Question about Westinghouse Televison & Video
Polaroid dvr 0900 - stopped working alltogether. Power will not come on either by power button or remote. Fan is working.
5 Suggested Answers
SOURCE: Polaroid DRA-01601A will not power up
these units are famous for capasitors popping in the power supplies.
Posted on Jun 05, 2008
  • 226 Answers
SOURCE: DRM-2001G weak remote
The range problem with the remote can be fixed by replacing the LED in the remote with a Radio Shack 276-143. The LED is a lot stronger and now the remote works a lot better.
You may also find that the 'receiver' inside the cabinet is pointed at an angle instead of directly towards the 'window'. You can trim the rubber(?) to allow it to point correctly.
Posted on Apr 29, 2009
  • 6 Answers
SOURCE: purchased astar dvr-2100 dvd recorder. power button
Can you be more specific? Is there anything on the display? Or is the red power light on or off? Some more detail is needed.
Posted on Dec 23, 2009
Testimonial: "no power at all. unit does not respond. power lite does not come on."
tariq_romy
  • 116 Answers
SOURCE: remote control power button and stop/play/home dont work
open the remote clean with petrol
or ony from dry cloth
thare was a corben in that key becouse that key are more useable so carben
Posted on Feb 19, 2010
Tip
DISH VIP612 Program AUX Remote Code 2
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | Televison & Video
Tip
DISH Solo DVR VIP612 Program TV or VCR Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR 612 to control your primary TV or a VCR? (Instructions to setup a receiver, tuner, stereo, second TV or second VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a primary TV or a VCR:
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR 612 User Manual.
  3. Press and hold the mode button (TV or VCR) until all the other buttons light up, and then let go. The mode button will flash.
  4. Enter one of the three-digit codes from the tables in the manual.
  5. If you want to program Limited Mode, press 1. If not, skip to the next step. (You can add or remove Limited Mode later.)
  9. If the code didn't work, repeat steps 3 through 8 with the next device code from the tables in the manual.
Your device control codes for your TV or VCR are now programmed into your DISH Solo DVR VIP 612.
Help for programing a tuner, receiver, 2nd VCR, or 2nd TV using the AUX mode button can be found here.
I hope that helps.
on Jul 05, 2010 | DISH Network ViP 612
My tv is set on zoom3 and i dont have my remote control,; what can i do? I've bought universal remotes but no luck!
Doesn't appear to be a good way to do this without the remote, you can try to do a factory reset,
Factory Mode Procedure
1.Power on TV.
2.Press volume up and channel up buttons on the TV simultaneously and release.
3.Power off TV with remote or power button to exit.
If this doesn't work you can get a polaroid replacement remote here:
http://www.discount-merchant.com/Polaroid-RC-201-Remote-Control-p/remote-9039.htm
Apr 01, 2011 | Polaroid FLM-323B Television
Phillips DVR Model DSR704...fan works, black screen, no powing up
the power supply is bad.
I had to same problem with mine after a power outage. Luckily I had a spare TIVO series 2 receiver with an identical power supply. Popped it in the busted TIVO and I am back in business.
Apr 24, 2009 | Philips DSR704
Polaroid flm-2011 20 inch lcd television
 I will be happy to help.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Jan 24, 2009 | Televison & Video
I bought my Polaroid 373-B without a remote. I then bought a RCA universial remote that has worked until it dropped the codes. Now, I can't find the list of codes to re-program the remote. Can someone help...
Hi stevieb44, I am happy to help. Turn your TV on.
  1. Press and hold the TV button
  2. While holding the TV button press and hold the Power(on/off) button, the light will go out and then come back on.
  3. Release both buttons, the light should remain on.
  4. Point the remote at the TV.
  5. Press the power button repeatedly until TV turns off, wait about 5 seconds between pushes.
  6. When TV turns off press the Stop button at bottom of remote, that will lock in the code.
Let me know if this helps and please rate this solution. Lone99star
Jan 18, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Samsung DVR Combo no work
There is a small hole next to the power input socket. You are supposed to power down, hold the button in and power up, then hit the button again and hold until the menu screen comes up. Mine does not work, but that is about what it sayw in the manual.
Jan 25, 2008 | Samsung SSC DVR Digital Video Recorder...
Need 3 digit remote code for Cyberhome DVR 1600 PLEASE HELP!!!
Don't know if this is what your looking for but give it a try.
How to convert your CyberHome CH-DVR 1600
into a Region Free DVD Player
There are two versions of the Cyberhome DVR 1600 which require different methods of changing the Region Coding
CH-DVR 1600 MU
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
CH-DVR 1600 ZU
  3. Press the Red Record button on your remote control
  4. Press the 8 button on your remote control
  5. Press the 1 button on your remote control
  6. Press the 0 button on your remote control
  7. Press the 5 button on your remote control
  8. Press the Red Record button on your remote control
  10. Press the Setup button on your remote control
Jan 02, 2008 | Cyberhome DVR 1600 DVD Recorder
Ellion DVR-950S
Ellion DVR 950S Festplattenrecorder.
Please help me.
I have a problem, that the Power on/off Display get never out - it is a loop - power on an than power off power on .....
I diconnect the line (power cable), but it is the sam again. There is no more - other funktion by the recorder.
Thank you for help
walter-august
Jan 02, 2008 | Ellion DVR-530S DVD Recorder
Televison & Video Logo
50 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
