Question about HP Pavilion ze2000 Notebook
Ze2000 laptop is coming up with error message window\system32\config\system have tried loading friends xp boot disk but fails to pass looking for previous windows
  • 56 Answers
I think your laptop have a virus that will damage from registry ..i suggest reformat your computer and reinstall the windows and antivirus to prevent the malicious attack....
Posted on Jan 09, 2008
  • 45 Answers
Do you have a recovery disk?
Insert the recovery disc, (if auto run starts up, just close it)
Go to Start>Run and type cmd and hit enter.
In the DOS command window, type sfc /SCANNOW and hit enter.
That will check your Windows files against the Windows files on the disc. If it finds corrupted or missing ones, it will repair or replace them. You will not lose any data or files this way. (If it will accept the disc again)
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Saying:/windows/system32/config/system is missing or corrupted n i dnt now how to fix it wut link exactly do i have to download to my usb to fix it n wut r the steps?
Assuming it is windows XP here are the steps to fix that error:
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line:md tmp
My YouTube Channel
Click Here Live Tech Support
May 03, 2013 | ASUS Eee PC 2G Surf Notebook
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Aug 09, 2012 | Microsoft Windows XP Professional
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
My tecra 8000 fails to boot cannot find config sys
Originally Posted by Don this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console2.gif.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Aug 22, 2009 | Toshiba Computers & Internet
Toshiba laptop problem
boot your laptop from a xp cd and select repair option
Sep 30, 2008 | Toshiba Satellite A105 Notebook
Having problems with my compaq Persario 2500
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
md tmp
md tmp
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
HP Pavilion ze2000 Notebook Logo
134 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
