Question about 2wire (1000-000057-000) Modem
2 wire gateway..trying to go wireless....shows excellent signal but limited or no connectivity.
    Scholar:
  • 78 Answers
1. Try to determine whether you can connect to the Internet
Start -> Control Panel -> Network and Internet Connection
-> Network Connections -> Right Click Local Area Connection
-> Properties -> Internet Protocol (TCP/IP) ->
Use the following IP Address,
IP Address: 192.168.0.2,
Subnet Mask:255.255.255.0,
Gateway: 192.168.0.1
2. Reset modem and rebooted the computer
3. Check cables if they are properly installed unplug and replug
4. If issue where not resolve contact your ISP service to check if it's the connection or hardware issue " ISP service has a tool that can run a line test determining where the broken connection is."
Posted on Nov 16, 2009
LIMITED OR NO CONNECTIVITY WITH AN EXCELLENT SIGNAL STRENGTH WITH TWO NOTEBOOKS
Wireless connection ...limited connectivity
If you connect the computer to the router , does it works? If the wired is on line that means the wired connection is OK.
Open the set up page of the router check the
wireless settings of the router.
I think your network is secured and you are not
typing the correct network key.
just open the router set up page and check the wireless settings.
Click Here for step by step solution
Feb 28, 2010 | B&G Computers & Internet
I have a 2 Wire network adapter on my desktop pc
If you can see many Wi-Fi nets at your area, try changing the settings especialy the channel transmition for your net.
Stelios.
Feb 21, 2010 | Computers & Internet
There is no connection between my Belkin router and Internet. I took my laptop and router to a service rep who stated everything worked fine in his shop. That is was the ISP who needed to be called. The...
Reset the router . CHeck if you can get a wired connection on your computer working . if it is not update the bios and the wired and wireless drivers. try reseating the wireless nic card as well .
Oct 19, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Samsung NC10 will not connect to any network
If WLAN and Wireless cards are enabled, then you may have to unplug your router for 10 seconds to reset it. They tend to build up a static charge. Unplug wireless router for 10 seconds, plug back in and you should be fine in a minute or two with full connectivity
Aug 20, 2009 | Samsung NC10-14GW Notebook
Can not connect wirelessly with router
The list of wireless routers that are available in Windows is very limited and the signal strength of any router that is detected is weak. This can occur when the Lite-On USB Wireless 802.11 b/g hardware and Windows are not able to fully synchronize the signal strength data. Figure 1: Example of detected wireless devices when the antenna cable wire is connected to secondary port c01153759.jpg Figure 2: Example of detected wireless devices in the same environment when the antenna cable wire is connected to primary port c01153760.jpg To correct this error , download and install Lite-On USB Wireless LAN Driver Update (sp35177) (in English) from the HP Web site. This update should only be applied if your PC has the Lit-On USB Wireless LAN adapter and is exhibiting the symptom. As a work-around, you can connect the wire that runs from the wireless antenna port to the primary port on the cord as follows: CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Open the side panel.
  2. Find the wireless networking board by following the antenna wire connected to the wireless networking antenna port on the back of the computer. Figure 3: Wireless networking hardware c01153761.jpg 1 - Wireless network board 2 - Antenna wire 3 - Wireless networking antenna port
  3. Very carefully, disconnect the small wire from the board by gently pulling the end of the wire away from the board.
  4. Connect the wire to the other available port on the board. Figure 4: Available port c01153762.jpg
  5. Replace the side panel, connect the power cord, turn on the computer, and use the computer again to verify that wireless signal strengths have improved.
Jan 14, 2009 | Acer Aspire 4520-5582 Notebook
Wireless shows connection,but will not connect.
This kind of problem occur due to dhcp disable in the wireless router for the security purpose. So try to give the ip adress manually by right clicking on the wireless and give the ip adress of the same range in which your network in working e.g 192.168.1.0 is the range of your ip addresses so please select the ip which is not been used by any other computer and than in default gateway enter the ip address of you wireless router and you will be able to access the internet on your system.
Dec 01, 2008 | Linksys Wireless-G WRT54GS Router...
I have tried to install router strait from modem to router to toshiba l30 laptop belkin shows up on laptop showing excellent signal but when i try to go on web it cannot make contact
access your routers administration by right clicking your network icon and using your gateway IP to access http://*gateway*
un - admin pw - (none), admin, public
look at your status in the belkin administration settings and see if you have an ip and gateway for your ISP.  The ip and gatway on your computer is for your belkin.
Try directly connecting the laptop to the router with a cable and see if it's on the net. If it is then you have wireless settings wrong. See belkin.com for more infor about router.
James Mac
Aug 02, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Wireless internet
You could try to manually set your IP address in the TCP/IP, the gateway and your ISP DNS
Feb 09, 2008 | 2wire (1000-400108-001) Router
Wireless Internet Connection
Are the wireless router connected to a network?
Oct 18, 2007 | Gateway Belkin 54g Wireless DSL/Cable...
2wire (1000-000057-000) Modem Logo
274 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
