Question about Brinkmann Charmglow 810-7600-S Grill
1. flame is the same, wether set at high or low. 2. turn on 3 burners and they almost go out. seems like there isn't enough gas flow to run even 3 of 5 burners
  • 187 Answers
Make sure your burners are clean and not blocked with lava rocks or anything. If that's all good, make sure that you are turning the tank off before you light it. This is really important, b/c if you light it with the tank already open, there is a safety device on most tanks that won't let the gas flow. After you try relighting after having the tank turned off for 30 seconds, make certain the valve on your tank is working. Turn the tank completely off. Open the hood and make sure you don't smell and gas. Without turning the gas on at the tank, turn the knob to light, and see if you get any flame. If all of that checks out, It is probably the gas regulator. They are relatively cheap and easy to replace.
Posted on Nov 15, 2009
I have pyromaster gas logs that has low gas flow
Sounds like a ventilation problem... they're not getting enough air. That's a real safety problem. Make sure they have enough fresh air, and that the room itself does also. This issue is a major safety problem, and if more ventilation does not fix the issue, stop using it! Gas burners are not supposed to stay on without a flame present!
Apr 12, 2017 | Heating & Cooling
Low flow to the burners. Probably because of spider webs
Yes, sometimes spider webs can cause it, as well as the OPD valve in the gas tank locking up the grill's regulator. In addition, a low pressure can be caused my low fuel in the tank.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Sep 23, 2011 | Lynx L36FR (LP) Grill
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
We have intermittent low gas flow to our Viking grill. We have replaced the burners and the regulator. It worked fine on Sunday but now today only the first burner lights (and it's low even though I...
Lynn, the problem lies with the gas regulator and the way you turn the tank ON. But it's readily solvable.
1. Turn the tank valve OFF & disconnect the hose from the tank.
4. Once the valve is fully open, light the burner farthest from the tank first and set it on HIGH.
Does the flame height look correct? If so, light the remaining burners the exact same way.
Do all the flame heights look correct? If so, your solved the problem. Always remember to
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. They run about $30.00 at any hardware store or home center that sells grills and accessories. Simply take you old one with you for comparison purposes.
Hope this helped you troubleshoot & solve the problem. Please let me know. Thanks.
Jul 06, 2011 | Viking VGBQ410-3RT Grill
Grill does not get hot enough. Which seem like low gas flow. One burner does not light
Yes, it is probably low gas flow. I assume you feel comfortable that there's a reasonable amount of gas in the tank.
Here's what you need to do. Turn OFF the LP Tank Valve and disconnect the hose from the tank. Wait 5 minutes. While you're waiting lift out the tank. Does it feel as heavy as it should? Or does it feel lighter than it should? If it feels lighter, you're either very low or have run out of gas.
In either case, here's what you need to do when you reinstall that tank or a new one. Attach the hose to the tank. Turn the tank valve On VERY, VERY SLOWLY ( I'm talking slow motion). Once the valve is fully open, light the burner that's farthest from the tank and turn it to the highest setting. Does the burner flame look correct? If it does, light the next burner and turn it to high and continue doing that until all the burners have been lighted. If the first burner flame doesn't look correct after you lit it. Turn the tank OFF and repeat what you did previously. If it still fails to produce the right flame heights, either the venturri valves on each burner are clogged or the regulator is locked up.. You will have to remove the burners to clean them. If that fails to solve your problem, buy a new grill hose and regulator. You can purchase it at either Lowe's or Home Depot or your local hardware store. Just be sure to take yours with you, so that you can get the right length and brass fitting size matches.
I'm sure this will solve your problem. Please be kind enough to let me know.
Happy Grilling
Rich
Mar 04, 2011 | Char-Broil Advantage 463453306
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
Low flame from gas cooktop
you can adjust the flames as follows pull a knob and look in the end of the brass peice you will see a small screw first you have to find a screw driver that will fit then with a pair of pliers hold the outer peice with the burner on and turn the screw one way rasies other lowers ideal adj is to turn buner all the way up then fast down if flame goes out to low keep working like that till flame is low but doesnt go out
Dec 30, 2007 | Kenmore 30 in.32232 / 32239 / 32234 Gas...
Brinkmann Charmglow 810-7600-S Grill Logo
172 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
