Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
I have a D-Link router but the main computer does not connect to the internet when I connect the cord from the internet cable box to the router and the other cord from the router to the main computer
  • cahazuka May 11, 2010
    do you have the modem plugged into the wan and other computers plugged into lan should work unless your internet service requires a log in. if you need to log in you will have to go into the routers set up
  • 3,153 Answers
You connect a CAT5/ETHERNET cord from the MODEM to the yellow WAN port on the ROUTER and then the computers to the other four ports.
The Router alse need to be set up and the CD that came with it will help you through the stages you need to do.
Posted on Nov 15, 2009
How to set up D-Link router
Remove the cable that is attached to the "Internet" port on the rear of your DSL or cable modem.
Plug the Ethernet cable into the "Internet" port on the modem and plug the other end of the cable into the "Internet" port on the rear of the D-Link router. Attach the power adapter to the port on the rear of the router and plug the adapter's cord into a outlet.
Remove the power cord from your modem and wait 10 seconds before plugging it back in. This will reinitialize your modem and force it to establish a connection to the D-Link router. Your router will immediately begin distributing a wireless network with the "D-Link" network name.
Connect your computer to one of Ethernet ports on the rear of the router and open a Web browser. Type "http://192.168.0.1" into the address bar and press "Enter." Enter "admin" into the username field and type "admin" again into the password field. Click "OK" to open the wireless configuration page. Click "Wireless Security Setup Wizard" to create a wireless password for your router's network. Click "Apply" to save the changes to the router's settings.
Feb 08, 2012 | D-Link Computers & Internet
I have no internet to my main computer i rerouted the cable from the router to my lap top then I have enternet but not on my main computer
First, make sure you have the internet cables on your main computer pressed in tightly (to computer and router).
Then carefully follow...
1) Unplug power cord or turn off the "cable modem" (first box that comes into your house provided by the cable company).
2) turn off your router (or unplug).
3) turn off your main computer
4) turn on (or plug in the power cord) for "cable modem" and allow it to run its startup route (1 minute minimum)
5) turn on (or plug in the power cord) for router and allow it to run its start up routine (1 minute minimum)
6) turn on your computer and let it start up and check if internet works.
good luck and rate me please.
May 04, 2011 | Computers & Internet
How Do I Hook up lines
First find your internet modem cable from your high speed internet box. Unplug it from your previous router or computer. This cable should run from your internet box to your router plugging it into the slot labeled internet. Then plug in the power cord to the router and let it power up.
Next you need to go to start then control panel and select the network and sharing center. Select Change adapter settings and then right click on the wireless network connection and then left click on enable. It should find several networks and your should be LinkSys. Select this and then connect.
You should now be able to access the internet after you restart your computer.
Mar 27, 2011 | Linksys Wireless-G Broadband Router
I need to access the d link configuration page. while keeping the internet connected to the router i am plugging a cable to the laptop and to the router and entering 192.168.0.1 an error message is...
Hi tkoleilat
If you want to access the router configuration page, follow the steps mentioned below:
If your IP starts with 192.168.X.X or 198.162.X.X then open internet explorer( http address box) and type 192.168.1.1 or 198.162.1.1 and it will prompt for User ID and password
Default User ID " Admin" or " Administrator"
Default Password " password " or " admin "
This will help you to access router page.
Note: To perform these steps you need to be connected via Wired LAN cable to Laptop and the main internet cable to be connected to router.
Thank you
gowtam1402@live.com
091-9916828137
Jan 02, 2011 | D-Link DIR-600 Router
Hello i am having probelms with my Belkin g basic router it has wireless and it works but when i connect it to my computer it does not it says it can't find or something but if i plug in my other box that...
It's sounds like you're getting your cords mixed up. The modem (the box from your company that provides internet) needs it's power cord plugged in, a phone cord or a cable cord plugged in, and an ethernet (LAN) cord plugged into it. The power cord will plug into the wall obviously, the phone cord or cable cord will be coming out of the wall obviously, but the Ethernet (LAN) cord will plug into your computer or a router. A router in your case. So the Ethernet cord from your modem (box that came from you company that provides internet) will plug into the router in the specific slot that says Internet or Modem connection. Now you need another Ethernet cord to go from your router to your computer. Try to plug the cord that goes from the router to the computer into the 4 different ports on the router until one of them works, you'll have to give it about a min to check each one. If that doesn't fix it then you need to make sure your LAN card is being read correctly and installed correctly, best way to do this is to go to Start > Control Panel > Device Manager and look at Network Adapters. If there is a Red X next to a conenction, right+click the conenction and tell it to enable, or update drivers.
Dec 13, 2010 | Belkin (F5D7231-4) Wireless Router
Changed internet companies now router won't work
I'm sorry but I find your post a bit confusing. Do either of the computers get on the internet?
Changing internet providers is something done INSIDE the router. The cables are irrelevant.
Nov 10, 2009 | Computers & Internet
Changed from AT&T to a cable company for DSL. Trying to set up
You need to "fool" your cable box into thinking that the wireless router is the computer. This just means that the modem is locking into the first ip address it can get... it tends to block out all others. Here's how to remedy and allow everything to get access...
1 Shut off computers, routers, everything.
2. Turn on your wireless router FIRST... leave everything else off until you see it's completely booted.
3. Then with the cable connected to the modem/cable box and the router, turn on the cable box/modem and let it cycle up. This should allow the cable modem to "find" the wifi ip address as the main ip.
After that, turn on any other routers, and the computers...
This should allow you access to the net by any of your computers because the wifi router should give all the other comptuers and routers on the system inddividual ip addresses and all should be well...
Give it a try and let me know!
K
Aug 28, 2009 | 2wire (1000-400108-001) Router
Dlink dir-655
  • call dlink support to configure the router
  • but if you can powercycle first the modem router and pc
Aug 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Internet connection
If you are able to connect on other computers, then check the ip address of your main computer.
steps to check ip...
1. First connect your router and your computer with ethernet cable.
2. Click start->run>type in the run box as "cmd" without quotes..
and then click ok.
It will take you to command prompt screen...there you will find a cursor flashing Type next to that as ipconfig and then press enter...
It will give you the "ipaddress' of your computer and "default gateway" i.e. the ipaddress of your router...
check if you get this and then let me know
Feb 16, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
69 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
