Question about ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC
I loaded the new version of java and it caused so many problems I had to remove all java from my computer. How do I download an older version? I have searched the web, but have been unable to find it.
  • 86 Answers
You can download all previous versions of java from the link below:
http://java.sun.com/products/archive/
Posted on Nov 23, 2009
Java will not load onto the computer how do i fix this problem
What others are saying:
By Brien Posey in 10 Things, August 1, 2013, 10:33 AM PST 1: Verify the error I have seen a couple of situations in which an installation error was displayed even though Java installed correctly. Therefore, I recommend beginning the troubleshooting process by verifying that Java really isn't working. The easiest way to do this is to go to this special test page, which will tell you conclusively whether Java is working.
  • 2: Remove version conflicts If the installation appears to succeed, but Java is not working, check to see whether the Java Control Panel exists within the Windows Control Panel. If the Java Control Panel is missing, the problem is often related to a conflict with JavaFX or legacy Java code. In these situations, you should use the Windows Control Panel to remove any instances of Java. After doing so, use theMicrosoft uninstaller to clean up any Java fragments. Then, try installing Java again.
    3: Use the offline installer The Web installer for Java tends to be a little bit buggy. That being the case, the offline installer package will sometimes succeed where the Web installer fails. You can download the offline installer for Windows.
    4: Try the 32-bit version If you're having trouble installing a 64-bit version of Java, try using the 32-bit version instead. Although 64-bit Java would seem to be the logical choice for use on a 64-bit operating system, the 32-bit version seems to have fewer issues.
    5: Install with administrative privileges If you run into problems installing Java on Windows 7 or Windows 8, try installing Java as an administrator. To do so, download the offline installer and save it to an empty folder on your hard disk. Then, right-click on the executable file and choose the Run As Administrator command from the shortcut menu.
    6: Temporarily disable User Account Control Some people have reported that the User Account Control feature gets in the way of installing Java. If you suspect that the User Account Control feature is causing your problem, you can temporarily disable it until after the installation is complete. The method for doing so depends on the version of Windows you're using. In Windows 8, the option to change the User Account Control settings is found in the Control Panel under System And Security ' Action Center.
    7: Set Internet Explorer's security to the default level If Internet Explorer is configured to use a higher-than-default security level or if it is running a custom security level, there is a possibility that Java may be blocked. You can set Internet Explorer to the default security level by opening your browser and selecting the Internet Options command from the Tools menu. When the Internet Options dialog box appears, click on the Security tab and click the Default Level button. Click OK to save your changes.
    8: Temporarily disable your antivirus scanning There have been some reports of antivirus software preventing Java from being installed. If you want to see whether your antivirus is causing your problem, I recommend downloading the offline installer, updating your antivirus software, and then performing a full system scan. This will help make sure that there are no infections on your system before you disable the antivirus software.
    Once you're confident that your system is free of malware, you can temporarily disable the antivirus scanning process. The method of doing so will depend on the antivirus product you are using, but often it is possible to right-click on the antivirus software's taskbar icon and choose a pause option from a shortcut menu. When you have finished attempting your Java installation, don't forget to re-enable antivirus scanning.
    9: Check for a corrupt user profile According to Microsoft, a corrupt user profile can cause problems with Java installations. Try creating a new user and assign that user local administrative permissions. Then, log in using the new user account and try installing Java.
    10: Use the System Configuration tool Since problems with Java installations are often related to other software that is running on the system, you may be able to fix the problem by temporarily disabling other startup items. The easiest way to do that is to open a Run prompt and enter the MSCONFIG command. This launches the Windows System Configuration utility, which allows you to choose the startup items that you want to disable without requiring any permanent changes to the operating system.
    Other tricks? Have you found some other workarounds or fixes for dealing with Java install headaches? Share your suggestions with fellow TechRepublic members.
  • I have had the same issue on certain machines.
  • For me uninstalling and clearing the Cache before getting a new version worked most often.
  • Only use the Java site for download
  • use the ten suggestions above
  • Java can be a pain
  • good luck
  • Jul 03, 2014 | Dell Dimension E310 PC Desktop
    Pogo ican get on pogo but most of the games will not load
    Remove all Java and Flash from your computer. Once removed, do a Shut down, wait a couple of minutes, power the computer back on, go to Adobe and download and install Flash, after that's done, go to www.java.com and download and install the latest version of Java. Restart the computer, then try Pogo again. Don't skip any of the steps or it probably won't work.
    Oct 06, 2013 | Polaroid POGO Office Equipment & Supplies
    It keeps saying enable javascript which I did and it still will not install
    The first thing to try is to uninstall and reinstall Java.
    1. Enter Windows key + R, which will open the Run dialog box.
    2. Type APPWIZ.CPL into the dialog box and click OK.
    3. Wait for the Programs and Features (Vista and 7) or Add and Remove Program (XP) page to completely load.
    4. Scroll down looking for any JAVA installations.
    5. Select and remove any and all JAVA installations.
    6. Restart computer if necessary.
    7. Follow this link to install the latest version of JAVA: http://www.java.com/en/download/index.jsp
    8. Click "Free Java Download" and download Java.
    9. Install Java and restart computer if necessary.
    Note: If you have difficulty downloading and installing Java, then try and use Internet Explorer to install Java.
    Hopefully this fixes your problem. If it doesn't, then please post back.
    Good luck and thanks for using FixYa.
    Mar 08, 2011 | Kodak S100 Webcam
    I want ti install JDK version 1.5
    1.Remove the previous version of Java installed on your computer by selecting "Start->Control Panel->Add/Remove Programs" from your computer's Start menu. Then, choose the Java program in the program listing and select the remove icon.
    2. Uninstall Quicktime from the Add/Remove Programs menu after Java is uninstalled. In past versions of Quicktime, it has been known to interfere with new Java JDK installations.
    3.Download JDK 1.5 from the link listed in the Resources section of this article.
    4.Choose the installer program after download is complete and choose the default menu options displayed by the installer to install the JDK to your computer. Restart your computer after installation is complete and you will have JDK 1.5 installed on your computer.
    Feb 21, 2011 | Computers & Internet
    Everytime I download mxit on my D900i it says java game error I even bought A different simcard but it still says the same thing
    Java game error is an application error and not a hardware error. So replacing the SIM card will never fix this problem. There's a possibility that the Java version that you have in your phone is not supported by the MXIT.
    Verify the supported Java versions of MXIT. Then check the version of Java you have in your phone.
    Try to upgrade the Java in your phone, then try to download the MXIT again. If same problem occur, try to download another application, and if it DOES work, then there's no problem with the phone. There could be a problem with the application (mxit) that you are trying to download.
    Contacting the manufacturer for additional info is a good thing to do as well.
    Thank you and good luck!
    Jul 10, 2010 | O2 Samsung SGH-E250 Cellular Phone
    Am having problem installing Java. I have tried severla times to download it but along the finishing, it keeps wrting a notice saying that Java is already installed in my computer. But testing my computer...
    Are you getting the below exception
    Error 1714. The older version of Java cannot be removed
    If yes , the you can try Offline installation of Java.The below URL gives the complete details -
    http://java.com/en/download/help/error_1714.xml
    May 17, 2010 | Microsoft Windows Vista Home Basic Edition...
    Java stopped working
    What version of Java do you have running? Have you tried uninstalling the JVM (add/remove software in control panel) and re-loading from the most current version from Sun? V6.16 is most current:
    Sep 02, 2009 | Acer Aspire 5735 Notebook
    Problem with java runtime environment for online gaming
    make sure you uninstall completely the previous java version
    download the latest version that will work with your os
    verify the version that your computer needs.
    Oct 18, 2008 | Computers & Internet
    Cant get a game to load
    YOU HAVE A Choice of using 4 kinds of Javas 1. the default Java,2. SunJava, 3. unsigned version of the default Java. 4. Microsoft Java. I have also found this problem., it happens after you rebooted your computer after installing 6u1 version of java.
    To fix this go to your controll panel>Add or Remove programs then look for java, you should have two different versions there, 5u11 and 6u1 uninstall 6u1 and reboot you computer.
    Hope this helps.
    Sep 30, 2008 | Sun Computers & Internet
    ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC Logo
    258 people viewed this question
    Top ArcMedia Computers & Internet Experts
    Computer Links
    Robin Hill
    Robin Hill
    Mike
    Are you an ArcMedia Computer and Internet Expert? Answer questions, earn points and help others
