Question about Guillemot Thrustmaster® Run 'N' Drive 3 in 1 Rumble Force for PC, PlayStation 2, PlayStation 3
It is possible to use a gamepad with Crossfire internet free game?
Trying to add a Bluetooth device but it's not connecting. I read that I might have the 'ADD NEW DEVICES' turned off. but I can't seem to find where to turn it on... or if that is my problem at all.
Connecting a Bluetooth Gamepad
(MENU/123) MENU System Device Manager Bluetooth Gamepad Settings
You can play the games downloaded and installed using the Smart Hub service with a Bluetooth gamepad. Select Bluetooth Gamepad Settings, and then place your Bluetooth gamepad close to your TV. The TV scans for available Bluetooth gamepads automatically. (DualShock®4, a gamepad optimized for PlayStation, is recommended.) After scanning, you can use the Bluetooth gamepad to play games.
  1. This function is not available on certain models in specific geographical areas.
  2. If the TV fails to find your Bluetooth gamepad, place it closer to the TV, and then select Refresh. For more information on pairing, refer to the Bluetooth gamepad's operating manual.
Feb 22, 2017 | Option Computers & Internet
Free unlocking codes
Free Unlock code is not possible to get for Sony Ericsson Xperia Play.It's latest Phone...You need to pay for it...Visit the site Simpleunlocking.com/sony-ericsson-xperia-play/rs16wp9/ get Unlock code and get Free Unlocking instructions at Mobileunlockguide.com/sony-ericsson-xperia-play and unlock it step by step.
Sep 18, 2012 | Sony Ericsson Xperia Play R800i Unlocked...
Can not play online games with gamepad F310 controler
when i play online games it works with the keyboard but not the gamepad i tire the internet to help me but it is not working
Jan 16, 2011 | Logitech (9633260403) Game Pad
LOGITECH RUMBLEPAD2 ON VISTA PC
You can start from OPTIONS in the main menu of any game and then choose CONTROLS. There if you have both the options : keyboard/gamepad, then only you can use the gamepad.
Then if you have the Gamepad option there, then select it and configure/assign the gamepad keys for your game. You can do it by going onto an option; lets say ACTION and then click the Gamepad key you want to assign. Hold down that Gamepad key and double click the mouse. There you go.Your Gamepad is up and running for your game.
Cheers.
May 04, 2009 | Logitech Rumblepad 2 Game Pad
Spiderman WoS and Incredible Hulk (2008) don't respond to gamepad
its not problem with your gamepad. Its the problem with game both games. It has a bug problem. It cant install gamepad. dont try it again & again as it may damage the game pad internal configuration. pls rate for me .
Feb 05, 2009 | Logitech (9633260403) Game Pad
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
Trying to use controller for call of duty 4 on pc
All hail! Here is your solution. Download this profile complete with instructions. No hassle, no problems!
http://rapidshare.com/files/252613129/Call_of_Duty_4_Rumblepad_2_Dual_action_Profile.rar
Nov 08, 2007 | Logitech Dual Action for Pc (963292-0403:)...
Guillemot Thrustmaster® Run 'N' Drive 3 in 1 Rumble Force  for PC, PlayStation 2, PlayStation 3 Logo
599 people viewed this question
Top Guillemot Video Game Consoles & Games Experts
shaun taylor
Chris Larocque
Michael Vincent Cruz
Are you a Guillemot Video Game Console and Game Expert? Answer questions, earn points and help others
