Question about Panasonic SDR-H40 HDD Camcorder
Message on camcorder when trying to download "Please connect ac adaptor" if i flick to still pics they download no problem.
    President:
  • 2,702 Answers
Its becouse the camera knows your on battery power and to save your dater it plays safe and wonts more power that cant run out half way in the down load
Posted on Nov 15, 2009
Testimonial: "Thanks for your reply thanks for details. Les "
Finepix won't acknowledge camera when it should...DCIM folder does not appear on tree. this happened twice, then the 3rd time i tried to download pix, the AC adaptor went pfft and gave out a cloud of...
Well, first of all, get a new AC adaptor. Do your pics appear on the camera? If so, just get a separate card reader to download your pics to a folder you create on your desktop. This one is $13 at Walmart. da139e4.jpg
Jun 11, 2010 | Fuji FinePix 2800 Zoom Digital Camera
I have a sony pc 100 dv cam. I am trying to find the right cable to connect it to my mac. I need what ever sony uses one one end and usb on the other.
your camcorder doesnt support usb connection.although it came with a pc serial cable,its the cable used for memory stick picture transfer, along with it comes a serial port adaptor for the memory stick and ac adaptor for serial adaptor. of course even if you lost this accessories you can still transfer pics from the ms using a memory card reader which works basically the same way. for videos on the tape you would just need a firewire or an ilink (ieee1394) cable. almost all mac computers support this connection.it's the dv in/out jack on the camcorder with an i symbol.upper most jack on the camcorder jack's location.check your mac to find out what cable you need.the unit uses a 4pin ilink port so you need a 4pin ilink cable at one end and the other end should match of course, the firewire port on your mac computer.should be a plug and play connection.you can use imovie software for video capturing.hope this helps.thanks :)
Mar 11, 2010 | Sony Handycam DCR-PC100 Mini DV Digital...
How do i know if my battery or the charger is the problem causing my camera not to turn on
If the camera works when the AC adaptor is connected its the battery, if dosent work with the AC adaptor, its the AC adaptor.
Jan 22, 2010 | Sony DCR-DVD610 DVD Camcorder
When i connect my camcorder to my pc and try to download videos it says connect ac adaptor, why?
Because it takes FOREVER to download. Don't trust the battery to get you through. It's a very slow process. The purpose the adapter is to protect your videos.
Oct 04, 2009 | Panasonic SDR-H40 HDD Camcorder
Uploading pictures
Cameras can't upload if low on power. Charge batteries or plug in the ac adaptor to an outlet and try again.
Sep 12, 2009 | Panasonic SDR-H40 HDD Camcorder
Hi I have DRC-SR200 camcoder, bought one year ago. Issue is lens cover is not opening. On the LCD display there is a message "lens cover not fully open. Turn off and on". I tried that but no use. Went...
Hi, perform the following steps to get this issue resolvbed... 1. Check whether the lens cover is opened 2. check whether the battery is fully charged. If the battery is not fullly charged, connect the Camcorder to the wall outlet using the sipplied AC adaptor. 3. Then, try resetting the Camcorder by pressing the RESET button using a sharp-pointed object while the Camcorder is turned ON. 4. If the issue still persists, turn OFF the Camcorder; then remove the battery pack and discinnect the Ac adaptor from the Camcorder; slide the POWER switch to the ON position for 1 minute. Then, connect the AC Adaptor tro the wall outlet and cjeck whether it helps.
If the issue still persists, service of the unit may require. contact the manufacturer of the Camcorder to get ut serviced.
Jul 10, 2009 | Sony Handycam HDR-HC1E HDV Digital...
Panasonic sdr-h40p cannot connect to my pc
hi all, i had exactly the same problem and finally managed to sort it out, here to share with u all. The AC adapter is the one looks like a battery cable which comes with the camcorder. You have to remove the battery first, and plug the AC adapter into the place where the battery was, then connect the other end to the battery charger. Now you can select the PC connect option and transfer your videos. Hope it helps. =)
Aug 25, 2008 | Panasonic PV-GS500 Camcorder
Panasonic VDR-D250 - PC Connection problem
I have the same camera did u click on finalize or something and then its says connect to ac power if yes just get your battery charger and u get this thing that helps u see explore ur camera by also charging the battery at the same time just connect it to the camera and it wont say anything like ac power afterward.
Jan 20, 2008 | Panasonic VDR-D250 DVD Camcorder
USB connection is not recognised by computer
Where can I download the Panasonic video camera model no. VDR-D300 from the Internet?
Nov 14, 2007 | Panasonic VDR-D300 DVD Camcorder
Panasonic SDR-H40  HDD Camcorder Logo
918 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
