Question about Nikon D90 Digital Camera with 18-105mm lens
My view window is dark and the auto setting wont work, is this related to the iso?
    Guru:
  • 1,738 Answers
It is the sensor. I went through the same problem on my camera. It was a nikon and it didn't work and got a new one for reasonable price and now it is working. Digital cameras are design to work about two years.
Posted on Nov 15, 2009
Very dark video output and view through the view screen, no matter where the ISO dial is set. The Auto, C1 and C2 mode for Photos is just as dark. I can take good pictures only in P (Program) mode, al
This is most often a problem with the imaging sensor and no reset is going to repair the part. Also, if replacing it, it needs to be properly calibrated after installed. If you need help with this, this is the place we recommend for the Canons: www.CamerasAndParts.com They are the best for these models, they only work on Canons and they are excellent for repairs. They have a service package for about $90 which takes care of an image problem as you have or you can try emailing them first. As far as service and the quality of work, I wouldn't go anywhere else but them for a Powershot. They are the best for these cameras. Good luck
Dec 20, 2014 | Canon PowerShot G10 Digital Camera
How do I lighten the pictures?
Check your camera settings:
White balance should be set to auto,
ISO should be set to auto,
flash should be set to auto,
scene should be set to auto,
Exposure Compensation should be set at 0.
If images are still too dark change ISO setting to 200. If that doesn't work change to 400. If that still doesn't work change exposure compensation to +1. If your photos are still too dark your camera is defective.
Nov 10, 2014 | Vivitar ViviCam 7024 Digital Camera
Nikon D5100 dark screen on live view mode
Open your appuatue set your ISO to 200 or 1600 what ever it needs
Feb 20, 2014 | Nikon D5100 Digital Camera
Pictures are all too dark even with flash
Go to Menu find Adjust ISO settings in camera it may be on Auto or at low setting . The Higher the setting in ISO the lighter the picture this is commonly used in low light settings.Play with it until desired ISo works for you . Nice camera nice lens !
Sep 20, 2012 | Panasonic Lumix DMC F3 Digital Camera
I bought this canon rebel t2 film camera recently and used film with ASO 400. Portraits look ok. but the landscapes, especially the sky area look dark and grainy. I used ef 28-135mm usm lens. Any solutions...
That's odd that the pictures would be coming out under exposed unless the previous owner has gone into the camera functions and switched the ISO from auto to manual. Another reason is that the exposure compensation has been activated and set for - exposure
Under "normal" use the camera will read the DX code on the film canisters and adjust the ISO automatically. However the previous owner may have shut this off in preference to setting the ISO manually. Even though you have ISO 400 in the camera the ISO on in the camera setting may be ISO 1600.
Checking for the Auto ISO and exposure compensation is fairly easy as you can see the film canister through the film window or you know you have loaded 400 speed film. on the LCD panel at the back of the camera is an ISO icon and exposure compensation.
Make sure the ISO for the camera is the same as what you have loaded and if the exposure compensation is to the right of 0 then the resulting picture will be dark. Move this back to the Zero.
I wasn't able to find an exact manual (if you don't have one) for your camera but have found a camera with similar. Here is a ling for that manual.
http://www.butkus.org/chinon/canon/canon_eos_rebel_ti/canon_eos_rebel_ti.htm
Hope this was a help
Dec 18, 2010 | Canon EOS Rebel T2 with 28-90 lens 35mm...
I am using D90 with programe Auto ISO 400, in clear day sun light my picture get very dark, but on same settings in door with auto flash I get very clear result why?
ISO400 is too high of a sensitivity to use in full day light. Set the ISO outdoors to ISO100 and learn how to use your exposure compensation. The meter in the camera is easily fooled in bright contrasty conditions, so if you are getting consistantly darker shots outdoors increase the exposure compensation a stop or two. Another way is to learn how to use the camera in manual mode and you find you will have better control over the exposure.
Oct 21, 2009 | Nikon D90 Digital Camera with 18-105mm...
Grainy pictures...iso problem for olympus stylus 820
Without ISO you will not be able to take pictures.
ISO is the old ASA which is related to film speed
ISO 50 is very slow film speed and may result in blur and some grainy appearance , same as if you PUSHED ISO up to 800 in low light.
Try setting it to ISO 100 and see if that helps.
You can still select auto, but its related to either shutter or aperture priority in relation to the set film speed ( now ISO 100)
Sep 09, 2009 | Olympus Stylus 820 Digital Camera
Is there anyway to resolve shutter lag on the Nikon Coolpix 8700?
oh what mode is your camera in? auto- adjust your Iso it is too bright or dark for your current setting
c1-(manual) change your f-stop and Iso. set the iso to 200 and move the F-stop to any number and test the speed.
c2-same as c1
If you need further clarification write back i'd love to help!
Jan 12, 2009 | Nikon Coolpix 8700 Digital Camera
Picture in dark condition.
It may be that your subject is too far away. The range of your internal flash is 12 feet if you have the ISO set for Auto, or 23 feet if the ISO is set for to 1000. You may get Normal 0   Normal 0 acceptable results with the ISO set to 1000 without the flash, but you should put the camera on a tripod (the shutter speed could be as low as 1/8 of a second) and use set the zoom for wide angle (the lens lets in almost 8 times the light as it does in maximum telephoto.)
I hope this helps,
Mike
Jan 03, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Dark Images
Even in automatic mode, camera still lets you pick what ISO to use. If ISO-Auto is OFF in camera menus, this can give some dark images. Press and hold ISO button and rotate command dial to give a higher ISO, or turn ISO-Auto on in camera menu with crayon icon. Also note that the camera saves exposure compensation setting for each mode,
May 09, 2008 | Nikon D40x Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
78 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
