Question about GigaFast Ethernet Easy 500-S 5-Port Ethernet Switch (EZ500-S)
I need to know the voltage on the power supply as it is not marked on the router. gigafart ethernet router ez-500-s
  • 12 Answers
9V 1A www.gigafast.com/tech/usermanuals.htm page 10 of your manual.
Posted on Nov 15, 2009
Gigafast ez800s power supply voltage
Looking inside helps it says 7.5vdc 1a I tried it with a precision power supply and it works on that voltage. Wish they would remember to put that on the outside as well.
Bill ccr
Feb 13, 2014 | GigaFast Ethernet GigaFast EZ 800-S...
Hello, where can I get wall charger for Xact x2x wrist walkie talkie? I'm from Mumbai-India.
your device should be marked with polarity and voltage requirements. Any power supply with the correct plug meeting those specs (if amperage isn't marked, look for one that is between 500- 1000 mA) should be fine. MAKE SURE it is a DC supply if the device you are using is marked DC.
Oct 22, 2013 | Xact Communication Radio Communications
Hi, I have a Linksys WRT56G2 V1 Wireless Router that worked just fine until 2-3 days ago... Now when I plug it in the power light is off, the internet light is on, the wireless light is off, and the 4...
1. the power supply to the unit has a malfunction.
the power light should be green to say that the unit is getting proper voltage if you see no light then the power supply is probably not working
If router is under warranty has manufacturer send a new one to you.
2. Try unplugging the router first for 30 second to a minute to see if your unit will restore if not a new unit is needed.
Oct 18, 2010 | Linksys WRT54G2 Wireless Router
Second time this has happened, Apricorn ez bus dts power supply
You can use a universal Adapter.
All you need to do is to match the correct voltage and the correct Ampere.
Lets say for example the input of your adapter is : 100-240v, 50,60hz . and 0.5 A
the output is : 12vor 5v 2A
So check this that correspond to the one you already have.
But one thing :: don't use one that is of a higher voltage capacity.
It will burst out forever the disk........
If you need any further help please let me know.
Regards
Uttam
Jan 29, 2010 | Apricorn EZ Bus DTS (EZ-BUS-DTS-500e) 500...
Mains power supply failed completely - who sell replacements?
Most stores sell multi voltage adaptors that are quite capable of running routers the only thing you reall need to check are the voltage and current requirements eg. 5 v 500 mA this is usually written on a label on the router either underneath or near where the power supply plugs in.
Any adaptor that meets or exceeds that specification will do then it is just a matter os electing the correct end (they come with a variety) to match your router.
Also check if you need centre positive or negative and set the adaptor to suit this also.
It is usually way cheaper than buying one from the manufacturer and also a lot quicker way to replace almost any pooched power supple that comes in the form of a "wall wart"
Sorry if it sound complicated but I assure you it isnt.
Aug 09, 2009 | Belkin (F5D7230-4) Router (587009)
Voltage/Ma of AC adapter for WR1500??
The power supply on my ParkerVision WR1500 router is 12 vdc, 1.2a, center pin positive. http://straylightsoftware.com/downloads/parker2.html
Oct 29, 2008 | ParkerVision SIGNALMAX WR1500...
How to install a linksys router to my desk top for my wireless laptop
1. plug in the router
2. connect the router to your DSL or Cable Modem using the supplied ethernet cable
3. connect the router to your computers ehternet port with a second piece of ethernet cable
you can use catagory 5 ethernet cable , or catagory 6
Most linksys routers have 4 to 5 ethernet ports to connect computers to.
One of the ports will be marked as the one to connect to your DSL or Cable Modem
Usually when looking at the back of the router the WAN port will be located to the far left.
Thank you for choosing FixYa!
Az.
Sep 19, 2008 | Computers & Internet
Routers
Hi Like,
Unplug the router, Don't hook it to anything but you PC you are have the CD in. Use the cable that came with the unit, plug it into your pc ethernet port and one of the 4 ports marked LAN. Make sure not use the port marked WAN. Make sure you use the ethernet cable, not the USB. Power up the router, and put the easystart cd in. Once it autostarts, press the Easy Setup button on the router for about 8-10 sec. The Easy Setup on your screen should respond. From there out, follow the prompts.
For the manual, follow this link.
http://support.asus.com/download/download.aspx
The quick start should solve your setup connection issues, if you have any. Also, make sure you have your firewalls disabled. And re-enable them what you are done, to be safe!
Good Luck!
Jan 06, 2008 | Computers & Internet
GigaFast Ethernet Easy 500-S 5-Port Ethernet Switch (EZ500-S) Logo
798 people viewed this question
Top GigaFast Ethernet Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a GigaFast Ethernet Computer and Internet Expert? Answer questions, earn points and help others
