Question about Hotpoint Dryers
Ctd80 hotpoint condenser dryer not heating up at all showing error message f 14 think its thermastat
  • Hotpoint Master
  • 3,463 Answers
Error code 14 indicates dryer element fault.
Checkelement-connections-and control module.
Please leave feedback.
Thanks.
Posted on Nov 16, 2009
Cotons high heat not working ctd80
one element could be broken , dryer takes two for high and only one for lower temps
Nov 26, 2013 | Hotpoint TDC32 Electric Dryer
I keep getting error code F-14 on Hotpoint condenser dryer model CTD85
Hi.
F14 means that control board does not sense that machine is heating:
F14 - A fault with the water heating has occurred
When you get F14 the fault is usually either the thermistor or the heating element (electric dryer). Both parts are tested removing the part from the dryer and reading impedance at the part contact. If the part returns infinity, then the part is defective. If you need to contact a qualified technician use the phone number listed on your owners manual or check Hotpoint website.
Regards.
Ginko
Sep 20, 2011 | Dryers
Condenser not drying stuff properly
I am hoping your talking about a clothes dryer here. based on the model number you posted here. Does your dryer even feel warm to the touch as in any signs of internal heating? If not then here are some things to check. 1 the basics: Check the circuit breaker and make sure that both of them are in the on positon. Just trip them off and then back on again to reset them. 2. Check the power cord for any signs of a bad connection. It will show up as a dark discoloration. 3. I know you said you checked the lint filter but have you gone outside and verified that the external outlet vent is free of obstructions? If not please check it and clear any obstructions. 4. The heating element itself may be open. Ovetr time they are like light bulbs and the burn out requiring repl;acement. 5. There can be a thermostat failure causing an open circuit and no power to the heating element. 6. The motor switch also controls the heating element circuit and it is actuated when the motor is running. If the switch has failed it will prevent the heating element from being energized. 7. The least likely suspects are the timer and heat setting controls yet either of them can cause a no heat condition. You did not mention if it was a gas or electric dryer and the comments above are for an electric dryer. If you have a gas dryer then you can have 8. a bad ignitor, 9. a bad gas valve, 10. a failed gas regulator. Based on this model number CTD80 it does not cross to anything that I can find. The bottom line is your unit is probably worth the cost of getting it repaired. You may want to check your model number again please and repost it you need more information. It appears this is a UK model. I hope this was helpful. It certainly was educational here.
Jan 11, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ctd80 showing error f13, have cleaned all the filters, and cleared the water and still it doesnt clear error on the low heat setting
F13 indicates the rear thermistor is open/short circuit, this is part of the heater circuit. it is akin to a thermostat, but there is more than one!!
Hotoint recommend you call an engineer..
I am assuming that this is a lcd tumble dryer.
Plz leave feedback.
Ta.
Dec 10, 2008 | Dryers
Hotpoint Ultima CTD80
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Sep 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint CTD80 Tumble Dryer F03 error
hiya
sounds like you will need a thermostat kit and possibly a heater unit, if your getting them shipped to oz you will probably use them. i would change the thermostats first as this will more than likely be the cause.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj.
p.s if its still broken this time next year i'll come and have a look just waiting of my visa :)
Jul 24, 2008 | Hotpoint Aquarius WD63 Front Load...
Condensor hotpoint ctd80 drier WON'T GET HOT
Check vent from dryer to outside.
May 09, 2008 | Dryers
Dryers Logo
401 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
