Question about HP LaserJet 2840 Printer
HP 2840 color laser prints color banding on all sheets
I have a HP 2840 color laser, when pages come out of the printer there is a banding of the different color cartridges, never black but more yellow and magenta than cyan. There are lots of lines, the thickness of the lines appear about as thick as a pencil, at the top of the page and as you go down the page the lines start to disappear. From what I can tell this looks like it started about the time a new image drum was placed in the printer. I have looked at the image drum and can not find any toner on that part. I have printed a supplies status page and it shows that the black has 99% left, Cyan has 8% left, magenta has 8% left and yellow has 64% left.This will happen on just pages printed in black or pages printed in color
Thanks
Jack
Mix-it-up
  • 832 Answers
SOURCE: Brother Printer Cannot Print in Black
This could be because of several probs: 1. The ink cart is not original and wont let the ink flow, because the valve is not open. 2. There might be air bubbles within the capillaries. 3. The ink is not genuine ink and has pigments in it. Solution: see here, too: http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=dcp110c_us Insert another ink cart. Use, if possible, the genuine ink cart from brother. Do the cleaning cycle twice. This will extract the air bubbles out of the caps after the second time. If you dont have any success the printhead is clogged and cant be cleaned anymore!
Posted on Sep 17, 2007
SOURCE: Pages full of toner / toner streaking
First off, this is a comment from a random person who may or may not know ALOT about these printers and toner/printer design in general. All toners are not designed to the same specification. Toner is a combination of plastic "pigment" and iron like shavings to make it magentically attracted to the electrical charges within the unit. Different toners conform to different grades and mainly size of the particles within the blend. The manufacturer doesnt only recommend that you use their toner to make them money, yes of course it makes money, but its because when the unit is designed it is designed to use a certain grade of toner, trust me if you put the non-branded toner vs the branded toner under a microscope you would see quite a difference. Often the non-branded toner is much larger in particle size (obviousely because its cheaper to make at this spec). This causes a variety of issues from excess toner not being cleaned off of developer rollers, IDT rollers, or clogging of toner dispenser tubes in the unit and the micro filters contained at the toner dispenser assy and developer assys. Also as for the issue not changing when switching to dell branded toner - the dispenser tubes within this unit contain up to 500-1000 pages worth of toner, making no change in toner you make immediately visible. Also depending on the damage caused by the previous toner, it may not be able to be fixed until all the components in between the toner and final delivery (drum cart) are replaced. In this case more than likely the toner dispenser assy, all developer assy's, and drum cartridge need to be replaced, and than be sure to stick with factory branded toner :)
Posted on Jul 17, 2008
SOURCE: Epson Stylus T10: Horizontal bands when printing cyan
With I could post a solutions but I have the same problem! Cyan has horizontal gaps, rest of the colors seem to be ok. I've realigned and cleaned the heads many times.
Posted on Oct 29, 2009
cene765
  • 787 Answers
SOURCE: printer does not print magenta and cyan. Change
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Posted on Nov 12, 2009
  • 32 Answers
SOURCE: Xerox Phaser 8560 Color not correct
the problem is not with the printer but it is with the ink that might be damaged, this is located inside the printer
Posted on Dec 01, 2009
2840 laser printer only prints on right side and nothing on left side
My Color LaserJet 2840 will only print on the right side of ...
h30434.www3.hp.com > ... > Scanning / Faxing
Apr 26, 2011 - 2 posts
I have a HP Color LaserJet 2840. If I am ... My Color LaserJet 2840 will only print on the right side of the page, how can I fix this? ... If I am copying or printing from the computer, the printer will only print the right side of the page. ... something obstructing the laser scanner blocking that side of the media path.
HP 2840 printing problem ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/46992
Feb 1, 2010 - ... Apr 19, 2007 at 10:57am. 0. HP Color LaserJet 2840 ... I have the same issue as above-Not printing on the left side of pages.I went threw the ...
HP Laserjet 2840, various problems ' FixYourOwnPrinter
Dec 25, 2015 | HP LaserJet 2840 All-In-One Printer
I installed an original Q3971A toner into the HP 2840 laser printer, However there is still a notice to install cyan catridge. Can you help please
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
Dec 18, 2015 | HP LaserJet 2840 All-In-One Printer
I'm trying to print its says page too complex
A solution might be the proposed in this webpage:
http://h30434.www3.hp.com/t5/Printer-All-in-One-Software-Drivers/page-too-complex/td-p/88560
Also, might be a problem with your driver, Download from HP website the latest driver available for your pronter model and intall it.
At this webpage you have the procedure for some other model but it shold be basically the same applied to your model.
HP Color LaserJet 2600n Page Too Complex Errors along with Blank Pages
page too complex
If still can't print, do a Google search for "PAGE TOO COMPLEX" and youll find more comments about issue.
Oct 23, 2015 | HP Color LaserJet 2840 All-in-One -...
Using only HP products color doesn't print
There are two ways to print black (grayscale) only. One is through the printer access provided through HP software. The other is through the Windows printer software. Try accessing through MS, such as printing from office or paint and see what the printer options show. Then try it again through another program, such as PDF Adobe, or another program that brings up the HP printer software. Another option is going through the device/printers option in control panel. Good luck.
Jan 19, 2015 | HP Color LaserJet 2840 All-in-One -...
How we clean the double image of our print?
Need to do a reinstall. Most important is that a page is printed that needs to be scanned into printer as part of setup. Should fixd problem.
Nov 24, 2014 | HP Color LaserJet 2840 All-in-One -...
Black stripe when printing from hp laserjet 2840
Cartridge faulty...
Two ways you can find out the faulty cartridge.
1. Remove each cartridge, just flip the drum shutter & chk for any toner bands appears on drum surface.. if found replace that cartridge..
2. Go to the paint. create four colored page as shown, print & verify which colored print mixed with bads.. replace that cartrdige.. ">
Mar 01, 2014 | HP LaserJet 2840 All-In-One Printer
Hp laserjet 2840 not printing
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-2840-prints-blank-pages-or-yellow-only/td-p/2326639#.Ur1kMH_lMgU
Aug 04, 2013 | HewlettPackard HP Color LaserJet 2840 All...
HP 2840 All in one won't print color
printer is ok, check the connecting cable and drivers.
Oct 28, 2008 | HP LaserJet 2840 All-In-One Printer
HP LaserJet 2840 Printer Logo
230 people viewed this question
Seeker5211
Seeker5211
