Question about Lexmark X5250 All-In-One InkJet Printer
I had a paper jam and removed all of the paper, but the printer is still saying to remove the jammed paper. I don't see anymore paper and I even ran a few sheets of paper through the printer to help clear any paper that I could not see. I unplugged the cords to see if that would help and it didn't. Any solutions?
  • 34 Answers
I ahd this problem to the onlt thing you could to is reboot the system.
Posted on Nov 15, 2009
It says paper jam remove toner but there is no paper jam at all
Try power cycling the printer. Otherwise there is a paper jam or a sensor is dirty. Every time I hear someone say there is no paper jam I almost always find one. Use a flashlight they can be very very small.
Dec 18, 2012 | Office Equipment & Supplies
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
Tried to print and it says remove paper jam and press start, tried that several times, put more paper in, powered off and it stil says paper jam...opened it up and no paper i can see thats jammed..
Jan 06, 2010 | Lexmark Pro X125 All-In-One InkJet Printer
Turned it on and it says paper jam. There is no
Dec 22, 2009 | HP PhotoSmart C4280 Laser Printer
PAPER JAM PRINTER SAYS PAPER JAM IN INPUT TRAYS BUT PAPER DOES NOT SEEM TO BE JAMMING
Dec 11, 2009 | HP LaserJet 4050 Printer
Machine says there is a paper jam when there is no jam. Shows jam in exit but the paper never even starts to get picked up from the main paper cassette but it will feed fine frome the mp tray. any...
Dec 08, 2009 | Samsung SCX-6320F All-In-One Laser Printer
My printer says remove jam when I try to print, even when there is no jam
Your printer see's a paper jam. You must find and remove the jam or have unit serviced.
If you can feed a piece of paper front to back without stopping, you should be ok.
Nov 24, 2009 | Canon Office Equipment & Supplies
Saying clear paper jam, I have done, there is no paper jam
Clearing a paper jam in a Lexmark laser printer is an easy thing to do. Laser printers produce high-quality products and are fairly complex machines, but paper jams (in most cases) can be solved mechanically with a little know-how and time. Follow these steps to learn how to clear a paper jam in a Lexmark laser printer.
  1. ep 1 Take the paper out of the paper trays. This will prevent any more paper from being drawn into the printer to further the jam.
  2. Step 2 Remove the cover from the housing of your Lexmark laser printer. This will expose the inner workings of the printer, and you also should be able to see the jammed paper.
  3. Step 3 Pull gently on the jammed paper. In many cases this is all that is required; the paper jam should move out slowly and smoothly.
  4. Step 4 Press the flashing paper jam button. This will allow the rotors to turn freely, which will facilitate the easy removal of the jam.
  5. Step 5 Unplug your Lexmark laser printer if the jam persists. This will allow you to pull more firmly without the gears working against you.
  6. Step 6 Examine the inner workings and confirm that all paper and shreds of paper have been removed. If the paper tore during the clearing, make sure none remains or it will inhibit normal printer function.
  7. Step 7 Plug the printer back in, refill the paper tray and try to print again.
    • Make sure to use a printer and paper type that are compatible. Consult your owner’s manual and the manufacturer’s Web site.
    • To deal with a large jam, it might be necessary to pull sheets from the middle of the jam in order to loosen the whole thing.
    • Always pull the paper “with the grain” of the mechanism, if possible. Pull it through the printer the way paper normally travels so that you don’t go against the gears.
    • For more serious repairs, contact an electronic store or professional repair person.
Nov 24, 2009 | Lexmark X4580 InkJet Printer
Paper jam on my i560
there is a small paper very small paper stuck in the printer remove it it will work
Nov 09, 2009 | Canon BubbleJet i560 InkJet Printer
Paper jam, need help urgently!
First check the Paper feed roller they maybe slick from paper dust, you need to clean them, then turn of the printer and remove the ink cartridges, turn macine over and check the under side of the machine for any sign of paper, remove any seen, then turn back over reinsert cartridges , turn machine on. paper dust sometimes covers the paper read sensor , causing a paper jam, and slick feed roller also contribute to frequent and pervasive paper jams.
Jul 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
Lexmark X5250 All-In-One InkJet Printer Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
