Question about Honeywell Programmable Thermostat Heater
Iv set my days and times on when i want my heating to come on but what do i put the switch on to auto or once? so that in the morning it will come on automaticly. thank you
  • 148 Answers
Set the switch to Auto
Posted on Nov 21, 2009
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Cuisinart dc 1200 coffee maker auto start mysteriously shuts off
Sounds like the switches got damp when you cleaned it. Let it dry out very thoroughly before you plug it back in. Then set the TIME OF DAY first, and be sure you pay attention to AM/PM if you are not in the 24-hour mode. Next, set the BREW TIME. Once again, heed the AM/PM or you will have nice hot coffee either 12 hours early, or 12 hours late! (I don't know which would be worse.)
Mar 18, 2012 | Cuisinart DCC-1200 Coffee Maker
Model TWEO36C140A1 blower will come on if I throw the breaker switch...but thermostat doesn't seem to be in sync. Fan will run in "on" position and once blower is running, in auto. ...
If no relay I'm assuming this is an x13 motor. Try swapping speed taps 4 and 5. It's possible the winding is over heating. Tough one to diagnose without being there. With power off take pic of tstat wiring and remove all wires. Be sure to spread wires apart to prevent blowing fuse. Turn power back on. Red and white together should bring on heat and fan. Red green and yellow should bring on fan and compressor. Try this several times each way making sure the blower comes to a complete stop every time. If everything seems to work by bypassing tstat you likely have a bad stat. Provided swapping your speed taps was unsuccessful. Good Luck!!
May 06, 2017 | Heating & Cooling
AC was weak so had it recharged. Everything was fine for the rest of the day. Next morning I started the car, turned on the AC, was putting junior into his carseat when the AC quit. I turned it off then...
read the owner manual to see how the auto works. try the defrost mode whcih is a fail safe mode and should always come on unless a major system issue.
Oct 15, 2010 | 1988 Jaguar XJ6
What is the proper proceidure to set exercise timer on a briggs generator model # 01938 and what year was this model manufactured? thank you
http://www.homegeneratorsystems.com/service_support/manuals/index.cfm?rd=1
This link will take you to their site where you can download their manual.
Setting Exercise Timer
The Home Standby Generator is equipped with an exercise
timer that will start and exercise the system once every
seven days. During this exercise period, the unit runs for
approximately 20 minutes and then shuts down. Electrical
load transfer DOES NOT occur during the exercise cycle
(unless an utility power outage occurs).
A switch on the control panel is labeled “Set Exercise”
(depicted on page 10).The specific day and the specific time
of day this switch is pressed is programmed into the
control board memory.This date and time is then used to
automatically initiate the system exercise cycle.
To perform the Set Exercise procedure:
1. Choose the day and time you want your Home
Standby Generator to exercise.
2. On that day and time, set the AUTO/OFF/MANUAL
switch to OFF.
3. Press and hold down the “Set Exercise” switch for two
seconds.
4. Set the AUTO/OFF/MANUAL switch to AUTO.“Set
Exercise” is complete.
For example, if you press the “Set Exercise” switch on
Sunday morning at 10:00 AM, the unit will run an exercise
cycle the following Sunday at 10:00 AM (+/- 1/2 hour).
NOTE: “Set Exercise” will only work if the unit is in the
Automatic mode and this exact procedure is followed.The
exerciser does not need to be re-set if the 15 Amp fuse is
removed or changed.The exerciser will need to be re-set if
the 12 Volt DC battery is disconnected.
If you want to change the day and time the unit exercises,
simply perform the “Set Exercise” procedure at the exact
weekday and time you want it to take place.
• To prevent possible injury that might be caused by such sudden
starts, always set the AUTO/OFF/MANUAL switch to OFF.
• Remove the 15 Amp fuse before working on or around the
generator or transfer switch.
Nov 12, 2009 | Briggs & Stratton 12,000 Watt Bi Fuel...
I cannot get the auto start to turn on. The times are properly set. Does the Program green light need to be yurned on to auto start or what?
You have to set the coffemaker to AUTO-ON for it to turn on at a set time in the morning. The PROG function is merely to set the right turn-on time. Once this time is set, you must switch the coffeemake to AUTO-ON.
-Tha Mp3 Doctor
Mar 20, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Acer aspire 5100 cd-rom issue
You can try deleting upper and lower filters. This solves many CD/DVD drive-related problems. The steps are outlined here:
http://support.microsoft.com/kb/314060/
Jan 28, 2009 | Acer Extensa 4620 Notebook
Fan Honeywell Chronotherm IV T8600
sounds like the fan has been programmed to come on during that time. run through your programming settings and make sure the fan is set to auto for all the times.
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
The exact same thing happens to me all the time. I don't have a solution I need one. As far as I can tell the only way out of this
Aug 04, 2008 | Acer (91.AB264.023) Internal 32x CD-ROM...
Heating & Cooling Logo
75 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
