Question about Hand Tools
I have an old dremel tool model 270. I just
I have an old dremel tool model 270. I just purchased grout removal tool. Is this model the right rpm to do the job. Grout tool kit says not to use model 275 as it operates too fast?
  • 187 Answers
If you are saying that the grout tool that you bought is a bit you hoped to use in one speed dremel, I would not use it if the manufacturer of the bit specifically said not to. If you are saying that you purchased a tool that operates separately and doesn't need to be power by the dremel, that is different. I can tell you that manufacturers never tell people not to use their product unless there is a pretty good reason! So, if it is the first scenario I advise you not to use the bit in the dremel.
Posted on Nov 15, 2009
Is there a specific tool recommended to loosen the set screw so I can change the tip? It doesn't mention anything in the directions
Engraver Kit / Model: 290-01 - Dremel.com
www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=290-01
DremelFeaturing a replaceable carbide point, Dremel's engraver kit lets you work on metal, ... http://mdm.boschwebservices.com/files/Dremel Engraving Tool 290 ...
Amazon.com: Dremel 290-05 120-Volt Industrial Engraver ...
www.amazon.com/Dremel-290...Engraver/.../B000VZ...
Amazon.com, Inc.
Rating: 4.2 - ‎62 reviews
Dremel 689-01 11-Piece Rotary Tool Carving and Engraving Kit .... tips and came from a different source ie there is no Dremel 290-05 tool. ... On the very first tool, afterengraving the serial number, the diamond tip began to loosen and slip out. ... When I returned to the engraver to tighten the set screw the tool fit perfectly, ...
Home Depot Dremel 120-Volt Corded Electric Engraver ...
reviews.homedepot.com/.../dremel-120...engraver...tool.../questions.htm
Afterwards you can remove the paper and glue with a simple adhesive remover or alcohol. ... I use the Dremel Electric Engraver Tool to engrave manufacturers name and model .... hardware store and they should be able to supply a new set screw for you. .... The 290-01 Engraver is for engraving applications only and is not ...
FAQ - Customer Service - Dremel
www.dremeleurope.com > Home > Customer Service
Dremel Europe
Dec 16, 2015 | Dremel 290 - 01 Engraver
Where can i get replacement brushes?
brushes for dremel tools can be purchased at stores that sell real dremel tools and bits (there right in the same rack) ck package back for your model number
Mar 11, 2014 | Tools & Hardware - Others
I have an old Dremel scroll saw model 550 and need blades. However, the blade holder is missing a clamp that secures the blade. Is there a universal kit I can purchase to solve problem?
Try going to a store that sells scroll saws and look at the new models to see how they hold the blade. Take your Dremel with you. Maybe you can find one that is similar enough that could work if you can get the part. Then go to the tool company's web site and search for the manual for the comparable tool you found - they all have on-line manuals nowadays. You should be able to order the part you need. Good luck!
Jan 30, 2013 | Dremel 5 3" Saw Blades 8033 For 550...
How to remove old hard grout from walls
There is no easy method that I have found over the years. The best thing that I have found is a speciality bit made for a dremel rotary tool. I believe it is made of titaninum and it is made to cut ceramic tile. They are not cheap or fast but they will get the job done.If you are dealing with a grout that is not portland cement base then dremel also makes several carbide tip cutters that will work.
This is a time consumining project and if you try to grind it out I would strongly recommend you use a good qualility dust mask. I hope this helps you and good luck. Thank you.
Feb 10, 2011 | Home
I have a dremel Model 270, with defective rotor. I need the rotor. Exist yet, for sale?Thanks.Tales.:
Hello. I'm new to FixYa and just found your inquiry.Dremel does have a router attachment for your unit. The model is "Dremel 335 - 01 Router Attachment" and usually sells for about $20-$30. Here's Dremel's cust assistance info just in case:
Phone:
1-800-437-3635 (toll free)
1-262-554-1390
(7am-6pm CT Mon-Fri)
Sep 11, 2010 | Hand Tools
Where can i find an instruction manual for the clarke ct4009 rotary tool
i have a dremel cordless rotary tool but have no manual,if anyone has one for the Dremel Lithium-ion cordless 10.8 variable 5,000-35,000 rpm model 800,can you kindly email it or tell me where to download it from at
rkellock@eastlink.ca
thanks "R"
Jul 08, 2009 | Tools & Hardware - Others
Tasks usage
Cutting holes in wallboard, Removing grout, Deburring metal, Cutting fiberglass, Sanding in tight spots, Cutting the heads off stripped screws, Shaping metal, Cutting ceramic tile, Stripping old paint and varnish from woodwork, Removing window pane glazing, Grinding, Shaping and cutting in arts and crafts projects, Polishing metal, Engraving, Etching, Cutting marble, Cutting nails, Cutting plumbing pipe, Sharpening tools, Cutting wood.
Aug 27, 2008 | Dremel 764 04 Pumpkin Carving Kit Includes...
Hand Tools Logo
472 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Bill Boyd
Dan Apthorp
Are you a Hand Tool Expert? Answer questions, earn points and help others
