WON'T TURN ON 4 BLINKS,REPLACED IC 800,NO HELP.
  • 2 more comments
  • tonynhutnguy Nov 15, 2009
    SOME BLINKS 4 TIMES,SOME BLINKS 5 TIMES.
    THIS TV IS DIRECTVIEW ,NOT LCD OR DLP.
    SONY KV-27FS320 ,NOW BLINKS 5 TIMES.
  • tonynhutnguy Nov 16, 2009
    SONY KV-27FS320 5 BLINKS,WON'T TURN ON ,REPLACED IC800.
  • 10,594 Answers
Can you tell me where is IC800 located in TV?
I been checked complete manual and couldn't find IC800, though IC801 is located on V board.
5 times blink shows problem of AKB (white balance) need to adjust Screen (G2) volts in TV.
I can solve your Tv problem as I have info, let me know what was initial problem and what parts have been replaced so far.
Thanks.
Posted on Nov 16, 2009
  • 448 Answers
If there is sound from the TV but no pictures and the indicator on the front of the TV is blinking four times then check if the projection lamp is okay.
Otherwise replace the projection lamp.
Posted on Nov 15, 2009
  • 1 more comment
  • Rahul Prashant Singh Nov 15, 2009
    Tony, four blinks indicates overheating and five or more blinks indicates an issue with the Optical block or light engine of the TV.
    Check the capacitors on the horizontal circuit as some of them may be causing the problem. Horizontal circuit board is: "If you look on the circuit board near the flyback (the large transformer with the big red wire coming out of it) about 3 inches in front of that is the horizontal circuit area".
    The following is the information indicated by the blinking pattern of the indicator on the TV:
    2 times : Power does not come on.
    Load on power line shorted.
    3 times : The TV has entered standby mode.
    4 times : Has entered standby state after
    horizontal raster.
    Vertical deflection pulse is
    stopped.
    Power line is shorted, or
    power supply is stopped.
    5 times: No raster is generated.
    CRT Cathode current detection
    reference pulse output is small.
    6 times: No picture
    9 times : No sound
My JVC HD-56FC97 won't turn on.the power and lamp indicator flash alternately. i just replaced the bulb but that didn't help.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 21, 2013 | Sony KV-36FV26 TV
Sony trinitron 2001 32" blinking red 4 times,
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
The vertical output IC and its related circuit parts should be checked. If you are handy in elelctronics, visit this site 'Electro-help'. All details about this fault are given here. Type in 'electronicshelponline.blogspot' into your browsers' search box, and click search. Pull up older posts there.
Jun 24, 2012 | Televison & Video
KV32FS120 blinks 4 times
4 times blink shows TV got problem in vertical deflection section and vertical out IC (IC561) either missing supply volts or itself bad.
Hope this info will help you if you are thinking to repair this TV.
Aug 30, 2009 | Sony Televison & Video
The stand by timer blinks continuously
Unpluggnig the set will reset some things, but not an error code. The 4 blinks usually means a lack of vertical deflection. If you can solder, you should be able to fix this yourself. Be warned however that there are dangerous high voltages inside the set even when unplugged.
That being said, try locating the vertical IC which will be a small flat IC attached to a heatsink that will be marked LA7837 or something similar. Try resoldering the pins on that IC first. If that failes to resolve the problem, replace the IC and post your results here. There may be other components that need to be replaced, but they will show up as other symptoms once the IC is replaced.
Dan
Jan 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Won,t turn on.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. check the vertical deflection IC and circuit
Nov 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Stuck in standby
The 4 blinks indicate a vertical deflection problem. Either the connections on the legs of the vertical IC are bad or the IC is defective. If you can solder, you can fix this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony Trinitron won't turn on...has 4 blinks in Standby.
This may be a vertical circuit problem. IC1509 is usually the vertical IC. If you can solder, I would first try an resolder the pins on this IC. If that fails to resolve it, replace the IC. This IC is a small flat IC attached to a heat sink with about 11 pins. It will be marked LA7837 or something similar. Feel free to post the marking and I'll confirm you have the correct IC.
Keep me posted.
Dan
Sep 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sont kp-46wt510 blinks 4 times
IC1509 8-759-593-33 IC LA78045 35.98
Q1505 8-729-423-33 TRANSISTOR 2SC3311A-QRSTA
Replacement part
8-729-119-79 TRANSISTOR 2SC2785-FEK-HFE 1.02
these ic locations are different than yours but same part number.
is there a 2sc3311 near by LA78045?
Jan 10, 2008 | Sony Grand WEGA KDP-51WS655 51" Rear...
Televison & Video Logo
180 people viewed this question
Top Televison & Video Experts
Electro Med Services...
