Question about Linksys Wireless-G WRT54G Router
Need to open some ports - Linksys Wireless-G WRT54G Router
    Guru:
  • 1,738 Answers
It is under administration tab.
Posted on Nov 15, 2009
I cant open port for Zhone 6211-I3-200 Router
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
Click Here
for more info
Dec 17, 2009 | Zhone 6211-I3-200 Router
I am trying to open the router ports to allow a ps3 to connect. when i try to play call of duty:modern warfare 2, i keep losing the connection. can you help me open the ports and configure the settings?
For example ,
You have a Linksys wireless router and you want to open the ports for the X-box.
You have opened the set up interface of the router. You will see Application and Gaming TAB at the top.
If you click on that tab you will find different Sub tabs.
Click on Port Triggering => Here you can open the port numbers for the network.
Click On Port forwarding if you want to open the ports for a special device in the network.
Click Save settings once you open the ports on the router.
Some of the recommended port numbers for different applications :
IMAP ==> 143 SMTP : 25
HTTPS ==> 443 HTTP : 80
DNS ==> 53 FTP : 21
SNMP ==> 161 TELNET : 23
XBOX ==> 53, 80-88, 3074
PS3 ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
WII ==> 28910, 29900, 29901, 29920, 80, 443
VPN ==> 1723, 500, 443-447, 10000-20000
World of Wars ==> 3724, 6112, 6881 - 6999
Click Here for more info
Dec 13, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
HOW TO DO THE PORTFORWARD
For example ,
DNS ==> 53 FTP : 21
Dec 06, 2009 | Belkin F5D8631-4 Router (F5D8631au4A)
I need to open my router ports
Here are the steps to open ports for your playstation:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5.Click on Advance settings (under setup) and choose port forwarding
6, Add a new port address,port number etc (It is the address of your Playstation and the port to be opened)...
The most common of these are TCP and UDP ports which are used to exchange data between computers and the Internet.
In order to use some games and features on PlayStation Network the following ports should be opened:
TCP: 80, 443, 5223, and Port Range 10070 - 10080
UDP: 3478, 3479, 3658, and 10070
This is how the port can be opened, for more information please refer the following link given below..
http://kbserver.netgear.com/kb_web_files/n101145.asp
PORT OPENING
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Nov 01, 2009 | NetGear DG834G Router
Dose this router work as a firewall switch?
It is not possible to close all the ports on the router.
you can open other ports.
by default port 80 is open on the router.
On the router there is no such setting to close the port.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
Open port on router for peer to peer downloading
The port you need to open depends on the specific application you're using.
Go to the website of the application you're using and search their support area for port settings or firewall configuration settings.
Some applications have a user forum where you can find the answer as to what ports are required to be open.
Here's an example of the ports that would need to be open for Limewire: (this does not mean these are the ports that need to be open in your case)
In LW tools > options > advanced > firewall config. Change LW's listening port to 65000 (or try any ports in the range of 49152 - 65535) > apply > ok. If you have port forwarding set up for a modem/router, you'll need to change the port forwarded to match LW's new listening port. If you have a specific port number allowed thru a software firewall, make sure that you allow LW's new port number.
Jun 29, 2009 | Computers & Internet
I am trying to get xbox live working on my xbox 360 console but I need to open some ports and I dont know how , how do I open the ports ? I need to open the port 3074 and I need yo use (UPnP) because I...
Okay so Here is the very simple solution. Go to your router page (192.168.1.254) and select Custom Services. Delete every port opening service you have made. Then Define a Custom Service lets just call it Xbox A and Open ports 80 - 65535 for TCP with the base host port 80 Do tthis twice for both TCP and UDP options. Enable the services on your Xbox (It needs to be Connected and have a static IP adress) It can take about 15 minutes to open all the ports to be patient. Your Xbox also needs to have a static IP adress. Lastly set the routers firewall on low and give it a shot. It worked for me!
Jun 26, 2009 | Netopia 2247NWG-VGx Wireless Router...
Need a port opened to speed up downloads
Hi. It really depends on what type of modem or router you are using to open up ports. Also if you are using an application for downloading such as Bitcomet, you need to find out what port or listening port is currently configured on Bitcomet. for example, the listening port on Bitcomet is 4545, then you have to open port 4545 on your router or modem.
You also need to make sure that your modem or router has port forwarding features..
you may also visit this link for instructions on how to forward or open ports to different types of routers...
http://portforward.com/
May 10, 2009 | Computers & Internet
Hangs with Bittorrent
That is because you need to open a port on router with the same number assigned to your torrent client.
You need to check port number on bittorrent configuration, then access router control panel typing router IP on internet explorer address bar and configure the router to open the port.
Read the following articles.
How to configure your router to allow fast BitTorrent downloads
Brian's BitTorrent FAQ and Guide: What ports does BitTorrent use
Slow Bit Torrent downloads? Router configuration tips.
Opening port BitTorrent |
forum.bittorrent.com / how to open firewall/router port
Guide to Open or Forward Ports for Utorrent and Azureus BitTorrent
Port Forwarding for the Netgear WGR614
Tweaking your system to get the most out of BitTorrent
Apr 13, 2009 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
