Question about Sony PlayStation 2 (PS2) Console
The piece the cd spins on will not come off - Sony PlayStation 2 (PS2) Console
Sony cfd-z110 cd seems to not spin/play when door/lid is closed but will play when lid is open and lid switch is depressed, is there any thing (maintence) that needs done on that round piece (that is...
your on the right track. the piece on top should spin really freely. there is a spring inside of that piece. if it lost its track it will lock it up from spinning. one other think it maybe is the tab is broken that presses the switch down. inspect both things if it ends up being the tab missing you can simple hot glue the switch down or dissemble and twists the two wires together (ones at the switch) that will bypass the switch. beware if you do this the laser will be active every time you have it in cd mode. (don't look at the laser it can harm your eyes) hope this helps please rate me.
Dec 31, 2010 | Sony ZS-S2IP Radio Boombox
Odd scratching or grinding noise
HI,
Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.Also check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
These are the only possible home remedies if you still face the problem then you will have to get it repaired.
Oct 17, 2008 | Sony MHC-GX250 CD Shelf System
I load the CD put I don't hear it spinning at all
No it isn't, because your switch isn't tripping when you close the DVD. Try holding the lid down with your hand and listen for spin. If your DVD starts spinning you will need to locate the plastic pin protruding from your lid and extend it with superglue and a piece of cardboard. This will make up for the warp in your lid, and allow the switch to close.
Mar 09, 2010 | Mintek MDP-1810 Portable DVD Player
My girls princess disney cd player keeps saying that there is no cd in the player. I have no idea what's wrong with it.
the laser lens is most likely dirty, buy a cleaning disk, or use a microfiber cloth or eyeglasses cleaning cloth and gently wipe the lens in one direction to clean it. the lens will look like a small round clear piece of glass near the motor that spins the cd, if this doesnt work, then the laser has quit working
Jan 14, 2010 | Disney Princess Portable CD Player...
Dvd drive no workin
yep anyone will work today!
Sometimes the motor barring needs greased located at the center tp side where the disk sanswich is located 3 small very small cres then the center piece lifs exposin a nice shinny ball like surface this need a small amount of lub. CD has to spin to be read and has to spin at a particular speed a little drag will slow it down and sometime wabble the cd and it will be damaged hitting the edges of the draw as it is spinning.
Jul 27, 2009 | HP 530i (Q6750A) DVD±RW Dual Layer...
A cd broke in my cd rom
I've seen and come across cd-roms where cd's have broken (or in most cases exploded/shattered). In one case the drive flew open and bits of cd flew across a classroom, in most cases the drive remains shut (even the tray can get jammed).
This problem is usually caused by a flaw on the cd itself, a scratch or mark on the cd causes it to 'wobble' and due to the speeds cd-roms spin cd's they come off the 'spindle' inside (all that holds it on is a magnet).
I have taken cd-roms apart and removed all the cd parts and the drive has worked perfectly afterwards. Other times the drive has needed to be replaced, so i would say its purely luck if your drive isn't damaged in some way.
Although the problem could have been your drive. Without being able to get the drive ejecting and spinning cd's again you'll never know... just make sure you don't use an important cd to test it with!
Dec 27, 2008 | E-Machines emachines (emachinees) CD-ROM...
My cd player on the Sony HCD-G101 rotates the discs but ...
i had the same problem after i moved and everything ran but when i put in a cd the disc would spin for awhile then change to the next disc and just kept spinning and moving from one disc to the other none stop. so i opened mine up turns out during the move there is a small black plastic piece that sits on top of the laser in the middle it shifted during the move making it block the view of the disc. you will have to carefully remove the plastic piece from the top of the laser with out touching the laser lens and that fixed mine good as new. my problem is i need the remote code movers lost my remote and can't find the code to use the replacement i bought. Hope it helps if this is the same problem i had should work. i tried to move the black piece back into place but it just did not go back right to just removed it all together. they did not use anything to really hold it into place to avoid slipping.
Dec 15, 2008 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Disk wont spin?
If its still under warranty, and the seal hasn't been cracked, contact Microsoft.
Try what hijackthis1 suggested, if that doesn't fix it, try this.
Since you have the 360 apart, and the top cover off of the dvd drive, here we go...
There's a circular cut-out that's glued to the top cover that you removed from the dvd drive, right below the sticker with all of the drive information. I was able to pop out the cut-out. After that you now have (3) pieces in your hand, the cover, cut-out, and a plastic piece.
Connected the dvd drive back in the 360 with the top cover off.
Put a game or movie in the drive, don't hit the eject botton, just put the disc in the tray.
Now with the disc in the tray, put the plastic piece in the center of the disc. Its magnetic, so it should kind of lock in to place.
Connect the power/av cords in the 360 and turn her on.
You should see the disc try to spin. (It may spin once or a couple times around, but it will stop). When you see the disc start to spin, GENTLE, spin/turn the disc in the direction in wants to go. It should load the game or dvd with no problems.
Reassemble the cover and put back on the dvd drive.
Now use the eject botton, and try games and dvds.
If disc fails to spin, do process over again.
I've done this with one of my 360's with no problems.
The drive I used was an Hitachi 0059DJ.
Dec 24, 2007 | Microsoft Xbox 360 Console
Xbox 360 problems
If its still under warranty, and the seal hasn't been cracked, contact Microsoft1.gif.
Since you have the 360 apart, and the top cover off of the dvd4.gif drive, here we go...
Now use the eject botton, and try games and dvds4.gif.
CD's won't play
I know that Panasonic provides chips, optics (laser),etc. to Emerson. I am familiar with the problem you've experienced because I've had a Panasonic CD Player. If the disc doesn't spin (as you said), the problem must be that your shelf system probably has an optical problem (laser problem/pickup problem) and will need to be serviced.
Apr 22, 2007 | Emerson MS3103 Shelf System
Sony PlayStation 2 (PS2) Console Logo
13 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
