Need to replace lid switch in older model maytag. where is this part located and what does it look like
  • 68 Answers
Usually attached to the underside of the machine's top. Small box with wires. Probably activated by either a post that sticks down thru the top from the lid or a lever moved by the lid hinges.
Posted on Nov 15, 2009
Maytag lse7806ace
open and close the lid,if you don't hear a clicking sound you just have a bad lid switch,you have an older machine and it has a cherry switch in it,go here and look at part number 5
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-dryer-combo-Parts/Model-LSE7806ACE/3048/0152000/M0601018/00016?blt=06&prst=0&shdMod=LSE7806ACE
part number 208823,all it is is a safety so the washer can't run with the lid open so it will fill and then stop because the switch is bad.
Jun 06, 2013 | Washing Machines
Hi. How do you get to the lid switch on a Maytag
You must remove the rear control panel housing...
Remove some clips - and then remove the basin surround.
Here is a video that will help you out without having to type out the entire instructions. It is a general instructional that covers just about all the manufacturers.
Thanks for using FixYa!!
Aug 05, 2009 | Maytag MTW5900TW Top Load Washer
Need to replace safety switch. How do I remove or lift the lid to replace switch?
If you are referring to the lid swtich on a Whirlpool manufactured top loading washer (such as Estate, Kenmore, Roper, Frigidaire and some later model Maytags), the following link explains step-by-step:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions, please post back with your MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
May 03, 2011 | Kenmore Washing Machines
Centennial washer, will fill with water, wont spin or agitate, power is good
Easy fix. Lid switch is bad. This is a direct drive machine. Older models would wash but not spin these latest babys won't wash or spin with the lid switch broken. To access te switch you flip up the control by using a putty knife to release each end. Older models had a screw that needed to be removed, not so with the newest ones. The switch has 2 hot wires and a ground wire. Jump them 2 hot wires and see if she runs
Video: How to get into these machine:
How it works
Apr 30, 2011 | Maytag Centennial MTW5800TW Top Load...
Center peice will not turn
If everything else is working and it just won't spin, there is good chance that all that is wrong is a bad lid switch or the lid switch actuator. The lid switch's location depends on the brand and model. But usually you can find a little slot around top of the washer where the lid closes. You should be able to push a pencil into it and here it click. That is the switch. On the lid, there should be some type of actuator (stick that goes thru the hole) when it is closed. On older Whirlpools, the actuator was bad about popping off and falling into the tub. On older Maytags, the switch is behind the lid..under the lip.
When the switch if broken or the actuator doesn't actuate the switch, then the machine thinks the lid is open and , for safety reasons, won't allow the drum to spin. If you can't find the switch locally, you can order it online.
Hope this helps
Jan 21, 2011 | Washing Machines
How do I replace the lid switch on a Maytag
Well the model # you listed goes to a Whirlpool machine so here goes.. The screws that hold the control panel on are located at the rear bottom of the end caps for the console/control panel, not the screws at the top of the control panel..
Once you remove those screws the control panel should slide forward 1/2 inch or so the up, and flip right over backwards towards the wall.
Once that is flipped up you will see the lid switch located in the left front corner under that console. Remove the 5/16" ground screw from the green wire, lift the connector release and remove the wire from the switch. Then carefully depress the plastic tab to release the switch and it should more or less lift right out.. No need to disassemble the entire cabinet.
whirlpool #8318084 $15-20 buks depending on where u are..
best of luck, have fun,
ttfn
Feb 03, 2010 | Washing Machines
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Wont start cycle after filling with water
check your lid switch should be on back of machine or under the lid
May 17, 2009 | Maytag PAV2300 Top Load Washer
Maytag LAT 9420
open the lid if it doesn't click check the lid switch,on the older maytags if they went out of balance the lid switch would sometimes stick,your washer is old and i can't see some of the lookups for it,like i said if you open the lid and you don't hear a clicking sound when you open and close it you have a problem with the lid switch,there's a plastic plunger part on it that could have broke or moved when it went off balance go here to see it
https://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/12001908/916383
this is for model number LAT9420AAE you have to send the full model number to look it up.hope this helps,if it's not the lid switch send your question again with the full model number so whoever answers you can look up your model to get the correct parts.hope this helps you out.on some models you can reach in just above the tub and feel the switch to realine it back up but you might have to open up the top console to get at it.
Jan 11, 2018 | Maytag Dependable Care LAT9706
Maytag stacked washer/dryer Model LS7804
OK it may be one of 2 things. I would check the lid switch first. On some maytags the have a lid switch that if it is not working properly it will not let the washer fill. If it will not fill the washer will not wash because the pressure switch did not activate the timer to wash. If the switch checks good you might have a bad timer. If you open the control panel you will find a tech sheet with the wiring diagram. I would follow the fill cycle and check the components. You might also check the water valve to make sure its ok too. But its very rear that both the hot and cold would go at the same time. Good luck!
Jul 11, 2007 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
Top Washing Machines Experts
