Question about Brother XL-5130 Mechanical Sewing Machine
Loading bobbin into bobbin case problem - Brother XL 5340
When I put the bobbin into the bobbin case, as described in the manual, and pull thread down into slot and to the left, the thread ends up just above the long delivery eye. It goes through a small hole on the inside of the bobbin case and so looks quite different than the diagram in B-3 (page 19 of the manual)
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
informatica
  • 1114 Answers
SOURCE: brother xl-5340
You can download the manual from the link below: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000062/xl513052325340ug01enesfr.pdf It has diagrams of how to thread the machine. There is also a FAQ section: http://welcome.solutions.brother.com/BSC/public/us/us/en/model_top/HomeSewingMachine/hf_xl5130eus.html?reg=us&c=us&lang=en&prod=hf_xl5130eus Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 17, 2007
  • 729 Answers
SOURCE: bobbin thread
if you could gain access to the bobbin compartment then cut all the tangled threads, then carefully/gently pull it out. after you pulled it, clean it, leave no threads on it and put some oil on the bearings! good luck
Posted on Feb 28, 2008
SOURCE: how do i thread the bobbin
I have a new sewwing machine Eurp-pro Shark automatic but I don't know to thread the bobbin
Posted on Oct 11, 2008
  • 323 Answers
SOURCE: threading lower bobbin
There are some different bobbin cases for different machines but the one you have is a pretty common one with a finger sticking out on top. If you examine the bobbin case you will see a slot on the side of it and there is another piece of metal screwed onto it. This is the tension they are describing.
To thread it properly, turn the bobbincase upside down and insert the bobbin in the case so you can see it. Place your thumb on top of the bobbin and pull the thread through the slot on the side of the case and under the piece of metal(the lower tension) which I described to you earlier.. When you have done that, remove your thumb from the bobbin and pull on the thread. It should have some tension on it.
Next,placing a thumb or finger on the bobbin to keep it from falling out, turn the bobbin case over.
Keeping the finger sticking up lift the lever on the
front of the case and insert the bobbin and bobbin case onto the spindle inside the hook assembly(The part that is in the bottom of the machine that turns when the hand wheel is turned.) Don't worry about the thread that is sticking out.
Holding the upper thread under the presser foot ,turn the handwheel towards you until the top thread pulls the lower thread to the top. Pull the thread to the left of the machine, insert your fabric, lower the presser foot and begin sewing
One more thing , The finger sticking up on the bobbin case will go into a slot on the ring holding the hook inside the machine.
Hope this solves your problem.
Be sure you thread the upper part properly. It should go through the tension, then the take up lever and then the needle. Tension should be set at around 5
sewman7
Posted on Jan 17, 2009
Bobbin thread cluming up
Make sure you have a tight wind on the bobbin, and it is free and clear of any lose threads. Also if replacement bobbin make sure the size is right for machine model. To thin of one causes them to bounce up and down putting tension on thread as it is sewing.
May 22, 2015 | Brother XL-5340 Mechanical Sewing Machine
How do I remove the outside case for my Brother xl 5340.
If you do that, you'll void the warranty on the machine. You may already have. If the "turning wheel" (handwheel) is stuck, then most likely either the machine has seized from lack of lubrication or thick lubricants, or you've got a heck of a thread jam going on in the bobbin case and feed dog area.
Feb 14, 2014 | Brother XL-5340 Mechanical Sewing Machine
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
Bobbin thread too loose makes loops and the top thread easily pulls out
try adjusting the top thread tension & see if that solves the problem
Oct 11, 2010 | Brother XL-5340 Mechanical Sewing Machine
Motor locked up and there isn't any tangled thread anywhere in the machine. Pressed the OK button and it still is jammed
try unthreading completely and make sure that the bobbin casing allows thread to come up when you rethread the machine. Make sure that you are turning the handwheel towards you not clockwise, because you can mess up the timing. Read the manual for other suggestions.
Sep 08, 2010 | Brother XL-5340 Mechanical Sewing Machine
I have a Brother XL3010 and I can't get the tension set right. The bottom thread keeps making loops. What am I doing wrong? thanks stampinjean
try and adjusting your bobbin case tension ,the little screw on the bobbin case. with bobbin in case hang by thread if it drops easy tension is to light cotton should be able to slightly move through the case. hope this helps reguards
Feb 26, 2009 | Brother XL-5340 Mechanical Sewing Machine
Machine not sewing
Have you checked that the tiny screw in the bobbin is not loose, sometimes this creates this problem for me or if the bobbin size is incorrect.
Dec 13, 2008 | Brother XL-5340 Mechanical Sewing Machine
Brother XL-5340 sewing machine
Try a new needle, making sure it is put in properly. A bent needle can break thread. Make sure top tension is set properly.
Dec 01, 2007 | Brother XL-5340 Mechanical Sewing Machine
Brother xl-5340
Aug 17, 2007 | Brother XL-5340 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
231 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
