Question about AEG Lavamat 16810 Front Load Washer/Dryer
Error 20 AEG washer dryer
Error 20 during a cycle
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Posted on Oct 25, 2008
Remove some clothes and spin again
Posted on Jan 26, 2010
Load is now too heavy with the added water and/or water is not draining.
Posted on Jan 11, 2008
My AEG T37400 lavatherm standanlone tumble dryer works for a turns of the drum then stops.
Alarm conditions during operation of the dryer
The LEDs begin to flash if one of the following malfunctions occurs:
  • NTC open (the LEDs flash in sequence from right to left)
  • NTC short-circuited (the LEDs flash in sequence from right to left)
  • If the START button is pressed for more than 20 seconds while a cycle is in operation all the LEDs flash.
25679338-hf2jxxovvq5cn05mugly0fcq-5-5.jpg If the microprocessor identifies one of the conditions listed above, operation of the dryer is interrupted; the LEDs continue to flash in order to warn the user of the malfunction.
If the error is eliminated, the dryer returns to normal operation when the programme selector knob is turned to RESET and the drying cycle is re-selected.
Dado
May 04, 2015 | AEG Dryers
AEG F60873 temperature problems.
The problem when the dishwasher does not heat is failure which requires to remove the qualified personnel and therefore error code is not shown on the display but it is visible in the service mode.
Possible error causes:
faulty heating element
wiring between heating element and PCB
PCB (printed circuit board)
Dado
Aug 24, 2014 | AEG Dishwashers
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
I have an AEG Lavamat L 16850. It has stopped showing an EFO error code for the second time (on the 20 minute cycle both times). The first time I removed the fluff filter which seemed to solve the...
We have this problem for nearly 2 years now. It always occured in a special program ("Kochwäsche/Buntwäsche 60°" what means coloureds/boiled 60°).
The AEG technician didn't find the problem. Since we avoided that program, the problem never occured again.
But now, close before 2-years-warranty-by-law I demanded them again to repair it. I will report.
Oct 25, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
My AEG Lavamat 62810 keeps coming up with an error code E60. What is this?
On my AEG Lavamat 62810, when I turn on a wash cycle a motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message. When this happened a few weeks agao running a drain cycle seemed to cure it; now the same thing happens on spin/drain/rinse cycles too. Any ideas?
Aug 06, 2010 | AEG Washing Machines
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG 16810 UPGRADE WASHER DRYER E10 ERROR
This is worth posting in case anyone else has the problem. The mechanic was stumped and then around 3 days later a Zanussi gave the same problem - steam emitting from the drum. He changed the valve - the entire unit. Problem solved. Zanussi and AEG have identical internals. He changed our valve - problem solved.
Jul 22, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
1,913 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
