Question about Acer Aspire 5500 5570-2609 Laptop
Will not come back on after power connected - Acer Aspire 5500 5570-2609 Laptop
When I plug into the back of printer the power light does not come on unless I jiggle the connection?
Sounds like a poor connection. If it's still under warranty take it back! I got a free replacement printer after the paper feed disintegrated.
Mar 04, 2015 | Lexmark Interpret S405 Wireless All-in-One...
Tip
How to repair Computer Fan
<p>1. Remove the mini-tower computer cord and unplug the power. Disconnect the cable from the back of the computer for a note in which they were set to be fast to restore.<br /> <p><br /> <p>2. Unplug the connector on the back of the computer. Tighten the screws on the back of the computer, back up the side with a screwdriver. Slide the computer case and put it out of your way.<br /> <p><br /> <p>3. Locate the fan in the box near the back and then connect the power cord where it is on the motherboard. Unplug the fan motherboard manual. Remove the four screws holding the fan on the bottom of the box with a screwdriver to secure.<br /> <p><br /> <p>4. Remove the PC case fan and set aside. Turn the fan of the new mini-tower in the back of the cabinet with screws and plugs wire connector on the motherboard.<br /> <p><br /> <p>5. Place the rear plate side of the computer and secure it with screws. Connect the power cord to power on the back of the case and connect the cable to the computer case.<br /> <p><br /> <p>6. Connect the power cable from the mini-tower outlet and turn on the computer.<br />
on Jun 21, 2011 | Computers & Internet
Came home to find it off, tried to power up, fan runs 3 seconds, no power light, then off
Try first to unplug the power cord at the back of the CPU then press the power button for 5 seconds while the power cord is unplug. This will clear the remain power from the capacitors on the power supply. Once done, re-connect the power and try to power the computer back on.
If still not, then this is a power supply issue. What you can do is to open the case, make sure power cord is not connected and you have done the above step again to ensure that there is no electric current remaining. Once done, trace the connection from the power supply connecting to the motherboard and unplug it. Please check for the lock clipping it from the motherboard. once removed, again press the power button for 3 seconds. Then reconnect everything and power the computer back on.
If still not, then this is really a power supply issue and it should be replaced.
Thanks,
~jash
Aug 09, 2011 | eMachines ET1641-02w (PT.NA60X.001) PC...
Hi, my router won't le tme connect to the internet. I have unplugged it, waited a few minutes and then plugged it back in. Re-booted it, and still no connections. Any suggestions?
you probably need to unplug power on your router too.
Unplug both power plugs and wait 20 seconds. Then plug back power to your MODEM FIRST.
Wait 1 minute to make sure the connection get an ip address.
After that, put the power back to your router.
Wait 20 seconds and try the connection with your computer.
If it doesn't work, restart your computer.
Hope this helps!
Feb 21, 2011 | D-Link DIR601 WirelessN 150 Home Router...
I'm having trouble connecting my emachine to a cable modem.
Turn off the computer before you begin making connections. Make sure the cable modem is up and running with your service before you attempt to make the computer connection.
  • 2 Connect the coaxial cable from the wall outlet into the back of the cable modem where it is marked "Cable" and has the male coaxial connection. Use an extension coaxial cable if necessary to reach the modem.
  • 3 Connect the CAT 5 networking cable from the cable modem where it is marked "PC" (or something similar) and connect the other end into the back of your computer where the networking card is. These connections are RJ-45 connections that look like oversized telephone jacks. If you also have telephone service through your cable provider, you will want to connect the telephone line into the port on the back of the cable modem marked "Telephone."
  • 4 Connect the power cord into the back of the cable modem and plug it into a power strip with power surge protection. The modem should power on by itself once it is plugged in. It will cycle through a power on self test and then make the connection to your cable Internet provider. Once the lights indicating power and cable are green, you are ready for Step 5. It could take several minutes for the modem to connect to your service provider.
  • 5 Turn on the computer and test out your Internet connection. Should your computer still have a problem connecting to the web you may need to reset your cable modem. You will find a small recessed button the size of the head of a ballpoint pen either on the back or front of the modem. This button will be marked "Reset." Pushing it once will allow the modem to reboot and reset all its connections. Turn off the computer before resetting the modem to allow the computer to flush all the networking connections out of its memory as well.
  • If the power goes out and your connection is not restored when it comes back on, always reboot the devices in this order: cable modem first, computer second. Keep the cable modem where it can get proper ventilation. Call your cable Internet provider if you get frequent interruptions to your cable Internet service and rebooting the modem does not solve the problem.
    Jan 21, 2011 | E-Machines eMachines Desktop PC
    My xbox is giving me 3 red rings which should mean that there is a connection or hook up problem ive gotten it to work after this once but there were no connection problems then after not playing it for a...
    Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
    1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    2. Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
    3. Make sure that all three connections are firmly secured.
    4. Turn your console back on.
    5. Check the light on the power supply. If this solution worked, your power supply light will be green....
    Dec 23, 2010 | Microsoft Xbox 360 Console
    Wireless connectivity suddenly lost
    Have you tried power cycling the router and the modem? if not:
    1. Turn off your modem and router by unplugging the power cord at the back of the devices.
    2. Disconnect the Ethernet cable from the modem to the router vice versa
    3. After a minute, replug the power cord at the back of your modem then reconnect the ethernet cable at the back of the modem as well.
    4. After a minute, replug the power cord and the ethernet cable at the back of your router.
    5. Try to test the connection.
    Warning: You can reset the router if you know that you can reconfigure it back to connect to the internet. If you don't know how to set the router back to connect to the internet, it would be ok to you to not to do step 6.
    6. If it didn't work, You can reset the modem. Press the reset button at the back of your router while it's turned on, wait for 15 seconds after that, unplug the power cord at the back of the router while the reset button is still pressed, wait for 15 seconds after that, replug the power cord at the back of your router while the reset button is still pressed, wait for 15 seconds again then release the reset button after 15 seconds.
    7. Reconfigure your router's settings to communicate to your modem. ( I don't know if you have cable internet connection, but if so, you can just clone the mac address of your modem to connect to the server, if you are using DSL if it's asking for a username and passowrd, just use the PPPoE type of configuration in your router)
    8. If it failed, try to update the firmware of your router.
    Jan 14, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
    I have a belkin N wireless router,got it 15days back.few days back its not showing any connection waht might the problems,tried connecting it to different power plugs.
    The unit maybe faulty. Connecting different power plugs (adapters) may cause the Belkin to fail if the power adapters are not the correct voltage and polarity.
    Dec 26, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
    Internet Explorer cannot display the web page
    Hi there.
    You need to reset the the wireless router and the modem, to do this just pull the power from the back of them for 2 minutes, don't power them off from the wall.
    After the 2 minutes is up plug the power back in and wait for another 2 minutes for them go through the boot procedure. After that try to connect again.
    If it still doesn't connect post back.
    Good luck and thanks for choosing FixYa!!
    May 30, 2009 | Microsoft Windows XP Home Edition for PC
    Nothing on the screen after power on
    Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
    Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
    Acer Aspire 5500 5570-2609 Laptop Logo
    21 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Steve Sweetleaf
    Steve Sweetleaf
