Question about Remington Shotgun Mount 12Ga Lh, B Square 16801, 870, 1100, 1187 12ga In Catagory: Optics, Rings, Bases and Mounting Systems, B Square Rings, Bases and Mounting Systems, B Square Shotgun Saddle Mounts
Will not cycle
Rem 1100
    President:
  • 2,702 Answers
Your shotgun may just need a realy good clean up,,,look in the gas by pass ports in the barrel are they blocked up with crud! clean the piston and cylinder remove all the carbon use very light oil on this part,,strip the action to clean it out of unburnt powder,,,,also they dont like soft rounds,,stick to fast heavy loads,,they love them,, but birds hate them!!!
Posted on Nov 15, 2009
Where connect rem connection
rem goes to the back of the headunit to a cable (blue or blue/white) that should say, either rem out or power continuous (PO CON) and needs to connect to the amplifier where it sais rem power(12v)
hope this helps
...andy...
Jan 05, 2014 | Car Audio & Video
Remington 1100 wont eject or load another shell
check and see if the shell stop hasn't broken loose. this on the inside left side of the action . this could stopping the next shell in the mag. from being loaded. this not uncommon. but is an easy fix. a gun smith can stake it back in . in a few minutes for around $20.00
Nov 25, 2012 | Remington Shotgun Mount 12Ga Lh, B Square...
After market trigger for Rem 742
You can try this spring from erniethegunsmith:
http://erniethegunsmith.com/catalog/i36.html
Or the 870 Trigger Fix from Timney:
http://www.brownells.com/.aspx/pid=32078/Product/REM-870-1100-11-87-TRIGGER-FIX
The 742 is an old gun. Not much made for it now.
Jul 06, 2012 | Car Audio & Video
Draw a flowchart to enter a number from 1 to 7 and display the corresponding day of the week
1 rem zero out all variables housekeeping
10 let a=0
15 clear $today
16 rem get input
17 input a
19 rem choose corresponding day of the week
20 rem case structure
25 if a=1 then $today="sunday"
30 if a=2 then $today="tuesday"
rem ect til saturday
rem use data created
40 print "today is";$today
Apr 27, 2011 | Computers & Internet
My remington 1100 does not cycle do i have to change seals
Check to make sure you have the seals in the right position, 99% of all automatics out there are set up wrong. My 1100 cycles perfectly with low brass, high brass, magnum, reloads, you name it. My first 1100 was a joke, it wouldn't cycle at all, that is when I learned all about those pesky seals. Go to gunparts.com, they have an exploded view of every gun made just about, you will be able to see the seals set up. Check your vent holes in your barrel, Hope this helps.
Mar 10, 2010 | Remington Shotgun Mount 12Ga Lh, B Square...
My ML 1610 Laser printer was working just fine a few minutes ago but it suddenly stopped printing and now the lights are blinking. It seems to be in this order 5 red 1 green 9 red 1 green 7 red 1 green...
please your problem is printer in rem and sarket in ice is fail. and you go to the near autho. dealer and changing the serket board
and checked the rem. and printer's services is fine.
Oct 03, 2009 | Samsung ML 1610 Laser Printer
My Candy GrandO washing machine is boil washing
sounds like overheating, don't use until you have had it checked, may be dangerous
Sep 29, 2009 | Candy CNW136 Front Load Washer/Dryer
Powers isnt turning on but everythings hooked up?
Check the fuses. If the fuse is bad the amp's power supply is burnt. If the red light stays red and never goes green then your amp is in protect mode and the output section is burnt.To test for rem. problem just use a jumper wire (paper clip... or whatever)to jump from +12v power to rem. If rem. wire has no voltage when your radio is turned on that will make your amp come on. then look for the fuse in the rem. line. Good luck !
barneyluc
Oct 03, 2008 | Car Audio & Video
Remington Shotgun Mount  12Ga Lh, B Square 16801,  870, 1100, 1187 12ga  In Catagory: Optics, Rings, Bases and Mounting Systems, B Square Rings, Bases and Mounting Systems, B Square Shotgun Saddle Mounts Logo
177 people viewed this question
Top Remington Cycling Experts
Piyal Perera
Piyal Perera
raysaw
ray gallant
Are you a Remington Cycling Expert? Answer questions, earn points and help others
