Question about Dell Dimension 2400 PC Desktop
DVD drive has shut down. It is not working, and this is about the 4th or 5th time this has happened since I bought the computer a year ago. There is a repair program that I have used before, but I have lost it. Can you help me
  • 34 Answers
Could be a effective dvd drive buy another one from a recycling center or ebay.
Posted on Nov 16, 2009
I can only get 4th gear on my 2000 geo metro what do i do to fix it
I suggest that you have to pull the box and do a full overhaul on it. From your description you will need 5thgears and synchros--bearings -all gears synchro kit and may be some gear dogs as well. Consider a replacement box from the wreckers as it would be cheaper.
Nov 16, 2013 | Cars & Trucks
Pata slave drive not found in bios a05 of dell dimension 8400 but found in windows and linux os's
Hi
Have you tried swapping the pata drives - eg master to slave and vice versa ?. I have found that if the drives are not from the same manufacturer, quite often, you cannot get both drives to work. Seagate and WD normally are O.K., but some of the older Fujitsu ones just knock out any other drives on the same 40/80 way cable.
Mar 17, 2017 | Dell Dimension 8400 PC Desktop
2010 crf450r jumping outta gear from 5th to 4th all other gears work fine
Terrence >>>> 1. Do not go through the gears while idling on a stand!!!
The rear tire is not moving at the speed that is normal for 4th or 5th gear..AND if you do get the tire moving that fast.. it is BEYOND DANGEROUS!!
This sounds like the 4th and 5th gears may need replacing.. or the shift drum detent for 5th gear has somehow become ineffective.. If you continue to ride this bike , you may cause more trouble and damage to the transmission.
Take this to a qualified professional!!
Jun 24, 2017 | Honda Garden
Turn up the higher setting for more heat but shuts down at the 5th click.
I had this problem last year and I have the fix for you. In between the burners there is a part called the flame sensor. See attached picture. All you need to do is clean the metal L shaped rod with Steel wool. Problem solved. The rod is oxidized and cant sense the flame.
Sep 04, 2012 | Heating & Cooling
Have 2000 camaro ss 6 speed lost 5th and 6th gear still have 1st 2nd 3rd 4th and reverse
So out with the trans & break it down
You find the problems once it is all over your
work bench
Worn Synchros ,happens when your having fun
jamming it through the gears
I beat the heck out a 65 Stingray I bought new
& get lots of experience pulling the trans & working
on the entire car myself,no teacher in the 1960's
Being a machinist at the time helped
Jul 01, 2011 | 2000 Chevrolet Camaro
Vibration
loosen all the engine and trans mounts and the exhasust head pipe pipes from the exh manifolds, then shift the trans from park to reverse a few times and then to nuetral, shut off the engine and see if that helps.
Sep 09, 2009 | 2004 Toyota Land Cruiser
My DVD/CD-ROM DRIVES play DVD but not any CD or VCD
Okay, is it Blu-Ray?
Those drives tend to have a fault w/ non standard DVDs/Blu-Ray Discs
Thnks to Sony
try going to device manager, right click the drive, properties, 3 or 4th tab, roll back driver
Jan 12, 2009 | Sony Computers & Internet
DVD rom drive
It may be the problem with drivers but its a rare chance. Go to ur DVD manufacturer website and check the drivers.
Happens tht sometimes dvd drives just stop working. Replacing ur drive would be the best thing to do. Just out of curiosity what is the name of the manufacturer of ur dvd drive
Aug 18, 2008 | Computers & Internet
DVD+RW DRIVE STOPPED WORKING
Try rebooting your computer. I have a similar desktop and sometimes after a period of use the drive seems to power down - if I shut down and start up again it seems to work again.
If this doesn't solve the problem, check the connections inside the computer to make sure the drive has the data cable and power cable connected securely.
If you bought the Inspiron 3 days ago, contact Dell for warranty service and a replacement. If you just bought the drive itself 3 days ago, take it back or return it to the retailer you bought it from for a replacement.
Jun 06, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
20 people viewed this question
Alun Cox
