the lamp housing. Some cars do not give room to do this and you will have to remove objects in the way or take headlamp out of car to achieve
Apr 24, 2010 | 2001 Toyota 4Runner
How do i get lamp out off housing
lamp and housing are sold as one unit..remove screws and replace whole assembly.lamp is made of quartz.handling bulb will shorten life of silver halide bulb.bulbs wires are usually connected with screws if replaceable or could be crimped on.too hot to be soldered on
Feb 18, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Replaced lamp housing(bulb). Now having trouble
replace the colorwheel. if the colorwheel doesn't spin or spin properly, the lamp won't light. if the colorwheel is ok, you have a ballast problem.
Dec 30, 2009 | InFocus ScreenPlay 4805 Multimedia...
How do I replace the lamp? Do I need just the bulb, or also the housing?
just the bulb.. write down the model number of the unit and they will give you the same bulb that you need, just give them the model number.
If you are going to install the bulb just remember DO NOT HOLD directly the bulb, use any clothe or gloves, because even a fingerprint can busted the bulb even thou it's not yet use
Nov 08, 2009 | Sony XL-2100U Projector Lamp for...
How do you remove the head lamp assembly on a 1993
1. Make sure headlamp is off and open hood.
2. Taurus model years 1990-1999: you must remove the whole headlamp to replace the bulb. Not a horrible task. Just annoying.
3. Facing the driver's side headlamp, and looking at the headlamp itself, at clock positions 8, 11 and 1 are the headlight housing screws. They all look the same. Using a 10mm socket wrench, remove these 3 screws and set them aside.
4. Just to the right of the "11 o'clock" housing screw is a bolt (same hexagonal 10mm sized top as the housing screws). This just needs a few turns to loosen it.
5. Gently pull the whole headlight forward. Now you can get at the bulb.
6. Disconnect the electrical connector from the bulb. Now the headlamp is free to work with. Remove the bulb, replace with a new bulb, make sure the bulb housing cylinder is in place and reconnect the electical.
7. Place headlamp back into position. Line up screw holes. Tighten the bolt. Replace housing screws and tighten.
8. Passenger side headlamp is mirror image of driver's side. Screws at 11, 1 and 4 o'clock positions. Bolt should be to the left of the "1 o'clock" housing screw.
Oct 12, 2009 | 1993 Ford Taurus
Is the color wheel fine if it is spinning? Can you see any light from the dlp lamp when the screen is off? I had a service guy come by to fix my dlp and he replaced the bulb with no luck. He said it was...
First You can look on the rear of the set and see the lamp light shine through the lamp door vents when the set is on. Second you need to replace the whole color wheel before the set will work. Third Color wheels may spin but not at the correct rpm and may shut down the tv and sometimes color wheels will emit a high pitched whine or buzzing sound indicating that the bearings in the motor are wearing out. But now that you have to replace the color wheel you will need to adjust the index delay in the service menu. I suggest having a factory trained tech repair the set.
Jul 10, 2009 | Televison & Video
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
