Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The tv makes a sizzling sound when you turn it on. No picture ever shows up and then it cuts back off.
    Genius:
  • 1,112 Answers
You may have a bad Scanning Cap in the High Voltage Power supply, if so then check the neck of the picture tubes for cracks usually the green tube is affected by this. If one of these caps goes bad High voltage goes through the roof and cause a tube to crack at the neck. While turning on the set look for arching around the tubes, Also check the main deflection for burnt tracings around the HV scanning Capacitors, they are usually Square in shape and may be yellow or gray in color. IF the board is burnt then scraping the coating of the tracing and resoldering the pin to the board and then sealing it with rubber compound will usually work in this instant. Saving the time and money. This board can be sent for repair. as a new one is probably no longer Avaible.
Posted on Nov 15, 2009
  • 456 Answers
What you may need to do is check that the lamp doesnt need replacing, if you have found that it has reached its expiry you need to make sure to reset the lamp use hours so the tv recognises that the tv has a new lamp inside it. Good Luck.
Hi my sansui tv sv29281 takes time to show pictures after i switch it on & when it becomes on, it produces weid sound...what could be the problem, pls help
If the sound is a high pitched, sizzling sound then it is most certainly a high voltage problem. If you feel capable, take the back of the set off and in a darkened room turn the set on. I would imagine you will see high voltage arcing somewhere around the transformer, trippler or lead that connects onto the back of the screen. (not the picture tube). If you do, this area will need to be investigated. Make sure the set is turned off and has been off for at least half an hour as there are very high voltages still present due to high voltage capacitors. Make sure that the plugs are right and insulate any earthing points around the area with simple elastoplast tape. Any holes in the trippler, ( a plastic box looking thingy), can be covered with a hot glue gun or silastic. Good luck and please take care._
Jul 11, 2014 | Televison & Video
Sizzling,smoke,sparks ...horray.
Thats the Inverter board. Your model used several different types which are not interchangeable. You can get the correct Inverter Board for your model by contacting the guys over at www.tvrepairworld.com
Mar 13, 2013 | LG 32LD450 32 In. LCD HDTV
Sony google tv makes sizzling sound
Even after switch off, there can be some discharge of static charges present in and around TV, hot plastic parts can contract and make some noise. Some sets have the cooling fan run for a few seconds more to reach a particular temp, before it is turned off. Just try switching off the power outlet, and removing the plug and see.
Aug 19, 2012 | Sony Google TV NSX-32GT1 32 in. LCD HDTV
My rca p52926 picture cuts in and out
If model number is correct (on rear of set in small letters it should be a PTK 195 chassis) you have a high voltage lead somewhere that is arcing.
This set did have issues with the High Voltage transformer failing and also that High Voltage (well over 10,000 volts) gets distributed to each of the 3 picture tubes this model uses.
Sometimes the lead where it connects to one of the tubes begins to arc---it is coated with white silcone to prevent this.
If arcing around the entry point to any of the tubes sooner or later it will take the set down--destroy parts that are currently ok.
Usually we locate this by turning set on with back off and looking and listening when set is turned on---If a frying or pop is heard up above the main boards--one of the entry points (called the 2nd Anode) is arcing.
I have seen them arc hard enough and long enough to actually crack and break the glass wall of the picture tube.
May 16, 2012 | RCA P52926 52" Rear Projection Television
I have a rca 32v343t atc010a and when i turn it on the power light comes on and the tv makes a noise like its coming on but then theres no picture or sound. I would like to finde out whats causing this to...
It sounds like the High voltage transformer has gone out. If you open the back of the tv and look on the right side, you will see a large (4 - 5 inch) black cylinder with a large wire coming out of the top. without touching anything, look and see if it is cracked.
Feb 18, 2009 | RCA Televison & Video
Projection tv not working
I guess loud sizzling was from High Voltage Splitter in your TV. HV seems cracked and leaking high voltage.
You can observe and confirm it by removing back cover and power up TV from distance and check at rear of TV. Please take care and there should be little dark to observe arc from HV splitter.
If this is the case, HV splitter available in Part Store.
Dec 16, 2008 | Televison & Video
Comes on sizzles then goes off
The sizzling sound is very probably arcing on the fire charred PC board. Warning: there is a dangerous possiility of fire. Do not attempt to operate the set any longer without having it serviced.
If you want to service it yourself, replacement boards may still be available. Contact manufacturer's parts department
Jul 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
350 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
