Convering the 3 prong plug to a round plug - Washing Machines
  • 77 Answers
Hi just take the plug cover off the back of dryer and u will see 3 posts red to red black to black the two outer posts those are your power make sure you put them on the outer posts!! white in the middle and look for a green screw thats were the green wire goes.If there isnt one ground it to the body,ok.
Posted on Nov 15, 2009
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
Fisher paykel electric dryer replacing a 4 prong plug to fit a 3 prong receptacle
Hi sheriduay
Go to the following webpage and it will show you how to conver 3 wire to 4 wire or 4 wire to 3 wire.
Please take time to rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Mar 22, 2013 | Fisher and Paykel Dryers
FISHER PAYKEL REPLACING A 4 PRONG PLUG TO FIT A THREE PRONG RECEPTACLE
Explanation.
Inside the rear of the dryer is a row of 3 screws/nuts.
The right and the left of those 3 are "hot".
You will attach the red and/or the black leads to those "outside" 2 screws, doesn't matter which.
The center wire is white wire only, it is a ground.
For the 4th wire, it will attach to the body of the dryer, it is also a ground.
P.S. On both the 3 prong and the 4 prong, the HOT wires ( red and also black ) are straight/flat lugs.
The "L" shaped lug and the round lug (4 prong only) are both ground.
Be blessed.
Mar 22, 2013 | Fisher and Paykel DEGX1 Electric Dryer
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
I just bout a new electric dryer but the plug thats on the wall will not fit so y went and bout a new plug but the new plug takes 3 wires and the in the wall takes 2 can i still use the new one
TO BE SAFE...I WOULD PURCHASE THE CORRECT PLUG WITH THE TWO PRONGS THAT FITS YOUR OUTLET!
IF YOU HAVE THE CORRECT PLUG... YOU CAN USE THIS ONE...BUT YOU WOULD HAVE TO BREAK OFF THE GROUND PRONG BY BENDING AND WIGGLING IT, IT IS THE THIRD PRONG SEPERATE ON THE BOTTOM! IT SHOULD LOOK STRAIGHT & ROUND!
HOPE THIS HELPS...WOULD APPRECIATE A RATING...THANKS!
KIND REGARDS!
Sep 08, 2011 | Frigidaire FEQ332E Electric Dryer
Can I convert a 3 flat pin female power cord into 3 round pin to fit a 1970's style appliance
The flat prong plug is for 220 to 240 volts. Converting it to a round hole connector won't work. As they are not approved for 220 to 240 volts. It will overheat.
Mar 16, 2011 | Heating & Cooling
Have a 2004 caliver the has a bad miss i change pluges,fuel filter checked valves checked wires seems like number 3 plug not firing changed some plugs a round didn't help the pipe after the cat conver with...
Hello! It is glowing red because it is plugged up and the metal is getting hot. It is a serious fire hazard, don't drive the vehicle until you have it replaced...The engine is missing because the exhaust is plugged...
Guru.Saailer
Feb 07, 2011 | 2004 Chevrolet Cavalier
I have an hfd-135 air purifier but i can't tell if it's 110 or 220 volts.
View the electrical plug.
A 120 Volt plug has two elongated prongs on one side, with a smaller round prong for your ground, on the electrical plug.
A 220 Volt plug has two elongated prongs, but each will be opposing each other in the middle, but tilted towards each other at the top. Also, on a 220 plug, the third prong will not be round, but flat, and in a horizontal position.
Nov 15, 2010 | Health & Beauty
Power cord hook up
Hi Jay
Middle terminal is White and goes to the "L" shaped prong
Red and Black go to the Flat prongs (Doesn't matter which)
Round prong to cabinet Ground.
There may be a strap from the White lug to the cabinet. This must be removed for the 4 prong plug arrangment.
Eric
Jun 08, 2009 | Electrolux Dryers
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
