Question about Bosch Dishwashers
I have a Bosch SGI4005 AU/12 dishwasher that needs a new door seal, is this a common seal, or is it a seal for this model only? can I use any other type of seal? regards Peter
textonor
  • 130 Answers
SOURCE: Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Posted on Jan 06, 2008
  • 833 Answers
SOURCE: Dishwasher draining - Bosch SGV4313GB/17
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
Posted on Feb 11, 2008
SOURCE: dishwasher leaking around the bottom of the door
We just had the very same problem and sure enough a flexible cutting board was over the outlet...very strange but thanks
Posted on Mar 12, 2008
SOURCE: Bosch Dishwasher SGS5302 AU/12
The machine starts and enters wash cycle but will not move on from there and continues washing
Posted on Jul 13, 2008
I had the same problem in 2004, lots of Bosch trained repair techs, calls to Bosch, and the appliance dealer we purchased it from with no answers. Our kitchen cabinet bases were ruined by the flooding that occured. After months of trying to get help I insisted on speaking to a supervisor that told me it was my fault for putting a flexible cutting board on the right side a blocking the vent. I told her that no where in the manual did it mention this issue and none of their trained techs were aware of this flaw in their design. When I asked about getting my cabinets repaired she said that was not an option. When I mentioned possible legal action her response was "good luck with that". Here it is 2009 and they recently called about a possible fire hazard recall for the control panel. The Bosch trained tech that came out to complete the repair knew nothing about the vent/flooding issue.
Posted on Aug 06, 2009
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
Bosch dishwasher door tension
Most dishwashers have big springs that run front to back at the bottom sides of the body. These are the door springs. Tension is adjusted by moving the spring to one of several holes in the frame. One way will give you less tension on the door the other way will increase it. If the dishwasher is new, why not call service and let them deal with it. Should be under warranty.
Mar 24, 2015 | Bosch Dishwashers
Bosch sgs5312gb leak
More than the door seal, check the water level is not stuck down or sinking. If the appliance is leaking from the door, this is often because of overfilling. If the machine is not overfilling, then replace the door seal.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 04, 2009 | Bosch Dishwashers
SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH DISHWASHER, ALSO WATER JUST DRIPPING THROUGH SPRAY ARM
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Mar 09, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Belt in dishwasher answer
the only thing i think of is that it is part of the door seal, have a look if the door seal has come off
Jan 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher Soap Dispenser Fails to Latch
Need to replace dispenser. I have access to that part; let me know.
Nov 26, 2008 | Bosch SHU9925UC Built-in Dishwasher
Jan 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHV45M03UC dishwasher door leaking
the latching mechinisum is at fault or the door is bent.
Apr 07, 2017 | Dishwashers
Bosch sgs43a32uk/01 dishwasher
clean filter outlet, pipe is ok ..remove stainless steal screws in side door it should be easy to fit seal then.
Nov 27, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
42 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
