Question about RCA WHP141 Consumer Headphones
New rca whp141, charged for 16 hrs, ready to use, all lites on, correct channel, NO SOUND other than humming. I had to use adapter to a smaller size for sony tv. any help? also, tv has jack for audio right and left. how do I handle that? Thanks, Joe
    Problem Solver:
  • 6 Answers
Take one side of the wires out and see if you get sound. if no sound try to reconnect them.
Posted on Nov 16, 2009
How do I connect a Manfrotto - 026 Swivel Umbrella Adapter (Lite-Tite) to a tripod?
Deborah
If you bought the Manfrotto #026 Lite-Tite new, it should have come with (2) brass adapters..., ((1) with male 1/4-20 & 3/8-16" threads & (1) with female 1/4-20" & 3/8-16" threads). All universal photo tripods made in the last 30 years use these (2) thread sizes. All you should need to mount this unit to a tripod is the 'female' adapter spud. If you are missing this item..., it is a Manfrotto #119 adapter (available through most photo dealers).
Peter
Jan 29, 2013 | Bogen Manfrotto 026 Swivel Umbrella...
A low humming noise
A low quality power supply pack (brick) to the wall outlet is most likely to be the cause of your problem.
Look for the power supply pinout and test it with a replacement power pack.
Plug the power pack onto the same power strip of the audio source (Example: your tuner) will also help rule out grounding problem.
Turn off any motor operated item (example: heater fan) to rule out noise from other appliance.
Apr 24, 2010 | RCA WHP141 Consumer Headphones
The jack will not fit in my tv
There are lots of different sized jack plug adapters on the market, you should be able to find one to do the job. I would try Amazon first, they have a good range and decent pictures of products.
Feb 11, 2010 | RCA WHP141 Consumer Headphones
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
Radio Shack Headphones 900mhz
You can download the instruction manual here.
http://66.77.167.109/rcaaccessories/RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&ACTION_CATEGORY_IDSTR_CATEGORY_HEADPHONES&ACTION_PRODUCT_ID=WHP141
Mar 23, 2008 | RCA WHP141 Consumer Headphones
RCA wireless headphones
Hey, my rca whp141 is incredibly quiet. Go ahead and turn the volume up on the TV.
If that doesn't work make sure
  • The headphones and headset are on the same channel (like 1).
  • the transmitter is on and working (Power: GREEN LIGHT)
  • the headset is on and working (GREEN LIGHT)
  • the headset is receiving a signal (St: GREEN LIGHT).
Hope this helps.
Jan 08, 2008 | RCA WHP141 Consumer Headphones
Sound diminishes....
Did you initially charge the batteries per the instructions? You must FULLY charge them for 16 hours, then let them TOTALLY discharge (without putting them back on the charger) and TOTALLY charge 3 more times. If you do not, you will lose life in the batteries.
Good luck
Oct 18, 2007 | RCA WHP141 Consumer Headphones
Adapter plug size
Wal-Mart ectronics dept. has an "Universal DC Adapter Kit" it will have various size adapter plugs and a variable setting to adjust DC Voltage. It also should have a switch to set the polarity. I used mine to power several different devices. It was well worth the money I spent as opposed to buying a actual DC Adapter. Subsequently, the kit from Wal-Mart was far cheaper than the real deal.
-marshall.
Albuquerque, NM
Aug 28, 2007 | RCA DRC620N Portable DVD Player
RCA WHP141 Consumer Headphones Logo
477 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
