Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
The black has turned whit in some spots due to an over heated pot
Why is stove top displaying symbols not recognizing pots? Had stove 6 weeks, pots are correct and been used on this stove. Displaying on all 3 cooking areas.Can I correct it or is it faulty?
lets review this
please advise readers
maker of cook top so they can find the user manual
model or how old helps also
its not a gas cook top
you have the right type of designed pots for that cook top
but you get no heat radiating to the pot base
when pot is in contact with the heat area
Aug 17, 2016 | Cooktops
Schott ceran. Why do the individual rings spontaneously lose heat or go off?
most likely it is your pots and pans . do a magnet test on the bottom of each one . if a magnet will stick it should be OK if not , do not use on your unit .but they are supposed to turn on and off as heat is needed . not stay on full time as in the old days
Aug 25, 2015 | Miele Cooktops
We have a CCE3401 Jenn-Aire Ceramic Cooktop. I was making jelly this week when I had a bad boil over. We used recommended products to clean up. It has left a black smooth spot above front left range...
Sorry to read about your problem, I hope this helps you out.
try using an oven cleaner spray... let the range heat up a little..then spray oven cleaner
a new glass top will cost over $600.00 just for the glass.
I have tried to help you. Please help me by vote/rate the response. Thanks If you live in the Denver Area. I can help you out.
Dec 15, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Little iridescent spot after cooking
It's just normal wear and tear, you can use any type of cookware.
Apr 11, 2010 | Jenn-Air JED8430 Electric Cooktop
Pot stuck to cooktop
Did you find that it was stuck after it had cooled off? A vacuum was probably created between the pot and the glass top. You could try twisting the pot, leaving it for a while, or heating it up again.
Apr 11, 2010 | GE Profile JP930 Electric Cooktop
Whenever I cook cream soups in my stainless steel pots, they burn on the bottom. I watch them very closely and just have the heat on medium, but they always seem to burn. I recently bought a glass pot to...
I'm assuming this is an electric stove, since that's what the picure shows. Most electric stoves turn the heating element on and off to regulate the temperature. On high the element is on almost all the time, on low it's off most of the time. The problem is that when it's on, it's on at full power, and sometimes this is enough to scorch things like milk based creme soups.
You can do two things:
First, try using a double boiler. This will put water in the lower pan and help keep the heat lower than with a regular pan. You could also try to find a pan with a very thick bottom, and try that. It might work better.
Sep 13, 2009 | Frigidaire 31 in. GLEC30S8 Electric...
Repair large chips to white enamel on stove top.
Get some glass enamel powder the same colour of course...I got it off ebay.or go here.www.find-a-fix.com/
Aug 29, 2009 | Cooktops
Gas hob turning bottom of pots black..not sure if the hob is installed properly
if the hob is turning the pots black the cooker needs a good cleaning they have air ports in the burner assembly they could be blocked or the incoming gas preasure to too high and needs to be checked by a gas engineer
Aug 19, 2009 | Cooktops
Black spot on glasstop Kenmore stove
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jul 23, 2009 | Cooktops
Heat too hot on LO simmer burner
take the knob off, and take a very small flat screw driver, and inside the valve, turn it to the left, go slow, and you'll see that it goes down, there ya go
Jan 13, 2008 | Maytag MGC5430 Gas Cooktop
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
