Question about Asko W6461 Front Load Washer
Moldy smell from front-loader Asko washer. - Asko W6461 Front Load Washer
  • 77 Answers
All front loaders do this leave the door open from now on and run a gallon of bleach through it.
Posted on Nov 15, 2009
  • 2,200 Answers
Hi
First check to make sure that the machine is draining properly and that the pump filter is clear of any debris.
On a frontloader a common place for mold to build up is the rubber seal around the door. Clean this out as well as you can with ordinary kitchen cleaner then place a heaped cup of baking soda directly into the drum and run an empty hot/boil wash on a full cycle.
Baking soda has a cleaning and neutralising effect and will help remove any build up of mold or gunge within the machine. You may need to run two of these washes before you see a solid result.
Thereafter I recommend you run a monthly 'maintenance wash' with the baking soda to prevent the problem arising again.
Hope this helps. Thanks for using FixYa
I want to buy a Frigidaire Affinity washer because I found one at a good price, BUT several reviews say there is a moldy smell that is awful. Any advice?!
Leave the door open to allow the tub area to dry after use (both top and front loaders). Front loaders also have a propensity to hold a small amount of water in the rubber door seal. Wiping this up after each use will also help prevent the growth of mould.
Nov 23, 2010 | Frigidaire ATF6000ES Front Load Washer
Neptune MLG2000A doesn't drain completely and has moldy smell
You need to clean the stationary "brush" that collects lint and debris from the water during the cycle. The brush can be seen around the tub directly touching it along the bottom/front of the device. Right were I pour my detergent in, after the cloths are in there. To remove the debris I use a bottle brush. You can expect to use trial and error for your attempts. As far as the water being left.... My device has always left water in the bowl. I periodically just run a cycle with no cloths and bleach...HOT.....Mine is not spinning at the moment...again....I think its another call to the local dealer....AGAIN....
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
My Maytag Neptune front loader always retains water after the rinsing cycle is complete. This has lead to mold in the door gasket and a moldy smell. Is it normal for water to stay in the machine after the...
pump is probably clogged not allowing all water to drain out. Should never see water in the tub at the end of a cycle. About once a month you should run your washer through a cycle with hot water and bleach. Doing that should keep the moldy smell down.
Mar 15, 2010 | Maytag Neptune MAH5500B Front Load Washer
Moldy smell
Hi Jewel,
You may want to try some Washer Magic, or similar product specifically designed to clean out washing machines. I personally use Affresh in my front loader and it works very well.
SG
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Moldy smell inside GE profle top loader washer
Check the pump and make sure that it is draining the water. There will always be a little water left over but you should never be able to hear it very easily. Once you check the pump and make sure it is operating properly check the water sensor to make sure that it is acuratly reading the water hieght. After that take one cup of Vinegar and run a hot load of water will kill the mold and clean your system out
Feb 21, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Brown dirt-like looking "gunk" coming out of the washer
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jan 10, 2009 | Kenmore 44832 Front Load Washer
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Mold & Smelly in Washer
Wash on hottest and longest cycle with regular laundry soap and a bottle of vinegar. After cycle, wash again with soap on hottest/longest cycle. This will clean your washer like new.
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Moldy smell in front load washer
www.affresh.com this will help with odors, also make sure you are using HE detergent and little bit at that(2-3 tablespoons)
Oct 12, 2008 | Kenmore 44072 Front Load Washer
Moldy smell in front load kenmore washer
I had the same problem. Have you cleaned the filter under the front panel? Simply remove the three screws holding the panel below the door and remove the 2" white screwcap. Be sure to have a basin handy to catch the water. (possibly a couple of gallons if the stainer is really clogged) I suspect you'll find several moldy items that are causing the odor. Good luck.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Asko W6461 Front Load Washer Logo
878 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
