Question about Toshiba SD-V295
DVD won't eject from Toshiba DVD player. I have already taken cover off and can manually engage the tray. When I try to eject with the remote I just get a little ''lock'' icon on my TV screen.
Press setup subtitle 3 audio 0 to unlock ...worked for me. Thank a user on Videohelp.com for solution:
http://www.videohelp.com/forum/archive/toshiba-sd-v295ku-locked-tray-solved-t362810.html
Posted on Dec 09, 2009
  • mandywalters Dec 29, 2010
    Finally!!!! Thank you so much for the excellent solution. I had tried everything and was about to ditch my combo (that has not even been used that much!) I tried your trick and it worked the first time. Thanks again!
  • 456 Answers
Try removing the disc if not already done as it may be a jamming issue, otherwise check the child lock isnt on with the unit. Good Luck.
Posted on Nov 15, 2009
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
LG v181 won't eject - it tries to load even when there is no disc and won't slide out the tray at all.
It's likely a belt that drives the tray has snapped or come off! If you take the top off you might well see it!
Dec 23, 2012 | LG V181 DVD Player/VCR
I tried the manual and the remote......still doesn't open
unplugged the unit and then re plugged and turn it on again while pressing the eject button, let see if it does. if still won't open, at this time you are going to remove the cover so you can access the internal part. you need check weather their is an stuck up on the rail motor for the loading tray or the motor belt not aligned.
Nov 09, 2012 | Sanyo DVW-6000 DVD Player/VCR
How to change toshiba sd-412v region 1 to free region?thanks
Hi friend. Try this:
Press the power button on the Toshiba DVD player remote. Press the "Open/Close" button to eject the disc tray. Remove any disc that might be on the tray before proceeding.
Press the following keys on the remote in this order: 2,4,0,3,9,6,0.
Press the "9" key on the remote.
Press the "Open/Close" button to close the disc tray. Press the power button to turn the Toshiba DVD player on.
Hope it works.
Jun 16, 2011 | Toshiba Televison & Video
DVD in the wrong way; won't eject
Apart from taking it apart! or forcing the disc tray out "DON'T" !!! try switching off at mains holding eject button continuosly pushed in and put mains back on, sometimes this causes a full "re-boot sequence" which from experiance and several attempts, does throw me the tray open!
May 20, 2009 | Toshiba LCDTV/DVD Player 19HLV87
Stuck dvd in the machine on top of one in there already - cannot eject - help
If you are comfortable taking the cover off, you can try removing the cover and remove the dvd's yourself.
IF you are not comfortable removing the cover then, you can try to take a credit card (Actually, if you have any of those JUNK credit cards that the CC companies send out as trial offers, those work the best, and who cares if you bend those, they get tossed anyway) and bend an edge at a 90 degree.. (about 1/8" of the edge) so it makes like a small ledge. try to fit it inbetween the top of the door, and then see if you can open it up. Some players have a seperate door, and some trays are attached to the door. You might be able to help it out or unjam the tray this way.
And in the Future, with any other CD/DVD Players, use your remote control or the open and close button to open and close the tray, and NEVER Push on the tray itself. If I had a dollar for every dvd player tray that Ive fixed because of this, I would be buying bill gates dinner. (not really, but you get my point)
Good luck.
Mac =)
Please post a rating or feedback if I have answered your question.
Mar 21, 2008 | Televison & Video
DVD tray will not open
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Feb 25, 2008 | Dual Presidian DVD Recorder
DVD will not eject
some have a pin hole under or next to the tray that you can put a paper clip in to and push it in.
other wise you have to take the cover off and take it out.
Jan 22, 2008 | Toshiba D-VR600
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Oct 16, 2007 | GoVideo Go Video DVD/VCR Combo
Toshiba SD-V295 Logo
2,204 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
