Question about Hubbell Shore Power Inlet 50a 125/250v
I want to install a marine shore power inlet in a sail boat. I see the standard is 125v/30 amp connection but I don't see any backing ring or backing plate to screw the inlet to. What is the standard backing for a power inlet?? Thanks.
    Scholar:
  • 111 Answers
You should try this instead. http://www.smartplug.com/
They know the standard and I have used them without incident since they came out. Not a bad way of doing things!
Posted on Jan 25, 2010
How to Buy and Install an Outboard Motor?
first find out what size motor will be needed for your boat then look up reviews on different makes also compare pricing for your budget then go to a marine store/daler and order one you want
Oct 20, 2016 | Boating
Will a Midland 75--810 communicate with a marine band radio?
Sorry Paula
The 75-810 is an CB radio that DOES have Wx capability but it won't communicate with marine band VHF's.
Hoe this helps you out.
-Steve
Oct 31, 2015 | Boating
Thermostat on 2005 aviator location
Removal & Installation
Print
4.6L & 5.4L SOHC Engines
  1. Partially drain the engine cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose from the water outlet adapter.
  3. Remove the power steering reservoir upper mounting bracket.
  4. Remove the bolts and remove the water outlet adapter.
  5. Remove the water thermostat and the O-ring seal. Discard the O-ring seal.
  6. Installation is the reverse of the removal procedure. Tighten the water outlet adapter bolts to 18 ft. lbs. (25 Nm). Tighten the power steering reservoir upper mounting bracket as shown in the accompanying illustration.
    Fig. View of the power steering reservoir upper mounting bracket and tightening specifications
    Fig. Exploded view of the water outlet adapter and tightening specifications
5.4L & 6.8L Engines
  1. Partially drain the cooling system to a level below the thermostat.
  2. Disconnect the upper radiator hose.
  3. Remove the coolant outlet connection, as follows:
    1. Remove the bolts.
    2. Remove the coolant outlet connection.
  4. Remove the (A) coolant thermostat and the (B) O-ring seal.
  5. Discard the (B) O-ring seal.
    Fig. Remove the (A) coolant thermostat and the (B) O-ring seal
To install:
NOTE Thermostat must be installed as illustrated.
  1. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold.
    Fig. Use a new (A) O-ring seal to position the (B) coolant thermostat in the (C) upper intake manifold
  2. Install the coolant outlet connection, as follows:
    1. Position the coolant outlet connection on the upper intake manifold.
    2. Install the bolts and tighten to 15-22 ft. lbs. (20-30 Nm).
  3. Connect the upper radiator hose.
  4. Fill the cooling system.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Partially drain the cooling system to a level below the thermostat.
  3. Disconnect the upper radiator hose.
  4. Remove the coolant outlet connection, as follows:
  5. Remove the (A) coolant thermostat and the (B) O-ring seal.
  6. Discard the (B) O-ring seal.
To install:
5.4L DOHC Engine
  2. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter.
    Fig. Disconnect the upper radiator hose, the heater water inlet hose and the heated PCV inlet hose from the water outlet adapter
  3. Remove the water hose connection and thermostat.
  4. Installation is the reverse of the removal procedure. Tighten the mounting bolt to 18 ft. lbs. (25 Nm).
    Fig. Exploded view of the thermostat-5.4L DOHC engine
Aug 13, 2012 | 2004 Lincoln Aviator
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
What is the amp draw of the motor, so i can buy the right battery for a minn kota endura 30 trolling motor?
You will need a 100 to130 amp hour deep cycle marine battery. Check prices of many brands in your area. (WalMart, Autozone, boat dealers,ect.)
Sep 16, 2010 | Minn Kota Endura 30 Freshwater Transom...
Is it compatible 3.5 HP engine with the boat? (mariner 4) if yes , when i used %30 of power just alone back side go down and can not control properly . engine is TOHATSU M 3.5 S
Your motor is too large.
For the Intex Mariner 4 Intex recommend an absolute maximum of 3HP (2,2kW) and the motor must not weigh more than 40lb (18,2kg).
Those limits assume that you are using the Intex motor mount kit (Part No. 10658) and that the boat is correctly loaded and inflated.
In reality and from experience I would personally recommend 2HP maximum power and to keep the motor as lightweight as possible. Although the Intex Mariner 4 can take a motor mount, it's really a rowboat and is not suited to using a motor for extended periods, but just as a convenient tender to a larger boat it's fine.
Dec 15, 2009 | Intex Mariner 4 Boat Set
What is best way to clean and restore a 50' X 50 amp marine power cord? Should be yellow. Is now black!
West Marine (and many marine stores) carries a shore power cord cleaner that works quite well.
Sep 20, 2009 | Hubbell Shore Power 50' Cable Set #6awg...
Shore Line Compact WR Marine VHF radio manual
I am looking for a power cable for my shoreline compact wr radio
Aug 30, 2009 | Boating
I WANT TO CONNECT MY MARINE RADOI TO THE WALL CURRENT 110V. I'M GOING TO USE THE CONVECTOR FROM 110 V TO 12 V. WHAT CAPACITY SHOULD I BUY THE INVERTER (OR CONVERTER - WHATEVER ITS NAME) IN AMPS ?. IS 5...
5 AMPS would be more then you need. 3 Amps would run it ok. I would go with the 5. But do not, DO NOT, sorry for stressing this but you will ruin your radio if you do go any higher then 5 amps
Apr 29, 2009 | Standard Horizon Eclipse Fixed Mount Vhf...
Hubbell Shore Power Inlet 50a 125/250v Logo
145 people viewed this question
Top Hubbell Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Hubbell Boating Expert? Answer questions, earn points and help others
