Question about Frigidaire FRS26H5AS Side by Side Refrigerator
What size bulb for the side by side frigidaire water despenser?
    President:
  • Frigidaire Master
  • 1,922 Answers
15watt maximum
Posted on Nov 17, 2009
Water dispenser how do i change it
if your talking about the water line from the bottom of the door to the despenser head, it pulls out and is replaceable, might be a little tricke to feed through the door but there is a channel in which it will push back through
Mar 28, 2012 | Frigidaire FRS3R5EMB Side by Side...
We bought a 2nd hand frigidaire side by side and the water/ice despenser light bulb is missing. Where can we get a new bulb and what size/type do we need to get?
You can use a regular night light bulb that you can buy from WalMart. It's the same bulb that is used in the large Christmass lights. Without the model number this is a guess but around 85% or the units on the market use this bulb. Good luck and have a great day.
Nov 19, 2009 | Electrolux Refrigerators
Why extra water line INSIDE my refrigerator
Hi, If you are talking about the tubing behind the crisper drawer, it is there to hold water for the dispenser in the door. The old design was a canister to hold water. Now it is tubing. I hope this helps you.
Vic
Jul 18, 2009 | Frigidaire FRS3R5EMB Side by Side...
Replaced watervalve ,water comes out of water despenser without
hi there,
the source tube should be connected to the valve dispenser otherwise the cold water continously flowing,havev a nice day,don't forget to rate me,thank's a lot.
Apr 09, 2009 | Frigidaire FRS26H5AS Side by Side...
The refrigerator by itself activates the water or ice dispensing
could be the water valve or water switch (depense switch)
Apr 01, 2009 | Refrigerators
Water despenser in door drips water
Hi!!! you seem to have a problem that everybody in the world has..Its normal at there is nothing you can do about it unless you install an antisyphon in the water line kitchen aid has one.Good luck..
Jan 05, 2009 | Frigidaire FRS23H5AS Side by Side...
Where is the drain?
Hi, Well could you tell me if your f/freezer is frost free? Or is it a wet wall type fridge? I.E. water running down the back of the fridge? This would help me in telling you what is wrong. As for the water despenser you will probably find that there is a small bit of scale in the water valve which lets the water in or that there is a scale build up in the water despenser in the door. This does happen even tho you have a water softner. You will need to check both as to ascertain which it is.
Dec 30, 2008 | Frigidaire FRS26R4A Side by Side...
The ice cubes come with white powder
Hey there....
The white powder in your ice cubes is the water line to the dispencer,The water in the pipe forms a white layer after some time,almost like the kettle around the aliment,you just have to clean the pipe out,i normaly use some hot water with a bit of vinigar,just make sure you flush the system after wards and there you go....
Hope you get it right...
Wouter.
Sep 10, 2008 | Frigidaire FRS26R4A Side by Side...
Water Depenser
As far as I know, all icemaker-equipped fridges have a filter in line with the water supply and if you have any sediment in yur lines, the filter may be clogged and due for a change.
Aug 26, 2008 | Frigidaire FRS3R5EMB Side by Side...
Fabric softener dispenser
remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
