Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso washing maching appears dead. Power is
Calypso washing maching appears dead. Power is coming into the machine (checked with gauge). This is not the first, second or third or more times this has happened. Have been able to get it to work by unplugging overnight in the past but not this time. Is there an internal fuse or circuit breaker on/in the machine itself? Help!!!
FYI, we have already had this machine service man repaired several times for miniscule reasons for lots of money and the machine is only several years old. We thought we were buying a quality machine and spent lots of money over all the other machines out there, but appently we were wrong. HELP!!!
  • 77 Answers
Its your control board most likely.Im sorry these machines were full of gremlins.service techs hate to work on them thats why its so much to fix them.sorry.
Posted on Nov 15, 2009
Testimonial: "Thanks for a quick and most likely answer. Appreciate the response and now we need to decide to keep repairing or buy something else. Thanks again!"
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Washing maching not working
Hello would need the complete model number and the make of the machine to provide exact solution whereas Error code 51 for a kenmore elite, Calypso, Catalyst usually tends to point towards a defective rps sensor which is the small sensor located on the stator (motor ). I will await your reply in order to supply an exact diagnosis of your issue
Thank you
Rick
Nov 22, 2011 | Washing Machines
My washer a calypso gvw9959k has no power . what could it be
Hello. Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Joe
Thanks for choosing Fixya!
Feb 19, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My whirlpool calypso washer just quit working no codes no power just dead. GVW9959KQ2
Won't Power Up
  • 120VAC electrical supply.
Check voltage supply to washer.
  • Open AC cord.
Check for voltage at the power cord connection to the line filter.
  • Line filter open.
Check voltage into and out of line filter.
  • Machine control board open.
With the washer off but connected to the AC outlet, measure the AC voltage between Pins 4 and 2 at connector P16.
Dec 23, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
We went camping for 2 days came home and the calypso washing machine won't start. We ran a load the day we left with no problems. The outlet works fine, we even tried plugging it into another outlet just...
The same happened with my Sears Calypso machine. The common problem is the front display panel. If you are able to find one at a very good price, post it here.
Aug 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso washing machine conrol panel is dead like its lost power
Check the supply circuit. The receptacle might be GFCI and needs to be reset, or the circuit breaker may have tripped and need be reset. If you have power goihng to the machine, then the control board may have failed.
Aug 02, 2009 | Kenmore Washing Machines
Just dead. Doesn't light up or start or respond.
You will need to replace the power supply most likely. If you can find a fuse or relay, check with an ohmmeter to determine that they are good. You can use a voltmeter to determine that there is power going to the control panel.
Jul 13, 2009 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
349 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
