Question about Canon Pixma MP500 All-In-One InkJet Printer
Canon MP500 Error code 6A00... what is this about?
    President:
  • 787 Answers
Error 6A00 is AP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Posted on Nov 16, 2009
  • Thierry Jul 09, 2013
    I just fixed mine with the same error message. I took off the right side cover and cleaned the purge tray with a cotton round and alcohol. It was stuck with ink. I also forced the white tray to move in and out to clean it.
Posted on Jul 09, 2013
pineworks
  • 4041 Answers
SOURCE: 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
  • 2692 Answers
SOURCE: canon mp 950 has a error code 6A00
There is a problem with the carriage lift mechanism.
Probale causes
1.PR Lift shaft assembly
2.Sheet Feed Unit
3.Logic Board
Only your local Canon Dealer will know
Posted on Mar 12, 2009
komguy
  • 2306 Answers
SOURCE: error 6A00
6A00 is a purge unit error, the station that cleans the printhead on the right hand side. Usually the wiper is jammed into the cleaning pads because of ink buildup. Water on a Q-tip can help clean that area or you may need a new purge assembly about $29.00
Posted on Oct 15, 2009
pineworks
  • 4041 Answers
SOURCE: pixma MP500 has a ERROR code 6A00 and the printer
Hi there
This answers with a titch more detail.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move.
And yes I have found all those things in a purge unit.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Posted on Mar 01, 2010
pineworks
  • 4041 Answers
SOURCE: Error 6A00 on a Canon Pixma MP500
Hi there
All the best
Error A600
Your A600 is a paper path error, usually related to the purge unit. Try checking the purge unit for paper stuck in it.
Almost 90% of the time is related to the purge unit being jammed with something and not being able to move.
Look for paper, paper clips, push pins, screws flower bud pods or the like.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow.
The purge unit is a white plastic assembly (on the right side of the printer where the print head homes) that is spring loaded on rides on a rail.
You can try moving it back and forth about 5 times or so and clean the rail with a cleanex and putting a little bit of some light oil on it and then close everything up and try it.
If you found this useful all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Posted on Mar 02, 2010
Error code 6a00
Error code 6A00 means an error occurred in the AP motor during purging operation. You will need to replace the sheet feed unit (part no. QM2-2916), logic board assy (part no.QM2-3078), purge unit (part no. QM2-2925).
Feb 12, 2011 | Canon Pixma MP500 All-In-One InkJet...
Printer has error code 6A00. What does that mean?
AP position error will trigger a 6A00 error code. An error occurred in the AP motor during purging operation. You will need to replace the Sheet feed unit (QM2-2916), Logic board ***'y (QM2-3078), Purge unit (QM2-2925).
Jan 20, 2011 | Canon Pixma MP500 All-In-One InkJet...
Error code 6A00 when you turn printer on
AP position error causes the 6A00 error code. An error occurred in the AP motor during purging operation. You will need to replace the Sheet feed unit (QM2-2916), Logic board assy (QM2-3078), Purge unit (QM2-2925).
Jan 03, 2011 | Canon Pixma MP500 All-In-One InkJet...
Canon pixma all in one mp500 error code 6A00
6A00 is a problem with the sheet feed unit.
Manually move the print head left and right, and turn the printer on/off. I would also inspect the rollers for ANY debris... it can often be fixed by using "canned air" and blowing the interior out completely.
Apr 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
Error 6A00 mp500 canon
Oct 15, 2009 | Canon Pixma MP500 All-In-One InkJet...
6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Error 6a00 in my mp500 pixma
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Dec 19, 2008 | Canon Pixma MP500 All-In-One InkJet...
Pixma error code 6A00
Dear luis,
Your printer has paper feed related error. There are 2 possibilities of this errror: Auto sheet feeder or logic board faulty. Then you need to replace these parts.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 error 5400
Please l have a problem with my printer whenever l want to Print an error code always comes up on the Screen ERROR CODE 6A00 what should l do
Oct 12, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error 6A00
Solution 1:
Solution 2:
Solution 3:
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP500 All-In-One InkJet Printer Logo
1,095 people viewed this question
old marine
old marine
