Question about Kenmore 98702 Stacked Washer/Dryer
I need to locate a manual for a Kenmore #417-97662790. Need to replace the washer timer switch and need directions for disassembly, removal & replacement.
SOURCE: Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Posted on Jun 25, 2008
duby1990
  • 367 Answers
SOURCE: Won't spin or agitate - will pump water water out
This is caused by either a bad door switch or a speed control unit. There is no way to test the door switch but it is the cheapest to replace. Try that first then the speed control. The door lock switch hopefully does it. (even if it locks it can still be bad there is another switch inside.)
Posted on Nov 18, 2008
RescueTech
  • 145 Answers
SOURCE: Kenmore washer 60 series
Hi, thanks for using the FixYa service. Your lid switch is probably broken. Make sure you can hear it click when you open and close the lid. It it is a very common problem on that model. Probably has nothing to do with the pillows, that was just the last load in the machine before the common part failure. Get me the exact model number and I can get you the replacement part number.
Posted on Dec 19, 2008
jsrock516
  • 5911 Answers
SOURCE: Disassemble Washer
Here ya go. Follow the steps provided in this link:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
The mixing valve is also know as a "fill valve" or "water inlet valve", just for clarification. I hope these steps help you with completing your repairs. If you get confused along the way, or require additional assistance, please let me know.
Posted on Dec 22, 2008
jyackle5
  • 8197 Answers
SOURCE: Need replacement coupling for Kenmore Washer
Go to a sears service senter and they can order one for you
Posted on Jan 22, 2009
Whdre526e1ww
follow this steps and fix it. God bless you
Lid Switch
This is the most common reason for the washer not spinning or agitating. This is easy to check. You will need to remove the switch, this varies with model type but the testing will be the same. When the lid is closed the switch should have continuity when the lid is opend the switch should have no continuity. If it differs replace the LID switch
Timer
To check the timer you will need to refer to the wiring diagram or disassemble to access the motor. Check the leads from the timer to the motor when turned to a wash cycle this should have 120 volts. If not replace the timer if it does the timer is not the problem.
Motor
To check the motor you will need to disassemble the washer to access the motor. First you can check the motor windings, to do this remove the plug and connect ohmeter to terminals. Refer to the tech sheet or service manual for the proper reading. Check motor for shorts by connecting ohmeter to terminals and motor housing should have no continuity. Connect voltmeter to motor wire connector and check for voltage. You should have 120 volts, if you do and the motor does not run replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of motor coupler
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Jul 09, 2013 | GE WBSR3140DW Top Load Washer
My kenmore frontloader does everything but spin.it worked fine for 8 months.
see this causes and fix it. God bless you
Water Level Control / Pressure Switch
his is the most common reason a washer will agitate but not spin. To check this on most , with no water you should have continuity on pins 7&15. With the tub full 7&16 should have continuity. This video walks you thru checking another type of switch.
Lid Switch
This can be the problem for the washer not spinning . Most whirlpool styles this will effect both agitate and spin but some models will still agitate but not spin.This is easy to check. You will need to remove the switch, this varies with model type but the testing will be the same. When the lid is closed the switch should have continuity when the lid is opend the switch should have no continuity. If it differs replace the Lid Switch.
Timer
To check the timer you will need to refer to the wiring diagram or disassemble to access the motor. Check the leads from the timer to the motor when turned to a wash cycle this should have 120 volts. If not replace the Timer, if it does the timer is not the problem.
Motor
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to thetransmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise theproblem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Oct 11, 2012 | Washing Machines
Washer doesn't rinse and spin
Lid Switch
This is the most common reason for the washer not spinning or agitating. This is easy to check. You will need to remove the switch, this varies with model type but the testing will be the same. When the lid is closed the switch should have continuity when the lid is opend the switch should have no continuity. If it differs replace the Lid Switch.
Timer
Motor
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
Sep 28, 2012 | Fisher and Paykel Washing Machines
GWL15 Fisher & Paykel washer doesn't rinse and spin
see this causes and fix it.God bless you
Lid Switch
Timer
Motor
Belt
Motor Coupler
Transmission
Sep 28, 2012 | Fisher Paykel EcoSmart GWL15
Will not cycle has nd error code
see this cause and fix it. God bless you
Lid Switch
Timer
Motor
Belt
Motor Coupler
Transmission
Sep 26, 2012 | Samsung WF330ANW Washer
Kenmore 2708 washer has a rubbing noise during spin
Level
If it is shaking and not sitting flat ( should have no rock corner to corner) check the leveling legs. Make sure to tighten up the locknut after adjusting.
Timer
Sometimes a Timer will start making noises before they fail. I would highly suggest replacing the timer as soon as the noise develops. This can cause problems with your motor and other components if left alone. This is easy to identify just listen up near the console when running.
Transmission
The transmission does not usually fail but to check this on a direct drive remove the motor and rotate the inner tub and listen for noises it should be quiet. If not the transmission is expensive and you will need to evaluate wether it is worth repairing.
Motor Coupler
On direct drive machines this is a common failure and can be very noisy. To check and replace the motor coupler watch the video.
Motor
You will need to disassemble the washer to listen to the motor running. If the motor is noisy it will need replacing. On direct drive models check the motor coupler first.
Suspension Rods
The Suspension Rods support the tub under the cabinet on some models. The washer must be disassembled to access. These usually do not fail. On direct drive types there will be springs instead of suspension rods. Either usually fails but can from being overloaded.
Drain Pump
The drain pump can be the cause of noise. On belt drive types remove the belt and rotate the pump pulley it should spin freely and make no noise. If it is noisy replace. If it does not spin freely remove and inspect for obstructions if none found replace the pump. Check the impeller on the pump it should be tight and spin freely. On direct drive types remove the pump and inspect or replace.
Sep 25, 2012 | Kenmore Oasis HE 27082 Top Load Washer
My washer fills and rinse cycle works but does not spin or agitate. Should I replace the control box?
see the causes and use the common sense. God bless you
Lid Switch
Timer
Motor
Belt
Motor Coupler
Transmission
Sep 19, 2012 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Estate washer refills after final spin
please follow the next step and use the common sense: God bless you
Lid Switch
Timer
Motor
Belt
Motor Coupler
Transmission
Aug 02, 2012 | Washing Machines
I have a Kenmore 800 washer Model #11029822800. It won't agitate or spin. I was told it may be a COUPLER, but i'm trying to get a repair manual or something that shows me how to take it apart
see the next step and use the common sense: God bless you
Lid Switch
Timer
Motor
Belt
Motor Coupler
Transmission
Aug 01, 2012 | Washing Machines
My GE whdsr316g1ww will freezes during the 'Cottons' cycle
please see the next step and use the common sense: God bless you
Lid Switch
Timer
Motor
Belt
Motor Coupler
Transmission
Aug 01, 2012 | GE WBSR3140DW Top Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
