Question about Kenmore Washing Machines
Washing Machine sometimes overflows - Kenmore Washing Machines
    President:
  • 2,702 Answers
Your washer has a blocked over fill pipe if you cat take the back off you will see a small pipe going up from the bottom of the brum to the velve block pop it off and blow through it to clear it, you wont get any more over fills after that
Posted on Nov 15, 2009
4 Suggested Answers
  • 6 Answers
SOURCE: top loading Maytag washing machine is overflowing
water level switch is bad
Posted on Mar 30, 2009
  • 72 Answers
SOURCE: washing machine overflowed
Try filling it again and stay with it, when it starts to get near the top, unplug it, if water continues coming out you need a new valve, if it stops, then the level switch inside the control panel is bad
Posted on Jun 17, 2009
jsrock516
  • 5911 Answers
SOURCE: KENMORE WASHING MACHINE WATER OVERFLOW
Is this a TOP LOADER? Or, a FRONT LOADER? This problem is commonly attributed to either a leaking water inlet valve, or a pressure switch malfunction. The following links explain how to diagnose the problem and repair as necessary:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
The easiest and most common cause of this problem is the small plastic air hose on the pressure switch coming loose. It can usually be fixed by simply reattaching the hose. However, read through all the information provided and double check everything to make sure.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Apr 15, 2010
Testimonial: "Thank you I will check this out and thanks for the quick response."
MY WASHING MACHINE WONT STOP FILLING SOMETIMES
suspect the pressure switch is failing
Jul 03, 2016 | Washing Machines
My Bosch classixx washing machine is overflowing
Bad water pressure switch or bad water inlet valve? does it have or leak water in the tub when not in use? ( inlet valve) sometimes the pressure switch tube has a hole or blockage in it and will not have the pressure needed to open diaphram and go into wash cycle and it may overflow
Mar 09, 2015 | Bosch Washing Machines
My Whirlpool AWG5122 washing machine keeps overfilling, it seems to take in water to the point of overflowing, I have to turn the water off at the mains in order for it to stop taking water in.
sometimes if the door switch of that machine is not working so there is no auto stop of filling water. or the pressure switch may be not function well.
Dec 09, 2010 | Whirlpool AWG5122 Front Load Washer
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
Our washing machine sometimes over flows water!!!
Could be a faulty water level switch or sediment in the base of tub partially blocking the air pressure tube. Remove the tube at the switch/control and blow it out, then re-secure it tight.
Mar 13, 2010 | Washing Machines
Hoover 500M Top Load washer - Water overflow & machine wont wash
Probably very repairable but impossible to say how much without looking inside and fiddling around and checking a few things.
Fault could be caused by several possible faults at widely varying cost.
I suggest you call a friendly local white appliance engineer...
Feb 13, 2018 | Hoover Nextra HNT 2135 Top Load Washer
Washing Machines Logo
66 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
