Question about Kitchen Appliances - Others
Dryer wont start. checked fuses and toggle switch
  • 161 Answers
Check door switch and start switch.
Posted on Nov 15, 2009
  • 77 Answers
How about door switch?
Lg dryer wont start lights on on but wont start
Check the thermal fuse, start switch on the control panel and door switch because all three are more likely the cause of the dryer not starting up.
The door switch is often the culprit in this type of fault, although a faulty drive motor is not ruled out.
Mar 10, 2014 | LG DLE2514 Electric Dryer
Dryer wont start
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details. Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Amana Dryers
I have an Dual brand 300 watt amplifier that I just bought and I hooked everything up right (battery---power, ground----sanded metal, bypassed remote with toggle switch remote-----+terminal on switch...
Is your toggle hooked to ground? Hook your toggle switch to the battery and then the other end of that toggle the remote input on the amp.
Aug 15, 2010 | Car Audio & Video
Dryer wont start
Check the following to address this issue.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
Jun 03, 2009 | Kenmore Dryers
Dryer wont start
First I would check the door switch I could have broken off or quit working if that is ok then there is a white thermal fuse on the blower housing behind the back panel check with a ohms meter to see if it is good it has two wires going to it
Mar 30, 2009 | Maytag Dryers
Wont start
did you check the door switch,and the heating element(make sure it's not grounding out,check to make sure you have 120volts coming in on both legs-mike
Mar 16, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer does not start - Thermal Fuse is ok.
Good to know, when the appliance does not start at all is always thermal fuse, wiring, door lock switch, or rarely the control assembly.
Have a nice day.
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore gas dryer won't start.
Hi!!1 You have a shorted thermal fuze on the dryer..The thermal fuze is located in the back of the dryer its white and oval with 2 wire leads..replace it and you should be fine..good luck..
Dec 26, 2008 | Kenmore 73952 Gas Dryer
Kitchen Appliances - Others Logo
37 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
