Washer leaks when filling,fill by pail no leak
GE space saver 6 years old ,one person so used about 3 loads of light wash a week. Washer leaks when filling,fill by pail no leak , none when agit, spin/drain. the hoses are ok Also lint filters are ruined $ 50.00to replace ,can I operate without them or will it ruin the pump. Does it pay to fix , service man gave a price of apprx . $300,00. Thank you Pat
  • 77 Answers
Pat it sounds like you pressure switch or hose to it is bad.your washer isnt leaking its overflowing the tub right?I dont understand the rest of your question so ill leave it alone..
Posted on Nov 15, 2009
How to replace seal of ge top load washer
You have asked a number of questions. How old is the Washer?
Based on your questions, it may be time to replace. No I am not a
GE Rep. Parts can be ordered online. Google Appliance parts. They may be able to help with "how to's". If newer machine, still warranty? If so check with GE. Otherwise, if the tub isn't being over filled and spin out doesn't send water outside the outer tub which could explain the dripping. Verify gasket leak by leaving water in tub and measure height of water very carefully let stand several days and remeasure.
Remove top should be springs on the front. Push in, to release, tip-up top. Tub must be removed. Remove the agitator by removing the top plastic, should reveal top nut holding down the agitator. You will see a number of nuts holding the agitator tower to reveal gasket. There may be rusting and pin holes causing the leak. I would check this before attempting gasket. I had a similar issue, used JB Weld epoxy about 5 year ago, still not leaking. Possibly the agitator tower has a seal leaking at top. If so that is in transmission and should be replaced as well as the bottom gasket. It may be $200 part.
Due to all the trouble, I replaced it to prevent future failure. You may find a lightly used replacement washer for about that price.
Nov 18, 2014 | GE Washing Machines
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
My GE Washing machine appears to be leaking from the bottom
It sounds to me , you need the seal and bearing kit.. It is over 300.00 dollar repair, if it is an old washer I would say go get a new one
Jan 13, 2010 | GE Profile Performance WPSF4170WAA
GE WBSE3120B toploader washer leaks only during agitation when super load selected. Is it the pressure switch for water fill level or another possible leak?
knowing this is the only time it leaks helps
sounds like your suffering from suds leak
try cutting way back on your soap 1 tablespoon per load that should take care of your issue
Oct 04, 2009 | GE WBSE3120B Top Load Washer
Washer leaks now when doing large loads.
pop the front panel you can do this with a putty knife. where the top is 2 inches down you will see a creas use a flash light you will see the 2 clips push in on the clips and pull out you will be able to access where the tub is to see where the leak is comeing from
Jan 04, 2009 | GE WBXR3100B Top Load Washer
Maytag top load washer leak
underneath the agitator is a graphite seal ring and nut that seals the inner tub and the outer tub. a suitable spanner wrench or a 6 inch channel lock plier will remove this locknut. replace the seal.
Sep 02, 2007 | Washing Machines
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
