Question about LG LHD45EL Dehumidifier
Fan will not come on.
LHD45EL Dehumidifier. Fan will not come on. The compressor is running and building pressure but then shuts off after it gets really hot. Is there a fuse on the machine somewhere or do I need to replace the fan.
    Scholar:
  • 79 Answers
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
Posted on Nov 15, 2009
    New Friend:
  1. My 70 pint Danby was found dead and pieces of the fan all over in and out., Got a new fan but motor would not run it works fine now Why did the fan break. fixed a 200 dollar machine for a little over 50.00 .and a cou;ple of hours of my labor. J F Sample
Posted on May 24, 2013
The compressor turns on, but the fan does not run. No water collects.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 08, 2011 | LG LHD45EL Dehumidifier
My dehumidifier is running but is not pulling any water. I have the humidity control set at 35 and havae cleaned the filter
these units lose some to most of their charge in 2 to 3 years,if the compressor is very hot to the touch its low on R-134a refrigerant
Jul 19, 2010 | LG LHD45EL Dehumidifier
My LG LHD45EL all of a sudden
Short on refrigerant... or a failed compressor. are most likely or a system problem, causing it to trip off.
There may also be a failed electrical component, you need to check for voltage at the compressor.
cheers
Jul 02, 2010 | LG LHD45EL Dehumidifier
Dehumidifier starts up but will shut down right away
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers2_bing.gif that run but do not extract water from the air..
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 23, 2010 | LG LHD45EL Dehumidifier
The dehumidifier isn't taking the moisture out of the air.
is the compressor in the unit hot to the touch,or are the coils freezing and thawing when it runs<if so you probably need to add some R-134a refrigerant,these type of units are notorious for losing all or part of their refrigerant charge,but unless you have the equipment to remove old refrigerant and vacuum the system down and recharge it it can get costly
Apr 15, 2010 | LG LHD45EL Dehumidifier
Should the compressor be on and the fan be off?
compressor re moves the mosture from the air. if you have high traffic in rm it will run all the time
Apr 13, 2010 | LG LHD45EL Dehumidifier
I HAVE 4 EA NEW LHD659EBK DEHUMIDIFIER and they make lots of noise and vibrate a bit, this is normal in these Dehumidifiers ..
These can be noisy.
Does the noise only happen when the compressor runs? These compressors float on rubber bushings to isolate the vibrations and maybe one of the three nuts on the mounting studs may be loose.
The fan bearings can also wear out.
Nov 21, 2009 | LG LHD45EL Dehumidifier
Runs but does not collect water.
compressor run but gas charge not enought
so it not very cool,and no water come out
Aug 23, 2009 | LG LHD45EL Dehumidifier
Just bought a new dehumidifier. does the fan
it should shut off when the compressor is not running. only portable a/c can have fan running constantly
Jul 03, 2009 | Dehumidifiers
LG LHD45EL Dehumidifier Logo
727 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
